Configurer Jeedore
Merci de ton retour,
J’avais désactiver le plugin, je viens de le remettre.
Du coup on mot de passe tu mets quoi ? Car depuis l’application maintenant il faut un compte chez Delta Dore associé à ton domicile. Je mets le mot de passe du compte ??
Voici les logs (la recherche reste vide suite à la réactivation du plugin) :
05/20/2022 12:45:59 - Jeedore Daemon connection has been closed…
05/20/2022 12:45:59 - Connection to DeltaDore server has been closed…
05/20/2022 12:45:59 - Command 1653043557166 executed!
05/20/2022 12:46:18 - Websocket connection initialization…
05/20/2022 12:46:18 - Connecting to ‹ 192.168.50.52 ›
05/20/2022 12:46:20 - Websocket connection has been closed with code:1002 reason:‹ An error has occurred while connecting. ›
05/20/2022 12:46:20 - Jeedore Daemon connection has been closed…
05/20/2022 12:46:20 - Connection to DeltaDore server has been closed…
05/20/2022 12:46:48 - Websocket connection initialization…
05/20/2022 12:46:48 - Connecting to ‹ 192.168.50.52 ›
05/20/2022 12:46:50 - Websocket connection has been closed with code:1002 reason:‹ An error has occurred while connecting. ›
05/20/2022 12:46:50 - Jeedore Daemon connection has been closed…
05/20/2022 12:46:50 - Connection to DeltaDore server has been closed…
05/20/2022 12:47:18 - Websocket connection initialization…
05/20/2022 12:47:18 - Connecting to ‹ 192.168.50.52 ›
05/20/2022 12:47:20 - Websocket connection has been closed with code:1002 reason:‹ An error has occurred while connecting. ›
05/20/2022 12:47:20 - Jeedore Daemon connection has been closed…
05/20/2022 12:47:20 - Connection to DeltaDore server has been closed…
05/20/2022 12:47:48 - Websocket connection initialization…
05/20/2022 12:47:48 - Connecting to ‹ 192.168.50.52 ›
05/20/2022 12:47:50 - Websocket connection has been closed with code:1002 reason:‹ An error has occurred while connecting. ›
05/20/2022 12:47:50 - Jeedore Daemon connection has been closed…
05/20/2022 12:47:50 - Connection to DeltaDore server has been closed…
Merci de ton aide, je l’aimé bien ce plugin !
Pour les DVI K-Line/Deltadore, Il y a plusieurs commandeq dont j’ignore l’info renvoyée :
openstate : statut ouvert ou fermé de la fenêtre, ça j’ai compris
BattDefect : état de la batterie en binaire ->ok
Config : un numéro ? C’est quoi ce numéro?
IntrusionDetect : ? Je comprends pas ce qui est renvoyé là?
SupervisionMode : LONG? Ici non plus !
Pouvez-vous m’éclairer?
Merci et bonne soirée !
Yannick
Bonjour a tous.
Je suis un novice dans lutilisation de jeedom.
J’avais deja chez moi une solution delta dore avec volets roulant, alarme et tydom 2.0.
Jai installé le plugin jeedore, cependant aucun equipement ne remonte lorsque je clique sur get all équipement.
Jai deja essayé de redémarrer la box, les dependances, le demon, et le retablissement des droits.
Pouvez vous me donner un petit coup de pouce pour resoudre mon problème.
Sans les logs la communauté ne devine pas les erreurs des plugin :frowning: d’ou l’intéret de poster avec les logs.
Si je devais tenté je dirais erreur 1002.
Avez-vous (re)vérifié :
  • Adresse MAC de la box tydom.
  • Adresse IP de la box tydom.
  • Network en local.
  • Mots de passe celui pour ce connecter a la box tydom et non a l’application Tydom.
Après avoir fait sa relancer le demon.
Dans mon cas (Tydom 1 avec Jeedom Atlas) sa a marché.
Il y a énormément de sujet ouvert sur ce problème je ne serais te conseiller que de continuer à fouiller dans les différents topic.
En espèrent que cela puisse t’aider.
Artemiss.
Yeap,
Il y a de forte chance que comme beaucoup d’entre nous au début, tu confondes 2 mots de passe. :wink:
  1. le mot de passe du boitier TYDOM
  2. le mode passe de l’application TYDOM
Dans le plugin Jeedore, c’est le 1) qu’il faut valider.
Maintenant comme DeltaDore est en train de faire plein de changement sur la gestion de la solution, tu ne peux plus positionner le mot de passe du boitier TYDOM à l’aide de l’application.
La solution consiste à installer l’application K-line Smart Home. A partir de là, tu peux positionner un mot de passe pour le boitier. Je te déconseille les caractères spéciaux.
Tiens nous au courant.
A priori l’application K-Line est strictement la même que celle de Tydom, il n’y a plus aucun menu pour changer le mot de passe, est-ce qu’il y aurait une autre solution pour le changer ?
Une fois celui-ci réinitialisé en appuyant 15 secondes sur le bouton, n’obtient-on pas un mot de passe par défaut qu’il serait possible d’utiliser ?
Hello
Effectivement je viens de relancer l’app KLine (j’ai été obligé de créer un compte ne pouvant réutiliser celui de DD) : il n’y a plus de possibilité de changer le mot de la box.
Par l’app Tydom non plus.
Le seul moyen désormais est de passer par une ancienne version…
Personnellement cela ne fonctionne pas… je veux bien de l’aide :slight_smile:
Hello
Sur android il te faut autoriser l’installation de sources externes afin de pouvoir executer l’apk d’une version antérieure à la 4.
Sur iPhone, je ne me prononcerais pas cela trop longtemps que je n’ai pas touché ces choses la en dehors du taf.
Il y a possiblement la solution de @Olivier_Pottier mais je ne l’ai pas testé n’ayant pas de visu du code derrière le bouton « se connecter » traitant des informations trop sensible à mon gout.
Enfin personnellement, je n’utilise plus Jeedore qui n’est plus maintenu mais tydom2mqtt qui sait désormais fonctionner avec le compte DD et non la MAC et le mot de passe du Tydom.
Merci pour ta réponse… mais je n’arrive pas à trouver le plugin dans le market. Il faut faire qq chose de spécial ?
Le market ?
Si celui de Jeedom : il n’y a que Jeedore à installer.
Si celui d’android (Play Store) : Il n’y a que la dernière version officielle de Delta Dore (DD).
Si celui d’Apple : idem j’imagine.
Il faut passer par des non-officiels, type apkpure pour android.
ou est ce que tu trouves « tydom2mqtt » ?
ICI mais il est beaucoup moins clé en main que Jeedore…
Il va falloir passer par un broker (serveur) MQTT (mais #plugins:jmqtt le fait très bien).
je vais regarder cela. Merci bp pour ton aide
ok … pas simple à comprendre :slight_smile: Si jamais tu as de l’aide rapidement ou une impression d’écran, je suis preneur :slight_smile:
