Je suis sur un nuc avec une VM sur Débian 9
Jeedom en V4.0.52
Clé conbee 2
Rallonge 3 mètres
Par moment mes périphériques ne répondent plus, et quand je me connecte sur phoscon, c’est indiqué « Firmware : not connected »
Un reboot règle le problème, mais je ne comprends pas pourquoi je perd la connexion.
Voici les dernières lignes de logs de Deconz :
[2020-04-28 12:46:07][DEBUG] : {"00212EFFFF059DFE":{"id":"10","r":"sensors","uniqueid":"00:15:8d:00:01:e4:6e:59-01-0006","config":{"battery":100,"reachable":true,"on":true,"temperature":2300},"e":"changed","t":"event"}}
[2020-04-28 12:46:07][DEBUG] : {"00212EFFFF059DFE":{"id":"10","r":"sensors","uniqueid":"00:15:8d:00:01:e4:6e:59-01-0006","e":"changed","state":{"lastupdated":"2020-04-28T10:46:07","open":false},"t":"event"}}
[2020-04-28 13:46:16][DEBUG] : {"00212EFFFF059DFE":{"id":"1","r":"sensors","uniqueid":"00:21:2e:ff:ff:05:9d:fe-01","e":"changed","state":{"sunset":"2020-04-28T19:04:20","sunrise":"2020-04-28T04:28:08","daylight":true,"status":170,"dark":false,"lastupdated":"2020-04-28T11:46:16"},"t":"event"}}
[2020-04-28 13:46:16][DEBUG] : Something received and no value updated, performing sync to create commands if needed
[2020-04-28 13:46:16][DEBUG] : 192.168.1.103:8484/api/D7EDCB1F3C/sensors type : POST
[2020-04-28 13:46:16][DEBUG] : {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"26b4221758bad5acf0391f295dc2c310","manufacturername":"Philips","modelid":"PHDL00","name":"Daylight","state":{"dark":false,"daylight":true,"lastupdated":"2020-04-28T11:46:16","status":170,"sunrise":"2020-04-28T04:28:08","sunset":"2020-04-28T19:04:20"},"swversion":"1.0","type":"Daylight","uniqueid":"00:21:2e:ff:ff:05:9d:fe-01"},"10":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"3b7bf2e76618447a82488d70d85de992","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"OpenClose 10","state":{"lastupdated":"2020-04-28T10:46:07","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:e4:6e:59-01-0006"},"11":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"a5e9f2d7de2b6265b82fc0e2542b051a","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"OpenClose 11","state":{"lastupdated":"2020-04-28T10:32:14","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:e4:50:77-01-0006"},"2":{"config":{"battery":65,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"0f0dd0d6117c5ae7c179caebf51f4637","manufacturername":"LUMI","modelid":"lumi.weather","name":"Temperature 2","state":{"lastupdated":"2020-04-28T10:18:26","temperature":2172},"swversion":"20161129","type":"ZHATemperature","uniqueid":"00:15:8d:00:01:f5:31:5e-01-0402"},"3":{"config":{"battery":65,"offset":0,"on":true,"reachable":true},"ep":1,"etag":"0f0dd0d6117c5ae7c179caebf51f4637","manufacturername":"LUMI","modelid":"lumi.weather","name":"Humidity 3","state":{"humidity":4582,"lastupdated":"2020-04-28T10:18:26"},"swversion":"20161129","type":"ZHAHumidity","uniqueid":"00:15:8d:00:01:f5:31:5e-01-0405"},"4":{"config":{"battery":65,"on":true,"reachable":true},"ep":1,"etag":"0f0dd0d6117c5ae7c179caebf51f4637","manufacturername":"LUMI","modelid":"lumi.weather","name":"Pressure 4","state":{"lastupdated":"2020-04-28T10:18:26","pressure":994},"swversion":"20161129","type":"ZHAPressure","uniqueid":"00:15:8d:00:01:f5:31:5e-01-0403"},"5":{"config":{"battery":100,"on":true,"reachable":true},"ep":1,"etag":"1fff1eea7dbf13570e02546e48b1e52f","manufacturername":"LUMI","mode":1,"modelid":"lumi.sensor_switch","name":"Switch 5","state":{"buttonevent":1004,"lastupdated":"2020-04-28T07:31:00"},"type":"ZHASwitch","uniqueid":"00:15:8d:00:01:a5:d0:89-01-0006"},"6":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2100},"ep":1,"etag":"4d4eab971faab48c4e3f9f552936a155","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"OpenClose 6","state":{"lastupdated":"2020-04-28T10:37:05","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:e4:6e:82-01-0006"},"7":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"3146ec278d03071189e6fca9b7a47b2f","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"OpenClose 7","state":{"lastupdated":"2020-04-28T10:34:11","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:e4:1c:bb-01-0006"},"8":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2400},"ep":1,"etag":"331c5134b8188368a457855e8cd856d3","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"OpenClose 8","state":{"lastupdated":"2020-04-28T10:40:19","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:de:8c:66-01-0006"},"9":{"config":{"battery":100,"on":true,"reachable":true,"temperature":2300},"ep":1,"etag":"504f3e96b09e78534dca2597e9bcf8f3","manufacturername":"LUMI","modelid":"lumi.sensor_magnet.aq2","name":"OpenClose 9","state":{"lastupdated":"2020-04-28T10:13:08","open":false},"swversion":"20161128","type":"ZHAOpenClose","uniqueid":"00:15:8d:00:01:e4:6e:6e-01-0006"}}
Merci d’avance
