Bonjour, j’ai le plugin MQTT Manager d’installer
Et j’ai changé de plugin, je suis maintenant sur la version officiel (Jeezigbee)
« La commande source » se n’est pas se que j’ai répondu plus haut? {« temperature_measured_value »: VALUE}
"definition": {
"description": "Heating thermostat",
"exposes": [
"access": 1,
"description": "Instantaneous measured power",
"label": "Power",
"name": "power",
"property": "power",
"type": "numeric",
"unit": "W"
"access": 1,
"description": "Sum of consumed energy",
"label": "Energy",
"name": "energy",
"property": "energy",
"type": "numeric",
"unit": "kWh"
"access": 7,
"description": "Controls piloting mode",
"label": "Schneider pilot mode",
"name": "schneider_pilot_mode",
"property": "schneider_pilot_mode",
"type": "enum",
"values": [
"contactor",
"pilot"
"features": [
"access": 7,
"description": "Temperature setpoint",
"label": "Occupied heating setpoint",
"name": "occupied_heating_setpoint",
"property": "occupied_heating_setpoint",
"type": "numeric",
"unit": "\u00b0C",
"value_max": 30,
"value_min": 4,
"value_step": 0.5
"access": 5,
"description": "Current temperature measured on the device",
"label": "Local temperature",
"name": "local_temperature",
"property": "local_temperature",
"type": "numeric",
"unit": "\u00b0C"
"access": 7,
"description": "Mode of this device",
"label": "System mode",
"name": "system_mode",
"property": "system_mode",
"type": "enum",
"values": [
"off",
"auto",
"heat"
"access": 1,
"description": "Position of the valve (= demanded heat) where 0% is fully closed and 100% is fully open",
"label": "PI heating demand",
"name": "pi_heating_demand",
"property": "pi_heating_demand",
"type": "numeric",
"unit": "%",
"value_max": 100,
"value_min": 0
"type": "climate"
"access": 1,
"description": "Link quality (signal strength)",
"label": "Linkquality",
"name": "linkquality",
"property": "linkquality",
"type": "numeric",
"unit": "lqi",
"value_max": 255,
"value_min": 0
"model": "CCTFR6700",
"options": [
"access": 2,
"description": "Controls the temperature unit of the thermostat (default celsius).",
"label": "Thermostat unit",
"name": "thermostat_unit",
"property": "thermostat_unit",
"type": "enum",
"values": [
"celsius",
"fahrenheit"
"access": 2,
"description": "Number of digits after decimal point for power, takes into effect on next report of device.",
"label": "Power precision",
"name": "power_precision",
"property": "power_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Calibrates the power value (percentual offset), takes into effect on next report of device.",
"label": "Power calibration",
"name": "power_calibration",
"property": "power_calibration",
"type": "numeric"
"access": 2,
"description": "Number of digits after decimal point for energy, takes into effect on next report of device.",
"label": "Energy precision",
"name": "energy_precision",
"property": "energy_precision",
"type": "numeric",
"value_max": 3,
"value_min": 0
"access": 2,
"description": "Calibrates the energy value (percentual offset), takes into effect on next report of device.",
"label": "Energy calibration",
"name": "energy_calibration",
"property": "energy_calibration",
"type": "numeric"
"supports_ota": false,
"vendor": "Schneider Electric"
"disabled": false,
"endpoints": {
"1": {
"bindings": [
"cluster": "hvacThermostat",
"target": {
"endpoint": 1,
"ieee_address": "0x00212effff059d6e",
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genIdentify",
"genGroups",
"hvacThermostat",
"haDiagnostic",
"schneiderSpecificPilotMode"
"output": [
"genIdentify",
"genOta",
"msTemperatureMeasurement"
"configured_reportings": [
"attribute": "occupiedHeatingSetpoint",
"maximum_report_interval": 3600,
"minimum_report_interval": 0,
"reportable_change": 10
"attribute": "pIHeatingDemand",
"scenes": []
"2": {
"bindings": [
"cluster": "seMetering",
"target": {
"endpoint": 1,
"type": "endpoint"
"clusters": {
"input": [
"genBasic",
"genIdentify",
"genGroups",
"seMetering"
"output": [
"genIdentify"
"attribute": "instantaneousDemand",
"maximum_report_interval": 60,
"attribute": "currentSummDelivered",
"scenes": []
"242": {
"bindings": [],
"clusters": {
"input": [],
"output": [
"greenPower"
"configured_reportings": [],
"scenes": []
"friendly_name": "0xe0798dfffe35f959",
"ieee_address": "0xe0798dfffe35f959",
"interview_completed": true,
"interviewing": false,
"manufacturer": "Schneider Electric",
"model_id": "CCTFR6700",
"network_address": 40431,
"power_source": "Mains (single phase)",
"supported": true,
"type": "Router"```
