Je suis parti en vacances, tout a décroché…
Tant pis je regarderai en rentrant.
J’ai quand-même jeté un œil, le démon redémarre en boucle …
zigbee2mqtt@1.37.1 start
> node index.js
[2024-09-05 15:20:21] e[31merrore[39m: z2m: Failed to load external converter file '/var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js' (Cannot find module 'zigbee-herdsman-converters/lib/extend'
Require stack:
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/utils.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/dist/util/settings.js
- /var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js)
[2024-09-05 15:20:21] e[31merrore[39m: z2m: Probably there is a syntax error in the file or the external converter is not compatible with the current Zigbee2MQTT version
[2024-09-05 15:20:21] e[31merrore[39m: z2m: Note that external converters are not meant for long term usage, it's meant for local testing after which a pull request should be created to add out-of-the-box support for the device
[2024-09-05 15:20:41] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2024-09-05 15:20:41] e[31merrore[39m: z2m: Failed to start zigbee
[2024-09-05 15:20:41] e[31merrore[39m: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-09-05 15:20:41] e[31merrore[39m: z2m: Exiting...
[2024-09-05 15:20:41] e[31merrore[39m: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:101:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:124:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:62:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:109:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:107:5)
Mince !
Tente de passer a Ember ?
De mon coté, je continue a toucher du bois, mais ca tient !
Je suis en vacances je regarderai a mon retour, j’ai demandé a un voisin de rebooter la clef zigbee. Ça ne donne rien. Heureusement que je n’ai besoin ni du chauffage ni de l’arrosage auto…
Hello
J’avais laissé les MAJ en automatique sur la clé SMlight et une maj avec un bug est passée juste après notre départ…
Downgrade et tout est rentré dans l’ordre. Tout a l’air stable ![]()
