Commande absente Sirene HS2WD-E
En debug dans MQTT Discovery
Voici ce que j’ai trouvé
[2026-10-13 08:38:58] DEBUG  Publish {"warning": {"mode": "{{ tone | default('emergency') }}", "level": "{% if volume_level is defined %}{% if volume_level | float <= 0.25 %}low{% elif volume_level | float <= 0.5 %}medium{% elif volume_level | float <= 0.75 %}high{% else %}very_high{% endif %}{% else %}medium{% endif %}", "duration": {{ duration | default(10) }}}} on zigbee2mqtt_nano/Sirene/set
[2026-10-13 08:38:58] DEBUG  params to send to daemon:{"action":"publish","topic":"zigbee2mqtt_nano\/Sirene\/set","payload":"{\"warning\": {\"mode\": \"{{ tone | default('emergency') }}\", \"level\": \"{% if volume_level is defined %}{% if volume_level | float <= 0.25 %}low{% elif volume_level | float <= 0.5 %}medium{% elif volume_level | float <= 0.75 %}high{% else %}very_high{% endif %}{% else %}medium{% endif %}\", \"duration\": {{ duration | default(10) }}}}","context":{"value":"emergency","tone":"emergency","volume":10,"duration":2}}
[2026-10-13 08:39:18] DEBUG  new message:{"zigbee2mqtt_nano":{"bridge":{"devices":[{"disabled":false,"endpoints":{"1":{"bindings":[],"clusters":{"input":["genBasic","genIdentify","genOnOff","genLevelCtrl","genTime","genOta","lightingColorCtrl"],"output":["genBasic","genIdentify","genGroups","genScenes","genOnOff","genLevelCtrl","genPollCtrl","lightingColorCtrl","msIlluminanceMeasurement","msTemperatureMeasurement","msRelativeHumidity","msOccupancySensing","ssIasZone","seMetering","seMeterIdentification","haApplianceStatistics","haElectricalMeasurement","touchlink"]},"configured_reportings":[],"scenes":[]},"242":{"bindings":[],"clusters":{"input":["greenPower"],"output":["greenPower"]},"configured_reportings":[],"scenes":  // TROP LONG
Dans les logs du DEMON je n’ai pas de debug je n’ai que des INFO
[2026-10-13 08:49:05] INFO  : Publishing '{"warning": {"mode": "emergency", "level": "medium", "duration": 2}}' on 'zigbee2mqtt_nano/Sirene/set'
Pour les logs du démon c’est parce qu’il faut toujours relancer le démon après avoir changé le niveau de log.
Mais pas grave, je pense avoir compris, j’ai mis une nouvelle beta en ligne.
