Oui, mais j’ai utilisé le bouton assistance pour créer le post
Zigbee2mqtt étant toujours l’id du plugin, on se comprend ? En plus j’ai mis assez de screen.
Donc hier soir j’ai mis des client id pour les plugins ZigbeeLinker (Jeedom02) et jMQTT (Jeedom01).
Les 2 se sont connecté sans soucis avec les nouveau id et depuis on vois que le seul à se déconnecter c’est ZigbeeLinker.
1706216877: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706218353: Client jeedomzb1479 disconnected.
1706218474: New connection from 192.168.2.50:52874 on port 1883.
1706218474: New client connected from 192.168.2.50:52874 as jeedomzb1479 (p2, c1, k60).
1706218678: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706219121: Client jeedomzb1479 disconnected.
1706219244: New connection from 192.168.2.50:56506 on port 1883.
1706219244: New client connected from 192.168.2.50:56506 as jeedomzb1479 (p2, c1, k60).
1706220479: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706221878: Client jeedomzb1479 disconnected.
1706221994: New connection from 192.168.2.50:41816 on port 1883.
1706221994: New client connected from 192.168.2.50:41816 as jeedomzb1479 (p2, c1, k60).
1706222280: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706223843: Client auto-F8583068-6E3B-9EC2-D863-DA21511BD9EF disconnected.
1706223843: New connection from 192.168.2.50:53967 on port 1883.
1706223843: New client connected from 192.168.2.50:53967 as JeedomJmqtt (p2, c1, k30).
1706223858: Client JeedomJmqtt disconnected.
1706223858: New connection from 192.168.2.50:54285 on port 1883.
1706223858: New client connected from 192.168.2.50:54285 as Jeedom01 (p2, c1, k30).
1706223874: Client jeedomzb1479 closed its connection.
1706223874: New connection from 192.168.2.50:51212 on port 1883.
1706223874: New client connected from 192.168.2.50:51212 as Jeedom02 (p2, c1, k60).
1706224081: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706225090: Client Jeedom02 disconnected.
1706225217: New connection from 192.168.2.50:57598 on port 1883.
1706225217: New client connected from 192.168.2.50:57598 as Jeedom02 (p2, c1, k60).
1706225882: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706225990: Client Jeedom02 disconnected.
1706226108: New connection from 192.168.2.50:33808 on port 1883.
1706226108: New client connected from 192.168.2.50:33808 as Jeedom02 (p2, c1, k60).
1706227683: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706228525: Client Jeedom02 disconnected.
1706228650: New connection from 192.168.2.50:46190 on port 1883.
1706228650: New client connected from 192.168.2.50:46190 as Jeedom02 (p2, c1, k60).
1706229484: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706231285: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706231969: Client Jeedom02 disconnected.
1706232093: New connection from 192.168.2.50:34760 on port 1883.
1706232093: New client connected from 192.168.2.50:34760 as Jeedom02 (p2, c1, k60).
1706233086: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706234887: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706235020: Client mqttjs_bcca87f9 closed its connection.
1706235076: New connection from 192.168.2.194:52788 on port 1883.
1706235076: New client connected from 192.168.2.194:52788 as mqttjs_82f9347d (p2, c1, k60).
1706235444: Client Jeedom02 disconnected.
1706235569: New connection from 192.168.2.50:51744 on port 1883.
1706235569: New client connected from 192.168.2.50:51744 as Jeedom02 (p2, c1, k60).
1706236505: Client Jeedom02 disconnected.
1706236625: New connection from 192.168.2.50:56878 on port 1883.
1706236625: New client connected from 192.168.2.50:56878 as Jeedom02 (p2, c1, k60).
1706236688: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706238414: Client Jeedom02 disconnected.
1706238489: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706238539: New connection from 192.168.2.50:38016 on port 1883.
1706238539: New client connected from 192.168.2.50:38016 as Jeedom02 (p2, c1, k60).
1706238778: Client Jeedom02 disconnected.
1706238903: New connection from 192.168.2.50:39728 on port 1883.
1706238903: New client connected from 192.168.2.50:39728 as Jeedom02 (p2, c1, k60).
1706240290: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706242060: Client Jeedom02 disconnected.
1706242091: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706242180: New connection from 192.168.2.50:55786 on port 1883.
1706242180: New client connected from 192.168.2.50:55786 as Jeedom02 (p2, c1, k60).
1706242314: Client Jeedom02 disconnected.
1706242433: New connection from 192.168.2.50:56956 on port 1883.
1706242433: New client connected from 192.168.2.50:56956 as Jeedom02 (p2, c1, k60).
1706243892: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706245132: Client Jeedom02 disconnected.
1706245249: New connection from 192.168.2.50:42694 on port 1883.
1706245249: New client connected from 192.168.2.50:42694 as Jeedom02 (p2, c1, k60).
1706245693: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706247455: Client Jeedom02 disconnected.
1706247494: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706247581: New connection from 192.168.2.50:53944 on port 1883.
1706247581: New client connected from 192.168.2.50:53944 as Jeedom02 (p2, c1, k60).
1706249203: Client Jeedom02 disconnected.
1706249295: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706249330: New connection from 192.168.2.50:34328 on port 1883.
1706249330: New client connected from 192.168.2.50:34328 as Jeedom02 (p2, c1, k60).
1706251021: Client Jeedom02 disconnected.
1706251096: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706251146: New connection from 192.168.2.50:43172 on port 1883.
1706251146: New client connected from 192.168.2.50:43172 as Jeedom02 (p2, c1, k60).
1706251466: Client Jeedom02 disconnected.
1706251586: New connection from 192.168.2.50:45274 on port 1883.
1706251586: New client connected from 192.168.2.50:45274 as Jeedom02 (p2, c1, k60).
1706251780: Client Jeedom02 disconnected.
1706251905: New connection from 192.168.2.50:46854 on port 1883.
1706251905: New client connected from 192.168.2.50:46854 as Jeedom02 (p2, c1, k60).
1706252897: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706253901: Client Jeedom02 disconnected.
1706254028: New connection from 192.168.2.50:57142 on port 1883.
1706254028: New client connected from 192.168.2.50:57142 as Jeedom02 (p2, c1, k60).
1706254638: Client Jeedom02 disconnected.
1706254698: Saving in-memory database to /mosquitto/data/mosquitto.db.
1706254765: New connection from 192.168.2.50:60820 on port 1883.
1706254765: New client connected from 192.168.2.50:60820 as Jeedom02 (p2, c1, k60).
1706254820: Client Jeedom02 disconnected.
1706254942: New connection from 192.168.2.50:33446 on port 1883.
1706254942: New client connected from 192.168.2.50:33446 as Jeedom02 (p2, c1, k60).
