### What happened?
Hello all,
I have been trying to get my zigbee2MQTT server …up and running for 2 weeks now. I have also done a lot of research, but unfortunately I have not found my case. Also not in the "FAQ / No logging is shown at all".
The system seems to boot without errors. At least I can't see anything.
In the MQTT you can see that Z2M is online.
The frontend also loads and can be operated.
If I activate Join nothing happens. No log, no message, zero.
Currently I am testing on an absolutely identical PC. With this has never been a zigbee device connected. When I activate the pairing at my Lidl /Silvercrest socket, then I get the message "Device has left the network". Apparently the dongle is receiving something. But a pairing is not performed. In the configuration.yaml no device is listed.
About my system:
I have a Nuc i5... Ubuntu is the operating system (reinstalled yesterday).
MQTT and Z2M are running in Docker. I have the Sonoff dongle zbdongle-p (zStack3x0 | 20221226) in use.
The configuration.yaml looks like this:
homeassistant: false
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://192.168.188.63
user: hass
password: NotthisTime;-)
serial:
port: /dev/ttyUSB0
frontend:
port: 8080
advanced:
log_level: debug
my Docker logs:
Using '/app/data' as data directory
Zigbee2MQTT:debug 2023-03-03 22:20:55: Loaded state from file /app/data/state.json
Zigbee2MQTT:info 2023-03-03 22:20:55: Logging to console and directory: '/app/data/log/2023-03-03.22-20-54' filename: log.txt
Zigbee2MQTT:debug 2023-03-03 22:20:55: Removing old log directory '/app/data/log/2023-03-03.21-20-45'
Zigbee2MQTT:info 2023-03-03 22:20:55: Starting Zigbee2MQTT version 1.30.2 (commit #cdf62ea)
Zigbee2MQTT:info 2023-03-03 22:20:55: Starting zigbee-herdsman (0.14.96)
Zigbee2MQTT:debug 2023-03-03 22:20:55: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/app/data/coordinator_backup.json","databaseBackupPath":"/app/data/database.db.backup","databasePath":"/app/data/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"path":"/dev/ttyUSB0"}}'
Zigbee2MQTT:info 2023-03-03 22:20:55: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-03-03 22:20:55: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:debug 2023-03-03 22:20:55: Zigbee network parameters: {"channel":11,"extendedPanID":"0x00124b0029e8d588","panID":6754}
Zigbee2MQTT:info 2023-03-03 22:20:55: Currently 0 devices are joined:
Zigbee2MQTT:info 2023-03-03 22:20:55: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-03-03 22:20:55: Connecting to MQTT server at mqtt://192.168.188.63
Zigbee2MQTT:debug 2023-03-03 22:20:55: Using MQTT login with username: hass
Zigbee2MQTT:info 2023-03-03 22:20:55: Connected to MQTT server
Zigbee2MQTT:info 2023-03-03 22:20:55: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-03-03 22:20:56: Started frontend on port 0.0.0.0:8080
Zigbee2MQTT:debug 2023-03-03 22:20:56: Received MQTT message on 'zigbee2mqtt/bridge/config' with data '{"commit":"cdf62ea","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x00124b0029e8d588","panID":6754},"permit_join":false,"version":"1.30.2"}'
Zigbee2MQTT:info 2023-03-03 22:20:56: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"cdf62ea","coordinator":{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20221226,"transportrev":2},"type":"zStack3x0"},"log_level":"debug","network":{"channel":11,"extendedPanID":"0x00124b0029e8d588","panID":6754},"permit_join":false,"version":"1.30.2"}'
Zigbee2MQTT:info 2023-03-03 22:20:56: Zigbee2MQTT started!
Zigbee2MQTT:debug 2023-03-03 22:21:13: Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"3tvuh-1","value":true}'
Zigbee2MQTT:info 2023-03-03 22:21:13: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-03-03 22:21:14: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"3tvuh-1"}'
Zigbee2MQTT:debug 2023-03-03 22:25:55: Saving state to file /app/data/state.json
Zigbee2MQTT:debug 2023-03-03 22:30:55: Saving state to file /app/data/state.json
Zigbee2MQTT:debug 2023-03-03 22:35:55: Saving state to file /app/data/state.json
Zigbee2MQTT:debug 2023-03-03 22:40:55: Saving state to file /app/data/state.json
Zigbee2MQTT:debug 2023-03-03 22:45:55: Saving state to file /app/data/state.json
Zigbee2MQTT:debug 2023-03-03 22:50:55: Saving state to file /app/data/state.json
As mentioned before, I get absolutely no feedback on what should go wrong. I cannot register any devices. However, the system seems to be running. If you have any tips for me, I'd really appreciate it.
Greeting from Bolheim
Rü
### What did you expect to happen?
I expect, that the devices
### How to reproduce it (minimal and precise)
i expect the devices to connect
### Zigbee2MQTT version
1.30.2 commit: cdf62ea
### Adapter firmware version
20221226
### Adapter
### Debug log
2023-03-03 22:21:13Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"3tvuh-1","value":true}'
Info 2023-03-03 22:21:13Zigbee: allowing new devices to join.
Info 2023-03-03 22:21:14MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"3tvuh-1"}'
Debug 2023-03-03 22:25:55Saving state to file /app/data/state.json
Debug 2023-03-03 22:30:55Saving state to file /app/data/state.json
Debug 2023-03-03 22:35:55Saving state to file /app/data/state.json
Debug 2023-03-03 22:40:55Saving state to file /app/data/state.json
Debug 2023-03-03 22:45:55Saving state to file /app/data/state.json
Debug 2023-03-03 22:50:55Saving state to file /app/data/state.json
Debug 2023-03-03 22:55:55Saving state to file /app/data/state.json
