@Eli
dans le doute j ai réinstallé la version beta du plugin et j ai toujours ca
[Fri Dec 06 18:56:14.315947 2019] [:error] [pid 15189] [client ::1:43895] PHP Fatal error: Uncaught Error: Call to a member function getConfiguration() on boolean in /var/www/html/plugins/jeedore/core/php/callback.php:101
Stack trace:
#0 {main}
thrown in /var/www/html/plugins/jeedore/core/php/callback.php on line 101
avant c’était ligne 106 car j’ajoute ca au caalback.php:
$endpoint->usage == 'conso' ||
$endpoint->usage == 'window' ||
$endpoint->usage == 'others' ||
$endpoint->usage == '' ||
$endpoint->usage == 'alarm' ||
log jeedore deamon :
12/06/2019 18:56:14 - Sending DeltaDore response to Jeedom, command : 'getcmddata'...
12/06/2019 18:56:14 - An error 'InternalServerError' occured while posting to Jeedom command : 'getcmddata' parameters : '[{"id":"14#14","cmd": "getLevel14#14", "value": 34, "validity": "upToDate" },{"id":"18#18","cmd": "getLevel18#18", "value": 0, "validity": "upToDate" },{"id":"19#19","cmd": "getLevel19#19", "value": 100, "validity": "upToDate" },{"id":"22#22","cmd": "getLevel22#22", "value": 0, "validity": "upToDate" },{"id":"24#24","cmd": "getPosition24#24", "value": 0, "validity": "upToDate" },{"id":"40#40","cmd": "getLevel40#40", "value": 0, "validity": "upToDate" },{"id":"41#41","cmd": "getLevel41#41", "value": 0, "validity": "upToDate" },{"id":"42#42","cmd": "getLevel42#42", "value": 0, "validity": "upToDate" },{"id":"43#43","cmd": "getLevel43#43", "value": 0, "validity": "upToDate" },{"id":"45#45","cmd": "getPosition45#45", "value": 0, "validity": "upToDate" },{"id":"52#52","cmd": "getLevel52#52", "value": 100, "validity": "upToDate" },{"id":"49#49","cmd": "getPosition49#49", "value": 0, "validity": "upToDate" },{"id":"1537800401#1537800401","cmd": "getPosition1537800401#1537800401", "value": 100, "validity": "upToDate" },{"id":"1537896761#1537896761","cmd": "getPosition1537896761#1537896761", "value": 0, "validity": "upToDate" },{"id":"1537897001#1537897001","cmd": "getPosition1537897001#1537897001", "value": 0, "validity": "upToDate" },{"id":"1537983041#1537983041","cmd": "getLevel1537983041#1537983041", "value": 0, "validity": "upToDate" },{"id":"1538901223#1538901223","cmd": "getPosition1538901223#1538901223", "value": 0, "validity": "upToDate" },{"id":"1538901823#1538901823","cmd": "getPosition1538901823#1538901823", "value": 0, "validity": "upToDate" },{"id":"1538906863#1538906863","cmd": "getPosition1538906863#1538906863", "value": 0, "validity": "upToDate" },{"id":"1538906923#1538906923","cmd": "getPosition1538906923#1538906923", "value": 0, "validity": "upToDate" },{"id":"1538915503#1538915503","cmd": "getPosition1538915503#1538915503", "value": 0, "validity": "upToDate" },{"id":"1546013309#1546013309","cmd": "authorization1546013309#1546013309", "value": "HEATING", "validity": "upToDate" },{"id":"1546013309#1546013309","cmd": "setpoint1546013309#1546013309", "value": "20", "validity": "upToDate" },{"id":"1546013309#1546013309","cmd": "thermicLevel1546013309#1546013309", "value": "", "validity": "upToDate" },{"id":"1546013309#1546013309","cmd": "hvacMode1546013309#1546013309", "value": "NORMAL", "validity": "upToDate" },{"id":"1546013309#1546013309","cmd": "temperature1546013309#1546013309", "value": "20.01", "validity": "upToDate" },{"id":"1546013309#1546013309","cmd": "absence1546013309#1546013309", "value": "False", "validity": "upToDate" },{"id":"1546013310#1546013309","cmd": "authorization1546013310#1546013309", "value": "HEATING", "validity": "upToDate" },{"id":"1546013310#1546013309","cmd": "setpoint1546013310#1546013309", "value": "20.5", "validity": "upToDate" },{"id":"1546013310#1546013309","cmd": "thermicLevel1546013310#1546013309", "value": "", "validity": "upToDate" },{"id":"1546013310#1546013309","cmd": "hvacMode1546013310#1546013309", "value": "NORMAL", "validity": "upToDate" },{"id":"1546013310#1546013309","cmd": "temperature1546013310#1546013309", "value": "20.67", "validity": "upToDate" },{"id":"1546013310#1546013309","cmd": "absence1546013310#1546013309", "value": "False", "validity": "upToDate" },{"id":"1546013311#1546013309","cmd": "authorization1546013311#1546013309", "value": "HEATING", "validity": "upToDate" },{"id":"1546013311#1546013309","cmd": "setpoint1546013311#1546013309", "value": "21", "validity": "upToDate" },{"id":"1546013311#1546013309","cmd": "thermicLevel1546013311#1546013309", "value": "", "validity": "upToDate" },{"id":"1546013311#1546013309","cmd": "hvacMode1546013311#1546013309", "value": "NORMAL", "validity": "upToDate" },{"id":"1546013311#1546013309","cmd": "temperature1546013311#1546013309", "value": "16.81", "validity": "upToDate" },{"id":"1546013311#1546013309","cmd": "absence1546013311#1546013309", "value": "False", "validity": "upToDate" },{"id":"1546013312#1546013309","cmd": "authorization1546013312#1546013309", "value": "HEATING", "validity": "upToDate" },{"id":"1546013312#1546013309","cmd": "setpoint1546013312#1546013309", "value": "21", "validity": "upToDate" },{"id":"1546013312#1546013309","cmd": "thermicLevel1546013312#1546013309", "value": "", "validity": "upToDate" },{"id":"1546013312#1546013309","cmd": "hvacMode1546013312#1546013309", "value": "NORMAL", "validity": "upToDate" },{"id":"1546013312#1546013309","cmd": "temperature1546013312#1546013309", "value": "21.18", "validity": "upToDate" },{"id":"1546013312#1546013309","cmd": "absence1546013312#1546013309", "value": "False", "validity": "upToDate" },{"id":"1546016127#1546016127","cmd": "authorization1546016127#1546016127", "value": "HEATING", "validity": "upToDate" },{"id":"1546016127#1546016127","cmd": "setpoint1546016127#1546016127", "value": "22", "validity": "upToDate" },{"id":"1546016127#1546016127","cmd": "thermicLevel1546016127#1546016127", "value": "", "validity": "upToDate" },{"id":"1546016127#1546016127","cmd": "hvacMode1546016127#1546016127", "value": "NORMAL", "validity": "upToDate" },{"id":"1546016127#1546016127","cmd": "temperature1546016127#1546016127", "value": "22.04", "validity": "upToDate" },{"id":"1546016127#1546016127","cmd": "absence1546016127#1546016127", "value": "False", "validity": "upToDate" },{"id":"1575215963#1575215963","cmd": "getLevel1575215963#1575215963", "value": 0, "validity": "upToDate" },{"id":"1575216025#1575216025","cmd": "getLevel1575216025#1575216025", "value": 0, "validity": "upToDate" },{"id":"1575216366#1575216366","cmd": "getLevel1575216366#1575216366", "value": 0, "validity": "upToDate" },{"id":"1575216437#1575216437","cmd": "getLevel1575216437#1575216437", "value": 0, "validity": "upToDate" }]'
12/06/2019 18:56:15 - Executing commamd to device : 'Rezolv.JeeDore.Server.DeltaDore.Request.GetInfo'...
12/06/2019 18:56:15 - Sending command 1575658575843 to DeltaDore...
12/06/2019 18:56:15 - Command 1575658575843 executed!
12/06/2019 18:56:15 - An expected message has been received from DeltaDore
12/06/2019 18:56:15 - Sending DeltaDore response to Jeedom, command : 'box'...
12/06/2019 18:56:15 - Command '/info' has been posted to Jeedom successfully!
12/06/2019 18:59:23 - An error 'InternalServerError' occured while posting to Jeedom command : 'getcmddata' parameters : '[{"id":"1546013310#1546013309","cmd": "temperature1546013310#1546013309", "value": "20.65", "validity": "upToDate" }]'
