Je viens de recevoir ce message de la part de Blink.
Est-ce la fin du plugin du coup ?
Inquiet aussi…
Pas très rassurant en effet
Je suis en stress
Peut-être @Duke9 en sait un peu plus ?
Ci dessous ma correspondance avec le support Blink:
Hi,
I have received a mail asking telling me that i am using a script with a old authentication method and suggesting me using ifttt instead with only 6 days to react.
Problem : the script i am using permits me to activate only one camera (or two, three, four…) instead of the whole system.
Is it possible to get same feature with ifttt?
Currently with ifttt, i can only arm the full system and that’s a problem.
Best regards,
Fabien
Fabien,
Thank you for contacting Blink. You are able to manually arm and disarm individual cameras on your Blink System at anytime by using the running man icon, Blink Support
Currently Blink only integrates with IFTTT and Amazon Alexa-enabled products, you cam learn more about these integrations here:
https://support.blinkforhome.com/integrations/how-to-integrate-blink-with-ifttt-services?from_search=45426711
https://support.blinkforhome.com/integrations/alexa-setup-and-troubleshooting-guide?from_search=45426740
Thank you for being a Blink Customer
Hello Heido,
What I do with my blink system and the script:
- If burgral alarme is unarmed:
At 9pm, the system is armed with only my two blink cameras placed outdoor.
At 23pm, the system is armed with the two outside cameras, the living room camera and the basement camera
At 6 am, the system is unarmed.
- If burgral alarme is armed:
All the system is armed (5 cameras)
All this fings are done automatically without opening the app. I’m not interested to doing this manually, this is not confortable.
I can understand that you blocked an old authentication system but why don’t you propose such possibilities on ifttt?
Best regards,
Fabien
Fabien,
Right now we do not have individual camera scheduled arming, however we do have system scheduled arming, https://support.blinkforhome.com/using-the-blink-app/how-do-i-use-scheduled-arming?from_search=44860601
We do see a lot of customers who would like this feature and it seems like something that could be very valuable. I cannot comment on our future roadmap, however I will pass along the suggestion to the team for future consideration.
You can at this time manually arm/disarm individual cameras on the same sync module using the running man icon. https://support.blinkforhome.com/87511-using-the-blink-app/what-is-the-running-man-icon?from_search=44860651
You could do this at this time by placing some cameras on a different sync module. You are able to set-up and access this second system from the same account by using the multi-system support feature. With our multi-system support feature, you can access and use two or more (up to 5) separate Blink systems from the same Blink App account. For more information on how to do this, please check out our support article:
https://support.blinkforhome.com/using-the-blink-app/how-can-i-access-multiple-blink-systems-from-one-account?from_search=44799299
Note Geofencing can be done using IFTTT at this time as well , https://support.blinkforhome.com/integrations/how-to-integrate-blink-with-ifttt-services
https://ifttt.com/applets/BwKMjb7c-disarm-your-blink-when-the-first-family-member-arrives-at-home
Regards,
Heidi @ Blink
J’ai fait ma demande de fonctionnalité via ifttt également.
Je n’utilise pas les fonctionnalités de visualisation du plug in mais j’apprécie la souplesse qu’il apporte dans l’activation du système.
Si vous avez des doléances, il faut leur transmettre (qui ne tente rien…)
C’était vraiment super ce plugin
Bonjour tout le monde,
Je ne sais pas si le plugin va continuer de fonctionner encore longtemps ? En attendant je me suis amusé à essayer une solution de contournement à mon besoin, avec IFTTT… même si IFTTT est loin d’être stable ou rapide.
Bref, je ne me suis pas encore penché sur le fait d’armer les caméras séparément. Peut être possible via Alexa si pas possible via Webhook IFTTT ?!
Toujours est-il que pour l’alerting sur la détection de mouvement (jusqu’à présent j’utilise [Dernier événement] du plugin Blink), j’ai mis en oeuvre une solution de contournement. Elle nécessite les 3 plugins : IFTTT, SCRIPT et VIRTUEL
Pardon si ça ressemble à une usine à gaz mais je n’ai pas de grandes compétences de dev ^^
Si vous avez une solution plus simple je suis preneur !
Concrètement j’ai 4 caméras blink, mais ça fonctionnera avec n’importe quel nombre
Dans un premier temps via le plugin IFTTT j’ai créé 1 nouvel équipement qui contient 4 commandes info (mes 4 caméras). Ex pour l’une des caméras : MotionENTREE qui vaut 0 par défaut
Puis j’ai créé dans platform.ifttt.com 4 applets pour Blink qui se chargent d’aller changer la valeur de ces commandes avec une URL qui se termine par value=1. Du coup, si mouvement détecte par la caméra à l’entrée alors ma commande MotionENTREE = 1
Tout est très bien expliqué ici https://jeedom.github.io/plugin-ifttt/fr_FR/ à la section 5 « Envoi d’information de IFTTT vers Jeedom »
J’ai créé un virtuel « IFTTT Motion Cameras Virtuel » avec une commande info qui est la somme de mes 4 commandes IFTTT (mes 4 caméras). Donc quand pas de mouvement ça vaut 0 et ça peut valoir jusque 4 si les 4 caméras détectent en même temps un mouvement !
J’ai un scénario dont le déclencheur est le virtuel : #[VIRTUEL][IFTTT Motion Cameras Virtuel ][IFTTT_Motion]# > 0
Si il vaut 1 (ou 2 ou 3 ou 4) alors le scénario va être exécuté
Dans ce scénario, j’ai des blocs SI (un bloc par caméra). Ex avec la caméra de l’entrée :
SI #[SYSTEME][IFTTT Caméras Blink][MotionENTREE]# == 1 alors je lance un scénario qui m’avertit par messages (comme je suis équipé, ça envoie un message sur Telegram, un sur Lametric, ça display une flèche sur le Dotti et change la couleur d’une hue go ^^)
- Attention, le retour à l’état 0 (pas de mouvement) ne se fait pas tout seul, c’est là ou j’utilise le plugin Script. J’ai créé un script qui contient 4 commandes action de type http. Chacune de ces commandes correspond à une caméra. En fait, ces commandes contiennent les URL déjà renseignées dans l’interface IFTTT (etape 2 ci dessus) sauf qu’à la fin, j’ai mis value=0
Et je lance le script depuis mon scenario de l’étape 4. Dans chaque bloc SI, une fois alerté, je fais un sleep de quelques secondes puis je vais chercher la commande de mon script qui correspond à la caméra concernée afin de repasser la valeur à 0. Nb : une alternative consiste à paramétrer ce script directement depuis la configuration des commandes IFTTT (etape 1) dans « Action sur la valeur ». Si valeur = 1 plus de 1mn, alors jouer le script concerné
Voilà, au cas où le plugin devient obsolète, si ça peut aider ou inspirer …?
Pour le moment le plugin fonctionne toujours
le PLUNGIN fonctionne toujours ?
chez moi le plugin ne fonctionne plus
Idem, plus rien chez moi
Est-ce que le créateur du plugin est parmi nous ? Il se passe des choses par ici : https://github.com/home-assistant/core/pull/35396
Peut être que ça pourrait être utile ?
Ça a l’air pas mal c’est clair
Beaucoup moins réactif avec IFTTT
Je m’ennuie déjà.
C’est nul iftt
Jai donc basculé la gestion de mes cameras avec ifttt.
Voici un rex après après quelques jours :
- alerte sur détection de mouvement : trop de latence entre le mouvement et l’alerting. Il se passe parfois jusqu’à 15mn entre le mouvement et la notification via ifttt !!
- armer / désarmer les caméras : ça par contre ça marche super bien, très réactif. On peut armer ou désarmer séparément chacun des réseaux depuis JEEDOM sans problème en passant par ifttt ==> Moi j’ai un réseau FRONT (2 caméras) et un réseau BACK (2 caméras).
Comment fait tu pour armer des caméras séparées moi ça arme ou désarmé tout le système
@Tiectac au temps pour moi, j’ai corrigé mon post. En fait on active les réseaux séparément (pas les caméras). Ca veut dire que si tu as 3 caméras et que tu veux les armer /désarmer chacune séparément, alors il faut que tu crées 3 réseaux
Ok, donc il faut 3 ponts, actuellement je tourne avec 2 ponts un pour les caméras intérieures un pour les caméras extérieures. Avant avec le plugin je pouvais désactiver le capteur de mouvement par caméra c’était top, j’essai de trouver une solution mais pas moyen.
