Bonjour, comme je disais avant, je suis passé sur une Raspberry Pi3 et un Jeedom 4, malgré l’inclusion d’un seul capteur, j’en ai 3, j’ai le même souci.
Voici les logs si cela peut aider :
[2019-12-17 21:19:17][DEBUG] : Message read from socket: {"apikey"xxxxxxx","cmd":"add","device":{"id":"0088C7AD","profils":[{"func":"06","type":"02","rorg":"a5","ignoreRelease":"","allButtons":""}]}}
[2019-12-17 21:19:17][DEBUG] : Add device : {u'id': u'0088C7AD', u'profils': [{u'rorg': u'a5', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'02', u'func': u'06'}]}
[2019-12-17 21:19:59][DEBUG] : Decode data : {"LRNB": {"value": "Data", "description": "Learn Bit", "unit": "", "raw_value": 1}, "repeat": "0", "dBm": "-79", "RS": {"value": "Range acc. to DB_1 (ILL1)", "description": "Range select", "unit": "", "raw_value": 0}, "rorg": "a5", "ILL": 8.0, "SVC": {"value": 0.13999999999999999, "description": "Supply voltage (linear)", "unit": "V", "raw_value": 7}, "ILL1": {"value": 8.0, "description": "Illumination 1 (linear)", "unit": "lx", "raw_value": 2}, "ILL2": {"value": 12.0, "description": "Illumination 2 (linear)", "unit": "lx", "raw_value": 6}, "packet_type": "1", "func": "06", "type": "02", "id": "0088C7AD", "manufacturer": "00"}
[2019-12-17 21:19:59][DEBUG] : Send to jeedom : {'devices': {'0088C7AD': {u'LRNB': {u'value': u'Data', u'description': u'Learn Bit', u'unit': u'', u'raw_value': 1}, 'repeat': '0', 'dBm': '-79', u'RS': {u'value': u'Range acc. to DB_1 (ILL1)', u'description': u'Range select', u'unit': u'', u'raw_value': 0}, 'rorg': u'a5', 'ILL': 8.0, u'SVC': {u'value': 0.13999999999999999, u'description': u'Supply voltage (linear)', u'unit': u'V', u'raw_value': 7}, u'ILL1': {u'value': 8.0, u'description': u'Illumination 1 (linear)', u'unit': u'lx', u'raw_value': 2}, u'ILL2': {u'value': 12.0, u'description': u'Illumination 2 (linear)', u'unit': u'lx', u'raw_value': 6}, 'packet_type': '1', 'func': u'06', 'type': u'02', 'id': '0088C7AD', 'manufacturer': '00'}}}
Ensuite j’ai testé avec une exclusion :
[2019-12-17 21:26:38][DEBUG] : Message read from socket: {"apikey":"ftMPjTTFXpnFfXkpfCrUHf1a4LtDjiON","cmd":"add","device":{"id":"0088C7AD","profils":[{"func":"06","type":"02","rorg":"a5","ignoreRelease":"","allButtons":""}]}}
[2019-12-17 21:26:38][DEBUG] : Add device : {u'id': u'0088C7AD', u'profils': [{u'rorg': u'a5', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'02', u'func': u'06'}]}
[2019-12-17 21:27:07][DEBUG] : Message read from socket: {"apikey":"ftMPjTTFXpnFfXkpfCrUHf1a4LtDjiON","cmd":"add","device":{"id":"0088C7AD","profils":[{"func":"06","type":"02","rorg":"a5","ignoreRelease":"","allButtons":""}]}}
[2019-12-17 21:27:07][DEBUG] : Add device : {u'id': u'0088C7AD', u'profils': [{u'rorg': u'a5', u'ignoreRelease': u'', u'allButtons': u'', u'type': u'02', u'func': u'06'}]}
[2019-12-17 21:31:38][DEBUG] : Send to jeedom : {'exclude_mode': 0, 'deviceId': '0088C7AD'}
[2019-12-17 21:31:38][DEBUG] : Decode data : {"LRNB": {"value": "Teach-In", "description": "Learn Bit", "unit": "", "raw_value": 0}, "repeat": "0", "dBm": "-92", "RS": {"value": "Range acc. to DB_1 (ILL1)", "description": "Range select", "unit": "", "raw_value": 0}, "rorg": "a5", "ILL": 44.0, "SVC": {"value": 0.4799999999999999, "description": "Supply voltage (linear)", "unit": "V", "raw_value": 24}, "ILL1": {"value": 44.0, "description": "Illumination 1 (linear)", "unit": "lx", "raw_value": 11}, "ILL2": {"value": 32.0, "description": "Illumination 2 (linear)", "unit": "lx", "raw_value": 16}, "packet_type": "1", "func": "06", "type": "02", "id": "0088C7AD", "manufacturer": "0b"}
[2019-12-17 21:31:38][DEBUG] : Send to jeedom : {'devices': {'0088C7AD': {u'LRNB': {u'value': u'Teach-In', u'description': u'Learn Bit', u'unit': u'', u'raw_value': 0}, 'repeat': '0', 'dBm': '-92', u'RS': {u'value': u'Range acc. to DB_1 (ILL1)', u'description': u'Range select', u'unit': u'', u'raw_value': 0}, 'rorg': u'a5', 'ILL': 44.0, u'SVC': {u'value': 0.4799999999999999, u'description': u'Supply voltage (linear)', u'unit': u'V', u'raw_value': 24}, u'ILL1': {u'value': 44.0, u'description': u'Illumination 1 (linear)', u'unit': u'lx', u'raw_value': 11}, u'ILL2': {u'value': 32.0, u'description': u'Illumination 2 (linear)', u'unit': u'lx', u'raw_value': 16}, 'packet_type': '1', 'func': u'06', 'type': u'02', 'id': '0088C7AD', 'manufacturer': '0b'}}}
Je récupère des valeurs cohérentes pour le moment mais ensuite ça renvoie 0lx.
J’ai 3 capteurs, pour le moment un seul est inclus mais les 2 autres ne peuvent ils pas perturber la communication ?
