J’ai peut être réussi à avoir le log grâce à Config-UI-X, en activant FFmpeg Debug Logging, et en récupérant le log . Pour info, la caméra salon1 provient de la configuration du plugin camera, et la caméra sous-sol est juste configuré avec -i http://freeboxcam:xxxxx@192.168.1.10/img/stream.m3u8
La finalité est la même pour les deux caméras
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra sous-sol] Snapshot requested: 1280 x 720
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra sous-sol] Snapshot command: ffmpeg -i http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8 -frames:v 1 -f image2 - -hide_banner -loglevel error
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra sous-sol] [Snapshot] http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra sous-sol] Fetching snapshot took 0.229 seconds.
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra sous-sol] Failed to fetch snapshot.
[Caméra sous-sol] Snapshot request handler provided empty image buffer!
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra salon1] Snapshot requested: 1280 x 720
[9/21/2023, 8:33:39 PM] [Camera FFmpeg] [Caméra salon1] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -i http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8 -frames:v 1 -f image2 - -hide_banner -loglevel error
[9/21/2023, 8:33:40 PM] [Camera FFmpeg] [Caméra salon1] [Snapshot] http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:33:40 PM] [Camera FFmpeg] [Caméra salon1] Fetching snapshot took 0.224 seconds.
[9/21/2023, 8:33:40 PM] [Camera FFmpeg] [Caméra salon1] Failed to fetch snapshot.
[Caméra salon1] Snapshot request handler provided empty image buffer!
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] Video stream requested: 1280 x 720, 30 fps, 299 kbps
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] Starting video stream: 1280 x 720, 30 fps, 299 kbps
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] Stream command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -i http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8 -an -sn -dn -codec:v libx264 -pix_fmt yuv420p -color_range mpeg -r 30 -f rawvideo -preset ultrafast -tune zerolatency -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease,scale=trunc(iw/2)*2:trunc(ih/2)*2 -b:v 299k -payload_type 99 -ssrc 9796996 -f rtp -srtp_out_suite AES_CM_128_HMAC_SHA1_80 -srtp_out_params EFxIWGhQ2Wj/N/R9JmGMQA+mkqXUToAAZQtnMS0d srtp://192.168.1.38:53302?rtcpport=53302&pkt_size=1316 -loglevel level+verbose -progress pipe:1
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] ffmpeg version 4.1.11-0+deb10u1 Copyright (c) 2000-2023 the FFmpeg developers
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] built with gcc 8 (Debian 8.3.0-6)
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] configuration: --prefix=/usr --extra-version=0+deb10u1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libavutil 56. 22.100 / 56. 22.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libavcodec 58. 35.100 / 58. 35.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libavformat 58. 20.100 / 58. 20.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libavdevice 58. 5.100 / 58. 5.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libavfilter 7. 40.101 / 7. 40.101
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libavresample 4. 0. 0 / 4. 0. 0
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libswscale 5. 3.100 / 5. 3.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libswresample 3. 3.100 / 3. 3.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [info] libpostproc 55. 3.100 / 55. 3.100
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [verbose] Routing option err_detect to both codec and muxer layer
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [tcp @ 0xaaaac615d980] [verbose] Starting connection attempt to 192.168.1.45 port 80
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [tcp @ 0xaaaac615d980] [verbose] Successfully connected to 192.168.1.45 port 80
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [http @ 0xaaaac615d1b0] [warning] HTTP error 401 Unauthorized
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] [error] http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] FFmpeg exited with code: 1 and signal: null (Error)
[9/21/2023, 8:33:47 PM] [Camera FFmpeg] [Caméra salon1] Stopped video stream.
[9/21/2023, 8:33:54 PM] [Camera FFmpeg] [Caméra sous-sol] Snapshot requested: 1280 x 720
[9/21/2023, 8:33:54 PM] [Camera FFmpeg] [Caméra sous-sol] Snapshot command: ffmpeg -i http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8 -frames:v 1 -f image2 - -hide_banner -loglevel error
[9/21/2023, 8:33:54 PM] [Camera FFmpeg] [Caméra sous-sol] [Snapshot] http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:33:54 PM] [Camera FFmpeg] [Caméra sous-sol] Fetching snapshot took 0.21 seconds.
[9/21/2023, 8:33:54 PM] [Camera FFmpeg] [Caméra sous-sol] Failed to fetch snapshot.
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra salon1] Snapshot requested: 1280 x 720
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra salon1] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -i http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8 -frames:v 1 -f image2 - -hide_banner -loglevel error
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra salon1] [Snapshot] http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra salon1] Fetching snapshot took 0.214 seconds.
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra salon1] Failed to fetch snapshot.
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] Video stream requested: 1280 x 720, 30 fps, 299 kbps
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] Starting video stream: 1280 x 720, 30 fps, 299 kbps
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] Stream command: ffmpeg -i http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8 -an -sn -dn -codec:v libx264 -pix_fmt yuv420p -color_range mpeg -r 30 -f rawvideo -preset ultrafast -tune zerolatency -filter:v scale='min(1280,iw)':'min(720,ih)':force_original_aspect_ratio=decrease,scale=trunc(iw/2)*2:trunc(ih/2)*2 -b:v 299k -payload_type 99 -ssrc 1789791 -f rtp -srtp_out_suite AES_CM_128_HMAC_SHA1_80 -srtp_out_params X/LhMI2VRIrOFt4uSojD8J31E2y374jQRuCCxLF4 srtp://192.168.1.38:57636?rtcpport=57636&pkt_size=1316 -loglevel level+verbose -progress pipe:1
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] ffmpeg version 4.1.11-0+deb10u1 Copyright (c) 2000-2023 the FFmpeg developers
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] built with gcc 8 (Debian 8.3.0-6)
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] configuration: --prefix=/usr --extra-version=0+deb10u1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libavutil 56. 22.100 / 56. 22.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libavcodec 58. 35.100 / 58. 35.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libavformat 58. 20.100 / 58. 20.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libavdevice 58. 5.100 / 58. 5.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libavfilter 7. 40.101 / 7. 40.101
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libavresample 4. 0. 0 / 4. 0. 0
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libswscale 5. 3.100 / 5. 3.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libswresample 3. 3.100 / 3. 3.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [info] libpostproc 55. 3.100 / 55. 3.100
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [tcp @ 0xaaaacf5c1980] [verbose] Starting connection attempt to 192.168.1.10 port 80
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [tcp @ 0xaaaacf5c1980] [verbose] Successfully connected to 192.168.1.10 port 80
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [http @ 0xaaaacf5c11b0] [warning] HTTP error 401 Unauthorized
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] [error] http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] FFmpeg exited with code: 1 and signal: null (Error)
[9/21/2023, 8:33:55 PM] [Camera FFmpeg] [Caméra sous-sol] Stopped video stream.
[9/21/2023, 8:34:00 PM] [Camera FFmpeg] [Caméra salon1] Snapshot requested: 1280 x 720
[9/21/2023, 8:34:00 PM] [Camera FFmpeg] [Caméra salon1] Snapshot command: ffmpeg -fflags +discardcorrupt+igndts -err_detect ignore_err -i http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8 -frames:v 1 -f image2 - -hide_banner -loglevel error
[9/21/2023, 8:34:00 PM] [Camera FFmpeg] [Caméra salon1] [Snapshot] http://freeboxcam:SsE+6naV@192.168.1.45/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra salon1] Fetching snapshot took 0.214 seconds.
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra salon1] Failed to fetch snapshot.
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra sous-sol] Snapshot requested: 1280 x 720
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra sous-sol] Snapshot command: ffmpeg -i http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8 -frames:v 1 -f image2 - -hide_banner -loglevel error
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra sous-sol] [Snapshot] http://freeboxcam:SsE+6naV@192.168.1.10/img/stream.m3u8: Server returned 401 Unauthorized (authorization failed)
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra sous-sol] Fetching snapshot took 0.432 seconds.
[9/21/2023, 8:34:01 PM] [Camera FFmpeg] [Caméra sous-sol] Failed to fetch snapshot.
