Sur la télécommande Lexman LEXK-5, les boutons I/O (On/Off) sont opérationnels.
@Loic, est-ce que le double/triple clic sur le On est possible avec le plugin ?
Pour la luminosité avec les fléches </> , cela remonte juste 1 ou 0 en retour.
A défaut de Binding, comment faire pour gérer l’augmentation ou diminution de la luminosité?
Une idée ?
Est-ce que quelqu’un a réussi a faire fonctionner l’anneau pour les couleurs et la température ?
A ce sujet, où puis-je trouver un tableau de correspondance RGB ?
@Loic as tu une idée pour le fonctionnement des 4 touches de présélection en haut ?
Merci d’avance
LEXK-5.pdf (4,8 Mo)
"ieee": "08:6b:d7:ff:fe:1b:d4:57",
"nwk": 46468,
"status": 2,
"lqi": "255",
"rssi": "-55",
"last_seen": "1614073327.0463676",
"node_descriptor": "02:40:80:77:12:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 2048,
"profile_id": 260,
"manufacturer": "ADEO",
"model": "LXEK-5",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 768,
"name": "Color Control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 40
"id": 2,
"name": "stack_version",
"value": 6
"id": 3,
"name": "hw_version",
"value": 2
"id": 4,
"name": "manufacturer",
"value": "ADEO"
"id": 5,
"name": "model",
"value": "LXEK-5"
"id": 6,
"name": "date_code",
"value": "20200426-12"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "2.8"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 29
"id": 33,
"name": "battery_percentage_remaining",
"value": 180
"id": 3,
"name": "Identify",
"attributes": []
"id": 2821,
"name": "Diagnostic",
"attributes": []
"id": 4096,
"attributes": []
"id": 64769,
"name": "Manufacturer Specific",
"attributes": []
"signature": {
"model": "LXEK-5",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4727,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
2821,
4096,
64769
3,
4,
6,
8,
25,
768,
4096
"class": "zigpy.device"
