Effectivement, il y a plusieurs sections d’aide, désolé…
J’ai mis un message au dessus le log _tuya.
Voici les infos du cloud Tuya:
Copie ecran devices:
Specification du device:
Request URL:
curl --request GET "https://openapi.tuyaeu.com/v1.0/iot-03/devices/bfe6fb87fedb0ba289jo57/specification" --header "sign_method: HMAC-SHA256" --header "client_id: 7fxypqhv8gsn5a5rmvda" --header "t: 1696246516971" --header "mode: cors" --header "Content-Type: application/json" --header "sign: 8CA90C62BD2CCC9EFBEE7F359C761F1D75A01E8447B63DDAAE5390FFB07379DD" --header "access_token: 0ebebfa9a301fc7a8fdf8911c523d702"
Response
"result": {
"category": "zndb",
"functions": [
"code": "event_clear",
"desc": "{}",
"name": "清除事件",
"type": "Boolean",
"values": "{}"
"status": [
"code": "fault",
"name": "过流故障上报",
"type": "Bitmap",
"values": "{\"label\":[\"ov_cr\",\"unbalance_alarm\",\"ov_vol\",\"undervoltage_alarm\",\"miss_phase_alarm\",\"outage_alarm\",\"magnetism_alarm\",\"terminal_alarm\",\"cover_alarm\",\"credit_alarm\",\"no_balance_alarm\",\"battery_alarm\",\"meter_hardware_alarm\"]}"
"code": "meter_id",
"name": "表号",
"type": "String",
"values": "{\"maxlen\":255}"
"name": "清除事件",
"type": "Boolean",
"values": "{}"
"success": true,
"t": 1696246517066,
"tid": "c279df50611711ee8665fe445e07f2df"
Sur la page cloud/development/devices, la borne apparait avec un libellé "standard instruction. Si je clique sur le lien, il semble qu’il y ai 2 possibilités standard ou DP. Ne faudrait il pas switcher le device sur DP instruction?
