Voila une erreur maintenant quand je relance une recherche de nouveau equipements:
Erreur sur Freebox_OS::FreeboxPUT() : Exception Object ( [message:protected] => [MySQL] Error code : 23000 (1062). Duplicate entry '938-Climatiseur (wifi)' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert [string:Exception:private] => [code:protected] => 0 [file:protected] => /var/www/html/core/class/DB.class.php [line:protected] => 120 [trace:Exception:private] => Array ( [0] => Array ( [file] => /var/www/html/core/class/DB.class.php [line] => 199 [function] => Prepare [class] => DB [type] => :: [args] => Array ( [0] => INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert [1] => Array ( [id] => [logicalId] => ether-28:6d:97:ab:3b:c8 [generic_type] => [eqType] => Freebox_OS [name] => Climatiseur (wifi) [order] => 0 [type] => info [subType] => binary [eqLogic_id] => 938 [isHistorized] => 0 [unite] => [configuration] => [] [template] => {"dashboard":"core::default","mobile":"core::default"} [display] => {"showStatsOnmobile":0,"showStatsOndashboard":0} [value] => [isVisible] => 1 [alert] => [] ) [2] => 0 ) ) [1] => Array ( [file] => /var/www/html/core/class/cmd.class.php [line] => 1102 [function] => save [class] => DB [type] => :: [args] => Array ( [0] => Freebox_OSCmd Object ( [id:protected] => [logicalId:protected] => ether-28:6d:97:ab:3b:c8 [generic_type:protected] => [eqType:protected] => Freebox_OS [name:protected] => Climatiseur (wifi) [order:protected] => [type:protected] => info [subType:protected] => binary [eqLogic_id:protected] => 938 [isHistorized:protected] => 0 [unite:protected] => [configuration:protected] => [template:protected] => Array ( [dashboard] => core::default [mobile] => core::default ) [display:protected] => Array ( [showStatsOnmobile] => 0 [showStatsOndashboard] => 0 ) [value:protected] => [isVisible:protected] => 1 [alert:protected] => [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => Freebox_OS Object ( [id:protected] => 938 [name:protected] => Appareils connectés [logicalId:protected] => network [generic_type:protected] => [object_id:protected] => 7 [eqType_name:protected] => Freebox_OS [isVisible:protected] => 1 [isEnable:protected] => 1 [configuration:protected] => {"autorefresh":"* * * * *","eq_group":"system","autorefresh_eqLogic":"*\/10 * * * *","createtime":"2023-08-26 22:20:15","logicalID":"network","updatetime":"2024-07-11 11:25:43","VersionLogicalID":"2.1","IPV4":"0","IPV6":"0","UpdateName":"0","UpdateVisible":"0"} [timeout:protected] => [category:protected] => {"default":"0","heating":"0","security":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"1"} [display:protected] => {"backGraph::info":0,"width":"152px","height":"140px"} [order:protected] => 26 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => [_cmds:protected] => Array ( ) ) [_needRefreshWidget:protected] => 1 [_needRefreshAlert:protected] => [_changed:protected] => 1 ) [1] => ) ) [2] => Array ( [file] => /var/www/html/plugins/Freebox_OS/core/class/Freebox_OS.class.php [line] => 475 [function] => save [class] => cmd [type] => -> [args] => Array ( ) ) [3] => Array ( [file] => /var/www/html/plugins/Freebox_OS/core/class/Free_CreateEq.class.php [line] => 805 [function] => AddCommand [class] => Freebox_OS [type] => -> [args] => Array ( [0] => Climatiseur [1] => ether-28:6d:97:ab:3b:c8 [2] => info [3] => binary [4] => Freebox_OS::Network [5] => [6] => [7] => 1 [8] => default [9] => default [10] => 0 [11] => [12] => 0 [13] => default [14] => default [15] => [16] => 0 [17] => [18] => 1 [19] => [20] => [21] => [22] => [23] => [24] => [25] => [26] => [27] => [28] => [29] => [30] => Array ( [updatename] => 1 [host_type] => networking_device [IPV4] => 192.168.1.163 [IPV6] => [mac_address] => 28:6D:97:AB:3B:C8 [order] => 104 [repeat] => 1 ) [31] => wifi ) ) [4] => Array ( [file] => /var/www/html/plugins/Freebox_OS/core/class/Free_CreateEq.class.php [line] => 72 [function] => createEq_network_SP [class] => Free_CreateEq [type] => :: [args] => Array ( [0] => Array ( [4GID] => 4G [4GName] => 4G [airmediaID] => airmedia [airmediaName] => Air Média [connexionID] => connexion [connexionName] => Freebox Débits [diskID] => disk [diskName] => Disque Dur [downloadsID] => downloads [downloadsName] => Téléchargements [freeplugID] => freeplug [freeplugName] => Freeplug [homeadaptersID] => homeadapters [homeadaptersName] => Home Adapters [LCDID] => LCD [LCDName] => Afficheur LCD [managementID] => management [managementName] => Gestion réseau [networkID] => network [networkName] => Appareils connectés [netshareID] => netshare [netshareName] => Partage Windows - Mac [networkwifiguestID] => networkwifiguest [networkwifiguestName] => Appareils connectés Wifi Invité [notificationID] => notification [notificationName] => Notification [phoneID] => phone [phoneName] => Téléphone [playerID] => player [playerName] => Player [systemID] => system [systemName] => Système [VMID] => VM [VMName] => VM [wifiID] => wifi [wifiName] => Wifi [wifiguestID] => wifiguest [wifiguestName] => Wifi Invité [wifimmac_filter] => Wifi Filtrage Adresse Mac [wifiWPSID] => wifiWPS [wifiWPSName] => Wifi WPS [wifiAPID] => wifiAP [wifiAPName] => Wifi Access Points ) [1] => core:: [2] => 104 [3] => LAN [4] => 1 ) ) [5] => Array ( [file] => /var/www/html/plugins/Freebox_OS/core/class/Free_Update.class.php [line] => 548 [function] => createEq [class] => Free_CreateEq [type] => :: [args] => Array ( [0] => network [1] => 1 ) ) [6] => Array ( [file] => /var/www/html/plugins/Freebox_OS/core/class/Free_Update.class.php [line] => 101 [function] => update_network [class] => Free_Update [type] => :: [args] => Array ( [0] => search [1] => other [2] => Freebox_OS Object ( [id:protected] => 938 [name:protected] => Appareils connectés [logicalId:protected] => network [generic_type:protected] => [object_id:protected] => 7 [eqType_name:protected] => Freebox_OS [isVisible:protected] => 1 [isEnable:protected] => 1 [configuration:protected] => Array ( [autorefresh] => * * * * * [eq_group] => system [autorefresh_eqLogic] => */10 * * * * [createtime] => 2023-08-26 22:20:15 [logicalID] => network [updatetime] => 2024-07-11 11:25:43 [VersionLogicalID] => 2.1 [IPV4] => 0 [IPV6] => 0 [UpdateName] => 0 [UpdateVisible] => 0 ) [timeout:protected] => [category:protected] => {"default":"0","heating":"0","security":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"1"} [display:protected] => {"backGraph::info":0,"width":"152px","height":"140px"} [order:protected] => 26 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => jeeObject Object ( [id:protected] => 7 [name:protected] => Multimédia [father_id:protected] => 2 [isVisible:protected] => 1 [position:protected] => 2 [configuration:protected] => {"parentNumber":1,"tagColor":"#000000","tagTextColor":"#FFFFFF","mobile::summaryTextColor":"","icon":"","hideOnDashboard":"0","hideOnOverview":"0","synthToAction":"synthToDashboard","synthToView":"1","info::type":"object","info::orientation":"0","info::space":"","useCustomColor":"0","useBackground":"0","summary::global::security":"1","summary::global::motion":"1","summary::global::door":"1","summary::global::windows":"1","summary::global::shutter":"1","summary::global::light":"1","summary::global::outlet":"1","summary::global::temperature":"1","summary::global::humidity":"1","summary::global::luminosity":"1","summary::global::power":"1","summary::global::piscine":"1","summary::global::chauffage":"1","summary::hide::desktop::security":"0","summary::hide::desktop::motion":"0","summary::hide::desktop::door":"0","summary::hide::desktop::windows":"0","summary::hide::desktop::shutter":"0","summary::hide::desktop::light":"0","summary::hide::desktop::outlet":"0","summary::hide::desktop::temperature":"0","summary::hide::desktop::humidity":"0","summary::hide::desktop::luminosity":"0","summary::hide::desktop::power":"0","summary::hide::desktop::piscine":"0","summary::hide::desktop::chauffage":"0","summary::hide::mobile::security":"0","summary::hide::mobile::motion":"0","summary::hide::mobile::door":"0","summary::hide::mobile::windows":"0","summary::hide::mobile::shutter":"0","summary::hide::mobile::light":"0","summary::hide::mobile::outlet":"0","summary::hide::mobile::temperature":"0","summary::hide::mobile::humidity":"0","summary::hide::mobile::luminosity":"0","summary::hide::mobile::power":"0","summary::hide::mobile::piscine":"0","summary::hide::mobile::chauffage":"0","summary":{"multimedia":[{"enable":"1","cmd":"#15945#","invert":"0"},{"enable":"1","cmd":"#6869#","invert":"0"},{"enable":"1","cmd":"#6895#","invert":"0"},{"enable":"1","cmd":"#6921#","invert":"0"},{"enable":"1","cmd":"#6843#","invert":"0"},{"enable":"1","cmd":"#3305#","invert":"0"},{"enable":"0","cmd":"#15969#","invert":"0"},{"enable":"1","cmd":"#11412#","invert":"0"},{"enable":"1","cmd":"#16018#","invert":"0"},{"enable":"1","cmd":"#15901#","invert":"0"},{"enable":"1","cmd":"#16062#","invert":"0"},{"enable":"1","cmd":"#15857#","invert":"0"}],"shutter":[],"light":[],"chauffage":[],"porte":[],"presence":[],"piscine":[],"outlet":[],"temperature":[],"humidity":[],"luminosity":[],"power":[]},"summary::global::presence":"0","summary::global::porte":"0","summary::global::multimedia":"1","summary::hide::desktop::presence":"0","summary::hide::desktop::porte":"0","summary::hide::desktop::multimedia":"0","summary::hide::mobile::presence":"0","summary::hide::mobile::porte":"0","summary::hide::mobile::multimedia":"0","summary_virtual_id":"1188","synthToPlan":"","synthToPlan3d":"","orderEqLogicByUsage::auto":"0"} [display:protected] => {"icon":"","tagColor":"#696969","tagTextColor":"#ebebeb"} [image:protected] => {"type":"webp","sha512":"ca379ac278498c66b9567ad6bed6666d630347a20d742c6c8383207def8729070497c419623e742caa1f0cc1b365864bd5b2fa55cc35cbe627056b338466692c","data":""} [_child:protected] => Array ( ) [_changed:protected] => [_summaryChanged:protected] => ) [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => [_cmds:protected] => Array ( ) ) [3] => Free_API Object ( [ErrorLoop:Free_API:private] => 0 [serveur:Free_API:private] => mafreebox.freebox.fr [app_id:Free_API:private] => plugin.freebox.jeedom [app_name:Free_API:private] => Plugin Freebox OS [app_version:Free_API:private] => v5.0.0 [device_name:Free_API:private] => Jeedom Delta [track_id:Free_API:private] => 1 [app_token:Free_API:private] => 8lv8i9X5n94ETB5GbCHTgtULUYvU8uOn2wbuF72Lefmg2meupayYV7kRBh86i+ii [API_version:Free_API:private] => v11 ) [4] => Array ( [user_login] => Alex43_b [user_id] => 2 ) [5] => network ) ) [7] => Array ( [file] => /var/www/html/plugins/Freebox_OS/core/class/Freebox_OS.class.php [line] => 280 [function] => UpdateAction [class] => Free_Update [type] => :: [args] => Array ( [0] => search [1] => other [2] => Rechercher les nouveaux appareils [3] => [4] => [5] => Freebox_OS Object ( [id:protected] => 938 [name:protected] => Appareils connectés [logicalId:protected] => network [generic_type:protected] => [object_id:protected] => 7 [eqType_name:protected] => Freebox_OS [isVisible:protected] => 1 [isEnable:protected] => 1 [configuration:protected] => Array ( [autorefresh] => * * * * * [eq_group] => system [autorefresh_eqLogic] => */10 * * * * [createtime] => 2023-08-26 22:20:15 [logicalID] => network [updatetime] => 2024-07-11 11:25:43 [VersionLogicalID] => 2.1 [IPV4] => 0 [IPV6] => 0 [UpdateName] => 0 [UpdateVisible] => 0 ) [timeout:protected] => [category:protected] => {"default":"0","heating":"0","security":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"1"} [display:protected] => {"backGraph::info":0,"width":"152px","height":"140px"} [order:protected] => 26 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => jeeObject Object ( [id:protected] => 7 [name:protected] => Multimédia [father_id:protected] => 2 [isVisible:protected] => 1 [position:protected] => 2 [configuration:protected] => {"parentNumber":1,"tagColor":"#000000","tagTextColor":"#FFFFFF","mobile::summaryTextColor":"","icon":"","hideOnDashboard":"0","hideOnOverview":"0","synthToAction":"synthToDashboard","synthToView":"1","info::type":"object","info::orientation":"0","info::space":"","useCustomColor":"0","useBackground":"0","summary::global::security":"1","summary::global::motion":"1","summary::global::door":"1","summary::global::windows":"1","summary::global::shutter":"1","summary::global::light":"1","summary::global::outlet":"1","summary::global::temperature":"1","summary::global::humidity":"1","summary::global::luminosity":"1","summary::global::power":"1","summary::global::piscine":"1","summary::global::chauffage":"1","summary::hide::desktop::security":"0","summary::hide::desktop::motion":"0","summary::hide::desktop::door":"0","summary::hide::desktop::windows":"0","summary::hide::desktop::shutter":"0","summary::hide::desktop::light":"0","summary::hide::desktop::outlet":"0","summary::hide::desktop::temperature":"0","summary::hide::desktop::humidity":"0","summary::hide::desktop::luminosity":"0","summary::hide::desktop::power":"0","summary::hide::desktop::piscine":"0","summary::hide::desktop::chauffage":"0","summary::hide::mobile::security":"0","summary::hide::mobile::motion":"0","summary::hide::mobile::door":"0","summary::hide::mobile::windows":"0","summary::hide::mobile::shutter":"0","summary::hide::mobile::light":"0","summary::hide::mobile::outlet":"0","summary::hide::mobile::temperature":"0","summary::hide::mobile::humidity":"0","summary::hide::mobile::luminosity":"0","summary::hide::mobile::power":"0","summary::hide::mobile::piscine":"0","summary::hide::mobile::chauffage":"0","summary":{"multimedia":[{"enable":"1","cmd":"#15945#","invert":"0"},{"enable":"1","cmd":"#6869#","invert":"0"},{"enable":"1","cmd":"#6895#","invert":"0"},{"enable":"1","cmd":"#6921#","invert":"0"},{"enable":"1","cmd":"#6843#","invert":"0"},{"enable":"1","cmd":"#3305#","invert":"0"},{"enable":"0","cmd":"#15969#","invert":"0"},{"enable":"1","cmd":"#11412#","invert":"0"},{"enable":"1","cmd":"#16018#","invert":"0"},{"enable":"1","cmd":"#15901#","invert":"0"},{"enable":"1","cmd":"#16062#","invert":"0"},{"enable":"1","cmd":"#15857#","invert":"0"}],"shutter":[],"light":[],"chauffage":[],"porte":[],"presence":[],"piscine":[],"outlet":[],"temperature":[],"humidity":[],"luminosity":[],"power":[]},"summary::global::presence":"0","summary::global::porte":"0","summary::global::multimedia":"1","summary::hide::desktop::presence":"0","summary::hide::desktop::porte":"0","summary::hide::desktop::multimedia":"0","summary::hide::mobile::presence":"0","summary::hide::mobile::porte":"0","summary::hide::mobile::multimedia":"0","summary_virtual_id":"1188","synthToPlan":"","synthToPlan3d":"","orderEqLogicByUsage::auto":"0"} [display:protected] => {"icon":"","tagColor":"#696969","tagTextColor":"#ebebeb"} [image:protected] => {"type":"webp","sha512":"ca379ac278498c66b9567ad6bed6666d630347a20d742c6c8383207def8729070497c419623e742caa1f0cc1b365864bd5b2fa55cc35cbe627056b338466692c","data":""} [_child:protected] => Array ( ) [_changed:protected] => [_summaryChanged:protected] => ) [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => [_cmds:protected] => Array ( ) ) [6] => Array ( [user_login] => Alex43_b [user_id] => 2 ) [7] => Freebox_OSCmd Object ( [id:protected] => 12834 [logicalId:protected] => search [generic_type:protected] => [eqType:protected] => Freebox_OS [name:protected] => Rechercher les nouveaux appareils [order:protected] => 0 [type:protected] => action [subType:protected] => other [eqLogic_id:protected] => 938 [isHistorized:protected] => 0 [unite:protected] => [configuration:protected] => Array ( [timeline::enable] => 0 [minValue] => [maxValue] => ) [template:protected] => {"dashboard":"core::line","mobile":"core::line"} [display:protected] => {"icon":"","forceReturnLineBefore":1,"forceReturnLineAfter":1,"showIconAndNamedashboard":1,"showIconAndNamemobile":1,"invertBinary":"0"} [value:protected] => [isVisible:protected] => 0 [alert:protected] => [] [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => Freebox_OS Object ( [id:protected] => 938 [name:protected] => Appareils connectés [logicalId:protected] => network [generic_type:protected] => [object_id:protected] => 7 [eqType_name:protected] => Freebox_OS [isVisible:protected] => 1 [isEnable:protected] => 1 [configuration:protected] => Array ( [autorefresh] => * * * * * [eq_group] => system [autorefresh_eqLogic] => */10 * * * * [createtime] => 2023-08-26 22:20:15 [logicalID] => network [updatetime] => 2024-07-11 11:25:43 [VersionLogicalID] => 2.1 [IPV4] => 0 [IPV6] => 0 [UpdateName] => 0 [UpdateVisible] => 0 ) [timeout:protected] => [category:protected] => {"default":"0","heating":"0","security":"0","energy":"0","light":"0","opening":"0","automatism":"0","multimedia":"1"} [display:protected] => {"backGraph::info":0,"width":"152px","height":"140px"} [order:protected] => 26 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => jeeObject Object ( [id:protected] => 7 [name:protected] => Multimédia [father_id:protected] => 2 [isVisible:protected] => 1 [position:protected] => 2 [configuration:protected] => {"parentNumber":1,"tagColor":"#000000","tagTextColor":"#FFFFFF","mobile::summaryTextColor":"","icon":"","hideOnDashboard":"0","hideOnOverview":"0","synthToAction":"synthToDashboard","synthToView":"1","info::type":"object","info::orientation":"0","info::space":"","useCustomColor":"0","useBackground":"0","summary::global::security":"1","summary::global::motion":"1","summary::global::door":"1","summary::global::windows":"1","summary::global::shutter":"1","summary::global::light":"1","summary::global::outlet":"1","summary::global::temperature":"1","summary::global::humidity":"1","summary::global::luminosity":"1","summary::global::power":"1","summary::global::piscine":"1","summary::global::chauffage":"1","summary::hide::desktop::security":"0","summary::hide::desktop::motion":"0","summary::hide::desktop::door":"0","summary::hide::desktop::windows":"0","summary::hide::desktop::shutter":"0","summary::hide::desktop::light":"0","summary::hide::desktop::outlet":"0","summary::hide::desktop::temperature":"0","summary::hide::desktop::humidity":"0","summary::hide::desktop::luminosity":"0","summary::hide::desktop::power":"0","summary::hide::desktop::piscine":"0","summary::hide::desktop::chauffage":"0","summary::hide::mobile::security":"0","summary::hide::mobile::motion":"0","summary::hide::mobile::door":"0","summary::hide::mobile::windows":"0","summary::hide::mobile::shutter":"0","summary::hide::mobile::light":"0","summary::hide::mobile::outlet":"0","summary::hide::mobile::temperature":"0","summary::hide::mobile::humidity":"0","summary::hide::mobile::luminosity":"0","summary::hide::mobile::power":"0","summary::hide::mobile::piscine":"0","summary::hide::mobile::chauffage":"0","summary":{"multimedia":[{"enable":"1","cmd":"#15945#","invert":"0"},{"enable":"1","cmd":"#6869#","invert":"0"},{"enable":"1","cmd":"#6895#","invert":"0"},{"enable":"1","cmd":"#6921#","invert":"0"},{"enable":"1","cmd":"#6843#","invert":"0"},{"enable":"1","cmd":"#3305#","invert":"0"},{"enable":"0","cmd":"#15969#","invert":"0"},{"enable":"1","cmd":"#11412#","invert":"0"},{"enable":"1","cmd":"#16018#","invert":"0"},{"enable":"1","cmd":"#15901#","invert":"0"},{"enable":"1","cmd":"#16062#","invert":"0"},{"enable":"1","cmd":"#15857#","invert":"0"}],"shutter":[],"light":[],"chauffage":[],"porte":[],"presence":[],"piscine":[],"outlet":[],"temperature":[],"humidity":[],"luminosity":[],"power":[]},"summary::global::presence":"0","summary::global::porte":"0","summary::global::multimedia":"1","summary::hide::desktop::presence":"0","summary::hide::desktop::porte":"0","summary::hide::desktop::multimedia":"0","summary::hide::mobile::presence":"0","summary::hide::mobile::porte":"0","summary::hide::mobile::multimedia":"0","summary_virtual_id":"1188","synthToPlan":"","synthToPlan3d":"","orderEqLogicByUsage::auto":"0"} [display:protected] => {"icon":"","tagColor":"#696969","tagTextColor":"#ebebeb"} [image:protected] => {"type":"webp","sha512":"ca379ac278498c66b9567ad6bed6666d630347a20d742c6c8383207def8729070497c419623e742caa1f0cc1b365864bd5b2fa55cc35cbe627056b338466692c","data":""} [_child:protected] => Array ( ) [_changed:protected] => [_summaryChanged:protected] => ) [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => [_cmds:protected] => Array ( ) ) [_needRefreshWidget:protected] => [_needRefreshAlert:protected] => [_changed:protected] => ) ) ) [8] => Array ( [file] => /var/www/html/core/php/jeeCron.php [line] => 87 [function] => FreeboxPUT [class] => Freebox_OS [type] => :: [args] => Array ( ) ) ) [previous:Exception:private] => )
