Bonjour @Doubledom
J’ai redémarré le plugin, voici le contenu de la log :
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47564]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"601702"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47564]
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47566]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"01A1A6FE"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47566]
[2023-11-10 12:39:10][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-11-10 12:39:10][DEBUG] : Add device : {'id': '601702'}
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47568]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"016E5F86"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47568]
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47570]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"4C6659"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47570]
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47572]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"6A45FA"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47572]
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47574]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"0200AD96"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47574]
[2023-11-10 13:39:10][INFO] : Démon RFXcom lancé
[2023-11-10 12:39:10][DEBUG] : Client connected to [127.0.0.1:47576]
[2023-11-10 12:39:10][DEBUG] : Message read from socket: b'{"apikey":"Hem1YHduhig04sYF1hVw1gcAaqdOI0E4","cmd":"add","device":{"id":"020D9CE2"}}'
[2023-11-10 12:39:10][DEBUG] : Client disconnected from [127.0.0.1:47576]
[2023-11-10 12:39:10][DEBUG] : Add device : {'id': '01A1A6FE'}
[2023-11-10 12:39:10][DEBUG] : Add device : {'id': '016E5F86'}
[2023-11-10 12:39:10][DEBUG] : Add device : {'id': '4C6659'}
[2023-11-10 12:39:11][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2023-11-10 12:39:11][DEBUG] : Add device : {'id': '6A45FA'}
[2023-11-10 12:39:11][DEBUG] : Add device : {'id': '0200AD96'}
[2023-11-10 12:39:11][DEBUG] : Add device : {'id': '020D9CE2'}
[2023-11-10 12:39:11][DEBUG] : msg3: [0, 0, 0, 0, 0, 0, 0, 0] / 00
[2023-11-10 12:39:11][DEBUG] : msg4: [0, 0, 0, 0, 0, 0, 0, 0] / 00
[2023-11-10 12:39:11][DEBUG] : msg5: [0, 0, 0, 0, 0, 1, 0, 1] / 05
[2023-11-10 12:39:11][DEBUG] : msg6: [0, 0, 0, 0, 0, 0, 0, 0] / 00
[2023-11-10 12:39:11][DEBUG] : Command: 0d00000203531C00000500000000
[2023-11-10 12:39:11][DEBUG] : Protocol actually activated 00000500
[2023-11-10 12:39:11][DEBUG] : Actual Frequency 53
[2023-11-10 12:39:11][DEBUG] : Wanted protocol 00000500
[2023-11-10 12:39:11][DEBUG] : All is ok, sending start
[2023-11-10 12:39:11][DEBUG] : Write data to serial port : 0d00000207000000000000000000
[2023-11-10 12:39:11][DEBUG] : Message: 1401070207436f7079726967687420524658434f4d
[2023-11-10 12:39:11][DEBUG] : Decode : 1401070207436f7079726967687420524658434f4d
[2023-11-10 12:39:11][DEBUG] : Test message: 1401070207436f7079726967687420524658434f4d
[2023-11-10 12:39:11][DEBUG] : PacketType: 0x01
[2023-11-10 12:39:11][DEBUG] : Length: 21
[2023-11-10 12:39:11][DEBUG] : Start decoding packet type 0x01
[2023-11-10 12:39:11][DEBUG] : Data : {'packetlen': '0x14', 'packettype': '0x01', 'subtype': '0x07', 'seqnbr': '0x02', 'cmnd': '0x07', 'msg1': '0x43', 'msg2': '0x6F', 'msg3': '0x70', 'msg4': '0x79', 'msg5': '0x72', 'msg6': '0x69', 'msg7': '0x67', 'msg8': '0x68', 'msg9': 116, 'msg10': '0x20', 'msg11': '0x52', 'msg12': '0x46', 'msg13': '0x58', 'msg14': '0x43', 'msg15': '0x4F', 'msg16': '0x4D'}
[2023-11-10 12:39:11][DEBUG] : Subtype = start RFXtrx receiver
Je vois bien tous mes volets dans les suites de messages « Message read from socket » :
Les Somfy : 601702 / 4C6659 / 6A45FA
Les Chacon IO : 01A1A6FE / 016E5F86 / 0200AD96 / 020D9CE2
Quand tu me dis faire un test avec un message de liste, je ne vois pas comment le faire, c’est depuis mon jeedom ou depuis rfxmngr ? Et comment ?
