Je partage mon expérience.
Je suis en Debian 11 jeedom 4.4.18 avec une ATLAS
J’avais plein d’erreurs et des pertes de communication avec mes modules :
error 2024-10-01 16:58:01zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:05:01zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:05:01zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:07:02zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:07:02zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:26:46zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:26:46zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:29:31zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:29:31zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:30:01zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:30:01zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:33:49zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:33:49zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
error 2024-10-01 17:35:02zh:ezsp:ezsp: Frame changeSourceRouteHandler parsing error: RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
error 2024-10-01 17:35:02zh:ezsp:ezsp: Unparsed frame 0xc4. Skipped
J’ai flashé le coordinateur zigbee interne à l’atlas en suivant cette procédure : Mise a jour firmware EZSP Atlas
(Quand j’ai cliqué sur Mise à jour du contrôleur, la fenêtre s’ouvre derrière. Il faut donc fermer la fenêtre "Configuration du plugin pour voir la fenêtre de mise à jour.
Tout s’est bien passé, je n’ai plus de message d’erreur, et il semble que le reseau est stable (a voir dans le temps)
