ZNCZ04LM : récupérer la température
Cette prise Xiaomi renvoie une valeur de la température, est-il possible de la remonter avec le plugin Zigbee ?
Merci pour votre réponse
    "ieee": "04:cf:8c:df:3c:7b:15:5a",
    "nwk": 64683,
    "status": 2,
    "lqi": "144",
    "rssi": "-64",
    "last_seen": "1641665835.2891903",
    "node_descriptor": "01:40:8e:5f:11:7f:64:00:00:2c:64:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "LUMI",
            "model": "lumi.plug.mmeu01",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "BasicCluster",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 22
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "LUMI"
                            "id": 5,
                            "name": "model",
                            "value": "lumi.plug.mmeu01"
                            "id": 6,
                            "name": "date_code",
                            "value": "09-06-2019"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 2,
                    "name": "Device Temperature",
                    "attributes": []
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 1
                    "id": 9,
                    "name": "Alarms",
                    "attributes": []
                    "id": 1794,
                    "name": "Metering",
                    "attributes": [
                            "id": 0,
                            "name": "current_summ_delivered",
                            "value": 398726
                    "id": 2820,
                    "name": "Electrical Measurement",
                    "attributes": [
                            "id": 1291,
                            "name": "active_power",
                            "value": 6.01200008392334
            "id": 21,
            "status": 1,
            "device_type": 9,
            "profile_id": 260,
            "manufacturer": null,
            "model": null,
                    "id": 12,
                    "name": "AnalogInput",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
            "input_clusters": [
                    "id": 12,
                    "name": "AnalogInputCluster",
                    "attributes": [
                            "id": 85,
                            "name": "present_value",
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4447,
            "maximum_buffer_size": 127,
            "maximum_incoming_transfer_size": 100,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 100,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    0,
                    2,
                    3,
                    4,
                    5,
                    6,
                    9,
                    1794,
                    2820
                    10,
                    25
            "21": {
                "profile_id": 260,
                "device_type": 9,
                "input_clusters": [
                    12
                    12,
                    4
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zhaquirks.xiaomi.aqara.plug_mmeu01"
Malheureusement non, zigpy ne l’intègre pas (et pour des raisons valable) donc on ne peut pas l’avoir dans jeedom. De toute facon la valeur est complètement fausse (c’est la valeur de température de la puce de la prise et non la température de la pièce)
Merci pour cette réponse.
