Salut les amis
Je me suis décidé à franchir le pas et utiliser ZigbeeLinker (version 2021-06-02 20:20:30) avec ma Conbee II. Plugin installé, dépendances construites, aucune erreur jusqu’à ce que…
J’ai bien suivi les conseils lors de l’install, à savoir « Réparer » puis « Reconstruire les dépendances » :
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://security.debian.org/debian-security stretch/updates InRelease
Ign:2 http://ftp.fr.debian.org/debian stretch InRelease
Hit:3 http://phoscon.de/apt/deconz stretch InRelease
Hit:4 http://ftp.fr.debian.org/debian stretch-updates InRelease
Hit:5 http://ftp.fr.debian.org/debian stretch Release
Hit:6 https://repo.mosquitto.org/debian stretch InRelease
Hit:8 https://deb.nodesource.com/node_14.x stretch InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:6.3.0-4).
gcc is already the newest version (4:6.3.0-4).
git is already the newest version (1:2.11.0-3+deb9u7).
make is already the newest version (4.1-9.1).
The following package was automatically installed and is no longer required:
libwebsockets8
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
##### Install or update NodeJs
NodeJs 14 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (2.0.11-0mosquitto1~stretch1).
libwebsockets8
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
##### Update : Download update from Zigbee2mqtt git
##### up to date
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
Voici aussi les logs du plugin en mode debug :
root@logger:~# tail -f /var/log/hosts/jeedom.log|grep -i mqtt
Jun 12 20:59:14 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/…/…/log/zigbee2mqtt_dep
Jun 12 20:59:15 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/…/…/log/zigbee2mqtt_dep
Jun 12 20:59:16 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 664 /var/www/html/core/class/…/…/log/zigbee2mqtt_dep
Jun 12 20:59:19 jeedom php[25713] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:19][INFO] : ############ Démarrage des service ############
Jun 12 20:59:19 jeedom php[25713] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:19][INFO] : Démon Version V2
Jun 12 20:59:19 jeedom php[25713] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:19][INFO] : ##### Démarrage du service ZigbeeLinker #####
Jun 12 20:59:19 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:19][INFO] : ##### Service ZigbeeLinker démarré #####
Jun 12 20:59:19 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:19][INFO] : ##### Démarrage du service MQTT #####
Jun 12 20:59:20 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:20][INFO] : ##### Démarrage du service MQTT terminé avec succès #####
Jun 12 20:59:20 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:20][INFO] : ##### Démarrage du service Client MQTT (Client MQTT Local) #####
Jun 12 20:59:21 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:21][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 1 seconde(s)
Jun 12 20:59:22 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:22][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 2 seconde(s)
Jun 12 20:59:23 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:23][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 3 seconde(s)
Jun 12 20:59:24 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:24][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 4 seconde(s)
Jun 12 20:59:25 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:25][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 5 seconde(s)
Jun 12 20:59:26 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:26][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 6 seconde(s)
Jun 12 20:59:27 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:27][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 7 seconde(s)
Jun 12 20:59:28 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:28][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 8 seconde(s)
Jun 12 20:59:29 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:29][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 9 seconde(s)
Jun 12 20:59:30 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:30][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 10 seconde(s)
Jun 12 20:59:31 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:31][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 11 seconde(s)
Jun 12 20:59:31 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:31][INFO] : ##### Impossible de démarrer le service Client MQTT (Client MQTT Local) #####
Jun 12 20:59:31 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 755 /var/www/html/plugins/zigbee2mqtt/core/class/…/…/data/zigbee2mqtt/configuration.yaml
Jun 12 20:59:31 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/chmod 644 /var/www/html/plugins/zigbee2mqtt/core/class/…/…/data/zigbee2mqtt/configuration.yaml
Jun 12 20:59:31 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/systemctl stop zigbee2mqtt
Jun 12 20:59:31 jeedom sudo: www-data : TTY=unknown ; PWD=/var/www/html/core/ajax ; USER=root ; COMMAND=/bin/systemctl disable zigbee2mqtt
Jun 12 20:59:31 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:31][INFO] : ##### Démarrage du service Zigbee2MQTT #####
Jun 12 20:59:31 jeedom sudo: www-data : TTY=unknown ; PWD=/opt/zigbee2mqtt ; USER=root ; ENV=ZIGBEE2MQTT_DATA=/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/ ; COMMAND=/usr/bin/npm start
Jun 12 20:59:32 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:32][INFO] : ##### Le service Zigbee2MQTT démarre… #####
Jun 12 20:59:32 jeedom php[6797] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:32][INFO] : ##### Le service zigbee2mqtt a démarré #####
Jun 12 20:59:45 jeedom php[30968] JEEDOM cron [2021-06-12 20:59:45][INFO] : Arrêt de zigbee2mqtt::deamon_client(), PID : 6925
Jun 12 20:59:46 jeedom php[30968] JEEDOM zigbee2mqtt [2021-06-12 20:59:46][DEBUG] : [Aucun][Client MQTT Local] : Cron remove for eqId : 677, cron name : deamon_client
Jun 12 20:59:46 jeedom php[30968] JEEDOM zigbee2mqtt [2021-06-12 20:59:46][DEBUG] : [Aucun][Client MQTT Local] : Cron create : deamon_client at * * * * *
Jun 12 20:59:46 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:46][INFO] : ##### Création du service Client MQTT (Client MQTT Local) #####
Jun 12 20:59:46 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:46][INFO] : ##### Démarrage du service Client MQTT (Client MQTT Local) #####
Jun 12 20:59:47 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:47][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 1 seconde(s)
Jun 12 20:59:48 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:48][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 2 seconde(s)
Jun 12 20:59:49 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:49][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 3 seconde(s)
Jun 12 20:59:50 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:50][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 4 seconde(s)
Jun 12 20:59:51 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:51][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 5 seconde(s)
Jun 12 20:59:52 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:52][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 6 seconde(s)
Jun 12 20:59:53 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:53][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 7 seconde(s)
Jun 12 20:59:54 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:54][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 8 seconde(s)
Jun 12 20:59:55 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:55][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 9 seconde(s)
Jun 12 20:59:56 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:56][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 10 seconde(s)
Jun 12 20:59:57 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:57][INFO] : ##### → Attent que le service Client MQTT (Client MQTT Local) démarre depuis 11 seconde(s)
Jun 12 20:59:57 jeedom php[30968] JEEDOM zigbee2mqtt_demon [2021-06-12 20:59:57][INFO] : ##### Impossible de démarrer le service Client MQTT (Client MQTT Local) #####
Jun 12 20:59:57 jeedom php[30968] JEEDOM zigbee2mqtt [2021-06-12 20:59:57][DEBUG] : [Aucun][Client MQTT Local] Refresh widget lancé
Avez-vous une idée de ce qui clocherait svp ?
Merci les amis
