Bonjour, je n’arrive pas à lancer le service zigbee2mqtt, que je tente d’installer sur rpi3B+.
Jai toujours cette erreur.
Quelqu’un aurait-il rencontré ce problème ?
Mar 19 19:18:47 zigbee2mqtt systemd[1]: zigbee2mqtt.service: Failed with result ‹ exit-code ›.
/opt/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:183
return new YAMLException(message, mark);
YAMLException: end of the stream or a document separator is expected (2:14)
1 | nano /opt/zigbee2mqtt/data/configuration.yaml …
2 | homeassistant: false
3 |
4 | # allow new devices to join
at generateError (/opt/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:183:10)
at throwError (/opt/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:187:9)
at readDocument (/opt/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1645:5)
at loadDocuments (/opt/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1688:5)
at Object.load (/opt/zigbee2mqtt/node_modules/js-yaml/lib/loader.js:1714:19)
at Object.read (/opt/zigbee2mqtt/lib/util/yaml.ts:7:21)
at read (/opt/zigbee2mqtt/lib/util/settings.ts:328:20)
at getInternalSettings (/opt/zigbee2mqtt/lib/util/settings.ts:433:21)
at Object.reRead (/opt/zigbee2mqtt/lib/util/settings.ts:716:5)
at start (/opt/zigbee2mqtt/index.js:91:14)
