BOnjour,
Suite à la MAJ du plugin plugin-zigbee2mqtt , celui est NOK.
J’ai relancé les dépendances mais cela ne change rien
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:3 http://phoscon.de/apt/deconz buster InRelease
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1+rpi2).
gcc is already the newest version (4:8.3.0-1+rpi2).
git is already the newest version (1:2.20.1-2+deb10u8).
make is already the newest version (4.2.1-1.2).
The following package was automatically installed and is no longer required:
libdav1d3
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
##### Install or update NodeJs
NodeJs 18 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (1.5.7-1+deb10u1).
libdav1d3
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
Removed /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service.
##### Repare Zigbee2MQTT
npm WARN using --force Recommended protections disabled.
## Supprime l'installation dans /opt/zigbee2mqtt
##### First installation : Download Zigbee2mqtt git
Cloning into '/opt/zigbee2mqtt'...
##### Install/Update Zigbee2mqtt
npm ERR! code ECONNRESET
npm ERR! errno ECONNRESET
npm ERR! network request to https://registry.npmjs.org/istanbul-reports/-/istanbul-reports-3.1.6.tgz failed, reason: socket hang up
npm ERR! network This is a problem related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settings.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly. See: 'npm help config'
npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-12-23T21_04_18_864Z-debug-0.log
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
J’ai fait les MAJ dede mon RPI au cas ou en SSH.
J’ai redemarré.
Mais rien y fait
Avez vous le même soucis?
Merci pour vos retours.
Cordialement
