Log Zigbeed_1
[2023-04-17 21:47:57][INFO] : Start zigbeed
[2023-04-17 21:47:57][INFO] : Log level : debug
[2023-04-17 21:47:57][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2023-04-17 21:47:57][INFO] : Device : /dev/ttyS2
[2023-04-17 21:47:57][INFO] : Apikey : CkZMQDHGZWWN8Zn46m4DS1yHxH8k7tyfRQU2BqQNVEAR4ppQNQtLF8wDkGTVXbOr
[2023-04-17 21:47:57][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2023-04-17 21:47:57][INFO] : Cycle : 0.3
[2023-04-17 21:47:57][INFO] : Controller : ezsp
[2023-04-17 21:47:57][INFO] : Channel : 15
[2023-04-17 21:47:57][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2023-04-17 21:47:57][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2023-04-17 21:47:57][INFO] : Folder OTA : None
[2023-04-17 21:47:57][INFO] : Zigpy advance configuration file : None
[2023-04-17 21:47:58][DEBUG] : SQLite version for <module 'sqlite3' from '/usr/lib/python3.7/sqlite3/__init__.py'>: 3.27.2
[2023-04-17 21:47:58][INFO] : Find device : /dev/ttyS2
[2023-04-17 21:47:59][INFO] : LOADER------Import de la configuration specifics.danfoss
[2023-04-17 21:47:59][INFO] : Writing PID 16621 to /tmp/jeedom/zigbee/deamon_1.pid
[2023-04-17 21:47:59][INFO] : Init request module v2.28.2
[2023-04-17 21:47:59][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2023-04-17 21:47:59][DEBUG] : http://127.0.0.1:80 "GET /plugins/zigbee/core/php/jeeZigbee.php?apikey=CkZMQDHGZWWN8Zn46m4DS1yHxH8k7tyfRQU2BqQNVEAR4ppQNQtLF8wDkGTVXbOr HTTP/1.1" 200 0
[2023-04-17 21:47:59][DEBUG] : Loading quirks module zhaquirks.innr.innr_sp120_plug
[2023-04-17 21:47:59][DEBUG] : Loading custom quirks module ts0601_valve_zgv1
[2023-04-17 21:47:59][INFO] : [start_zigbee] Init zigbee network with config : {'database_path': '/var/www/html/plugins/zigbee/data/1/network_ezsp.db', 'device': {'path': '/dev/ttyS2', 'baudrate': 115200}, 'network': {'channel': 15}, 'ezsp': {'CONFIG_APS_UNICAST_MESSAGE_COUNT': 12, 'CONFIG_SOURCE_ROUTE_TABLE_SIZE': 16, 'CONFIG_ADDRESS_TABLE_SIZE': 8}}
[2023-04-17 21:47:59][DEBUG] : executing <function aiosqlite_connect.<locals>.<lambda> at 0xffff8c69e488>
[2023-04-17 21:47:59][DEBUG] : operation <function aiosqlite_connect.<locals>.<lambda> at 0xffff8c69e488> completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA integrity_check', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA integrity_check', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method fetchall of sqlite3.Cursor object at 0xffff8b187730>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method fetchall of sqlite3.Cursor object at 0xffff8b187730>) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method close of sqlite3.Cursor object at 0xffff8b187730>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method close of sqlite3.Cursor object at 0xffff8b187730>) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b441b70>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b441b70>) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA journal_mode = WAL', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA journal_mode = WAL', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA synchronous = normal', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA synchronous = normal', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA temp_store = memory', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA temp_store = memory', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b104840>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b104840>) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA foreign_keys = ON', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA foreign_keys = ON', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA user_version', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA user_version', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method fetchone of sqlite3.Cursor object at 0xffff8b1712d0>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method fetchone of sqlite3.Cursor object at 0xffff8b1712d0>) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method close of sqlite3.Cursor object at 0xffff8b1712d0>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method close of sqlite3.Cursor object at 0xffff8b1712d0>) completed
[2023-04-17 21:47:59][DEBUG] : Current database version is v10
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'BEGIN TRANSACTION', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'BEGIN TRANSACTION', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'COMMIT', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'COMMIT', []) completed
[2023-04-17 21:47:59][DEBUG] : Loading application state
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM devices_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM devices_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method fetchmany of sqlite3.Cursor object at 0xffff8b187730>, 64)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method fetchmany of sqlite3.Cursor object at 0xffff8b187730>, 64) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM node_descriptors_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM node_descriptors_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM endpoints_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM endpoints_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM in_clusters_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM in_clusters_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM out_clusters_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM out_clusters_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method fetchmany of sqlite3.Cursor object at 0xffff8b171340>, 64)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method fetchmany of sqlite3.Cursor object at 0xffff8b171340>, 64) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method close of sqlite3.Cursor object at 0xffff8b171340>)
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method close of sqlite3.Cursor object at 0xffff8b171340>) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM attributes_cache_v10 WHERE attrid=4 OR attrid=5', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM attributes_cache_v10 WHERE attrid=4 OR attrid=5', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM attributes_cache_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM attributes_cache_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM unsupported_attributes_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM unsupported_attributes_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM groups_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM groups_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM group_members_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM group_members_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM relays_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM relays_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM neighbors_v10', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM neighbors_v10', []) completed
[2023-04-17 21:47:59][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM network_backups_v10 ORDER BY id', [])
[2023-04-17 21:47:59][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'SELECT * FROM network_backups_v10 ORDER BY id', []) completed
[2023-04-17 21:47:59][DEBUG] : Using selector: EpollSelector
[2023-04-17 21:47:59][DEBUG] : Resetting EZSP
[2023-04-17 21:48:00][DEBUG] : Resetting ASH
[2023-04-17 21:48:00][DEBUG] : Sending: b'1ac038bc7e'
[2023-04-17 21:48:05][ERROR] : Couldn't start application
File "/usr/local/lib/python3.7/dist-packages/zigpy/application.py", line 118, in startup
await self.connect()
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 134, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/__init__.py", line 107, in initialize
await ezsp._startup_reset()
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/__init__.py", line 98, in _startup_reset
await self.reset()
File "/usr/local/lib/python3.7/dist-packages/bellows/ezsp/__init__.py", line 127, in reset
await self._gw.reset()
File "/usr/local/lib/python3.7/dist-packages/bellows/uart.py", line 246, in reset
return await asyncio.wait_for(self._reset_future, timeout=RESET_TIMEOUT)
File "/usr/lib/python3.7/asyncio/tasks.py", line 423, in wait_for
raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
[2023-04-17 21:48:05][DEBUG] : Closed serial connection
[2023-04-17 21:48:05][DEBUG] : executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b0f3b70>)
[2023-04-17 21:48:05][DEBUG] : operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b0f3b70>) completed
[2023-04-17 21:48:05][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA wal_checkpoint;', [])
[2023-04-17 21:48:05][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0xffff8b12d030>, 'PRAGMA wal_checkpoint;', []) completed
[2023-04-17 21:48:05][DEBUG] : executing functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b104b70>)
[2023-04-17 21:48:05][DEBUG] : operation functools.partial(<function PersistingListener._set_isolation_level.<locals>.<lambda> at 0xffff8b104b70>) completed
[2023-04-17 21:48:05][DEBUG] : executing functools.partial(<built-in method close of sqlite3.Connection object at 0xffff8b12d030>)
[2023-04-17 21:48:05][DEBUG] : operation functools.partial(<built-in method close of sqlite3.Connection object at 0xffff8b12d030>) completed
[2023-04-17 21:48:05][ERROR] : [start_zigbee] Fatal error :
[2023-04-17 21:48:05][INFO] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py", line 102, in start_zigbee
start_radio=True,
File "/usr/local/lib/python3.7/dist-packages/zigpy/application.py", line 138, in new
await app.startup(auto_form=auto_form)
await self.reset()
[2023-04-17 21:48:05][INFO] : Shutdown
[2023-04-17 21:48:05][INFO] : Removing PID file /tmp/jeedom/zigbee/deamon_1.pid
[2023-04-17 21:48:05][INFO] : Exit 0
