Je m’auto-répond …
Le développer lixee suspecte une saturation du Lixee-Zlinky par le routage et propose un firmware ou la clé ne participe pas au routage ( no-router) https://github.com/fairecasoimeme/Zlinky_TIC/files/8901195/ZLinky_GpProxy_Ota_OM15081_V5.zip
Le nouveau module n’a pas le même nom mais la même taille et est aussi une V5
En mode debug
[2022-08-23 16:23:34][DEBUG] : APS data indication response: [35, <DeviceState.APSDE_DATA_REQUEST_SLOTS_AVAILABLE|2: 34>, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x0000>, 1, <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x3b33>, 1, 260, 25, b'\x01\x05\x01\x007\x10\x01\x00\x05\x00\x00\x00', 0, 175, 252, 15, 77, 0, 9, -84]
[2022-08-23 16:23:34][DEBUG] : [0x3B33:1:0x0019] Received ZCL frame: b'\x01\x05\x01\x007\x10\x01\x00\x05\x00\x00\x00'
[2022-08-23 16:23:34][DEBUG] : [0x3B33:1:0x0019] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, is_reply=0, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False), tsn=5, command_id=1, *is_reply=False)
[2022-08-23 16:23:34][DEBUG] : **[0x3B33:1:0x0019] Decoded ZCL frame: Ota:query_next_image(field_control=<FieldControl.0: 0>, manufacturer_code=4151, image_type=1, current_file_version=5)**
[2022-08-23 16:23:34][DEBUG] : [0x3B33:1:0x0019] Received command 0x01 (TSN 5): query_next_image(field_control=<FieldControl.0: 0>, manufacturer_code=4151, image_type=1, current_file_version=5)
[2022-08-23 16:23:34][INFO] : [00:15:8d:00:05:d2:a8:4f][listener.cluster_command] Cluster: <zigpy.zcl.clusters.general.Ota object at 0x7fb72a6de6d8> ClusterId: 0x0019 tsn: 5 args: (1, query_next_image(field_control=<FieldControl.0: 0>, manufacturer_code=4151, image_type=1, current_file_version=5))
[2022-08-23 16:23:34][INFO] : [00:15:8d:00:05:d2:a8:4f][listener.cluster_command] Use specific decode funtion of cluster id 25
[2022-08-23 16:23:34][INFO] : [00:15:8d:00:05:d2:a8:4f][chanels.general.Ota.cluster_command] Received command query_next_image
[2022-08-23 16:23:34][DEBUG] : **[0x3B33:1:0x0019] OTA query_next_image handler for 'LiXee ZLinky_TIC': field_control=FieldControl.0, manufacture_id=4151, image_type=1, current_file_version=5**, hardware_version=None, model=ZLinky_TIC
[2022-08-23 16:23:34][DEBUG] : executing functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fb72b016650>, 'UPDATE devices_v9 SET last_seen=? WHERE ieee=?', (1661264614.762655, 00:15:8d:00:05:d2:a8:4f))
[2022-08-23 16:23:34][DEBUG] : 'aps_data_indication' response from <DeconzAddress address_mode=ADDRESS_MODE.NWK address=0x3b33>, ep: 1, profile: 0x0104, cluster_id: 0x0019, data: b'010501003710010005000000'
[2022-08-23 16:23:34][DEBUG] : operation functools.partial(<built-in method execute of sqlite3.Connection object at 0x7fb72b016650>, 'UPDATE devices_v9 SET last_seen=? WHERE ieee=?', (1661264614.762655, 00:15:8d:00:05:d2:a8:4f)) completed
[2022-08-23 16:23:34][DEBUG] : executing functools.partial(<built-in method commit of sqlite3.Connection object at 0x7fb72b016650>)
[2022-08-23 16:23:34][DEBUG] : **[0x3B33:1:0x0019] OTA image version: 5, size: 240478. Update needed: False**
Ca se termine par « update need:false » et la mise à jour ne se fait pas .
C’est l’analyse que j’en fais , peut être que je me trompe …
Yannick
