Je teste le plugin ZIGBEE (avec une clef deconz) et je dispose de lampe IKEA.
Celles-ci sont bien reconnu lors de l’inclusion, mais le retour d’état, luminosité et intensité n marche pas vraiment ?
Aurais-raté une info ds la post global concernant ces équipements ?
La config brute si cela peut aider une ame charitable :
"ieee": "84:2e:14:ff:fe:7c:4a:42",
"nwk": 54263,
"status": 2,
"lqi": "255",
"rssi": "-55",
"last_seen": "1615551045.7707367",
"node_descriptor": "01:40:8e:7c:11:52:52:00:00:00:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 512,
"profile_id": 49246,
"manufacturer": "IKEA of Sweden",
"model": "TRADFRI bulb E27 CWS opal 600lm",
"output_clusters": [
"id": 5,
"name": "Scenes",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 1
"id": 1,
"name": "app_version",
"value": 17
"id": 2,
"name": "stack_version",
"value": 87
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "IKEA of Sweden"
"id": 5,
"name": "model",
"value": "TRADFRI bulb E27 CWS opal 600lm"
"id": 6,
"name": "date_code",
"value": "20170315"
"id": 7,
"name": "power_source",
"value": 1
"id": 16384,
"name": "sw_build_id",
"value": "1.3.002"
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 8,
"name": "Level control",
"attributes": [
"id": 0,
"name": "current_level",
"value": 211
"id": 768,
"name": "Color Control",
"attributes": [
"id": 3,
"name": "current_x",
"value": 30015
"id": 4,
"name": "current_y",
"value": 26870
"id": 2821,
"name": "Diagnostic",
"attributes": []
"id": 4096,
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4476,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 0,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"device_type": 512,
"input_clusters": [
0,
3,
4,
5,
6,
8,
768,
2821,
4096
5,
25,
32,
4096
"class": "zigpy.device"
}`Texte préformaté`
Ce qui m’étonne c’est que j’ai toujours
> "id": 6,
> "name": "On\/Off",
> "attributes": [
> "id": 0,
> "name": "on_off",
> "value": 1
quelque soit l’état de ma lampe (qui fonctionne sous DECONZ)
