Z2M - intégration Hue bloom
Arrivez-vous a intégrer les lampes à poser Hue bloom (product code 7299760PH) au travers de zigbee2mqtt ?
J’ ai réussit à l’intégrer 2 fois mais au bout d’une heure elle se déconnectait du réseau … mais maintenant je n’y arrive plus du tout … j’ai passé Z2M en mode debug mais je n’obtient pas grand chose
2023-05-10T15:53:39.455Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":1,"transid":58}
2023-05-10T15:53:39.455Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-05-10T15:53:41.150Z zigbee-herdsman:controller:device:log Interview - quirks check for 'undefined'-'undefined'-'Unknown'
2023-05-10T15:53:41.150Z zigbee-herdsman:controller:device:log Interview - quirks did not match
2023-05-10T15:53:41.150Z zigbee-herdsman:controller:device:log Interview - node descriptor request failed for '0x0017880103312ade', attempt 6
2023-05-10T15:53:41.212Z zigbee-herdsman:controller:device:log Interview - failed for device '0x0017880103312ade' with error 'Error: Interview failed because can not get node descriptor ('0x0017880103312ade')
    at Device.interviewInternal (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/model/device.ts:590:19)
    at Device.interview (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/model/device.ts:480:13)
    at Controller.onDeviceJoined (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:567:17)'
2023-05-10T15:53:41.212Z zigbee-herdsman:controller:database:log Writing database to '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db'
2023-05-10T15:53:41.223Z zigbee-herdsman:controller:error Interview failed for '0x0017880103312ade with error 'Error: Interview failed because can not get node descriptor ('0x0017880103312ade')'
Zigbee2MQTT:error 2023-05-10 17:53:41: Failed to interview '0x0017880103312ade', device has not successfully been paired
zlinky config: historique, single_phase, false, BASE
Zigbee2MQTT:info  2023-05-10 17:53:41: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0017880103312ade","ieee_address":"0x0017880103312ade","status":"failed"},"type":"device_interview"}'
2023-05-10T15:53:41.378Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,5,69,196,158,167,1,100,19,203]
2023-05-10T15:53:41.378Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,5,69,196,158,167,1,100,19,203]
2023-05-10T15:53:41.378Z zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 5 - 2 - 5 - 196 - [158,167,1,100,19] - 203
2023-05-10T15:53:41.379Z zigbee-herdsman:adapter:zStack:znp:AREQ <-- ZDO - srcRtgInd - {"dstaddr":42910,"relaycount":1,"relaylist":[4964]}
2023-05-10T15:53:41.379Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext []
2023-05-10T15:53:41.443Z zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,30,68,129,0,0,0,239,158,167,1,1,0,120,0,234,214,171,0,0,10,9,109,2,0,73,9,5,0,1,0,100,19,28,161]
2023-05-10T15:53:41.444Z zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,30,68,129,0,0,0,239,158,167,1,1,0,120,0,234,214,171,0,0,10,9,109,2,0,73,9,5,0,1,0,100,19,28,161]
Pas de soucis pour l’inclure sur le pont hue a la seule différence c’est que je dois le faire via le numéro de série et non un scan … étrange …
Je n’ai pas trouvé d’autres moyen que d’utiliser l’application HUE pour dissocier la lampe au pont (action effacer lumière)
ma conf Z2M
Version Zigbee2MQTT installée : 1.30.4 (votre versino de Zigbee2MQTT est à jour)
Version PHP installée : 7.4.33
Clef sonoff zigbee 3 Dongle plus
Une idée de par ou prendre le problème ?
@chris94440
Quelle version de la clé sonoff, E ou P?
Version du firmware?
A voir sur le guithub zigbee2mqtt si ils en parlent.
Merci pour ton support @Tonio16
Par contre je ne sais pas si c’est E ou P … je la trouve ou cette info ?
Non rien sur le github … j’ai aussi essayé avec une clef conbee2 … faut que je regarde la version…
Oui j’ai commencé à la parcourir … mais rien vu de flagrant … je vais y regarder de plus pres
Bon a priori c’est pas la dernière version … https://github.com/Koenkk/Z-Stack-firmware/tree/master/coordinator/Z-Stack_3.x.0/bin … v20221226…
Version P si zstack. Le nouveau firmware ne devrait rien changer car il resoud un problème si beaucoup de dispositifs.
Oui cest zstack …donc P
