Depuis plusieurs jours le démon Z-Wave ne démarre plus.
Voici les logs:
[2023-05-08 20:10:04]INFO : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device auto --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey xxxxxxxxx --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
File "/var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py", line 18, in
from ozwave import globals,server_utils,rest_server
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/server_utils.py", line 7, in
from jeedom.jeedom import *
File "/var/www/html/plugins/openzwave/resources/openzwaved/jeedom/jeedom.py", line 21, in
import requests
File "/usr/local/lib/python2.7/dist-packages/requests/__init__.py", line 48, in
from charset_normalizer import __version__ as charset_normalizer_version
File "/usr/local/lib/python2.7/dist-packages/charset_normalizer/__init__.py", line 24, in
from .api import from_bytes, from_fp, from_path
File "/usr/local/lib/python2.7/dist-packages/charset_normalizer/api.py", line 34
sequences: bytes,
SyntaxError: invalid syntax
J’ai MAJ os et python 2 et 3 mais rien y fait.
Je suis sous debian 10
Si qq’un peux me mettre sur une piste.
Merci,
Luc
