Voilà quelques logs:
[2021-06-28 12:03:32]DEBUG : Send to jeedom : {'devices': {'yeelight': {'ip': u'192.168.31.215', 'port': 55443, 'capabilities': {u'hue': u'360', u'color_mode': u'1', u'name': u'', u'power': u'off', u'support': u'get_prop set_default set_power toggle set_bright set_scene cron_add cron_get cron_del start_cf stop_cf set_name set_adjust adjust_bright set_ct_abx adjust_ct adjust_color set_rgb set_hsv set_music udp_sess_new udp_sess_keep_alive udp_chroma_sess_new', u'rgb': u'16712196', u'fw_ver': u'15', u'bright': u'21', u'model': u'strip6', u'ct': u'6375', u'id': u'0x00000000156f31a4', u'sat': u'99'}}}}
[2021-06-28 12:04:10]DEBUG : Message read from socket: {"apikey":"XXXXXX","type":"yeelight","cmd":"refresh","model":"strip6","dest":"192.168.31.215","token":"","devtype":"15","serial":"0x00000000156f31a4","id":"192.168.31.215"}
[2021-06-28 12:04:11]DEBUG : Bulb<192.168.31.215:55443, type=BulbType.Unknown> > {'params': ['power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'delayoff', 'music_on', 'name', 'bg_power', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode'], 'id': 0, 'method': 'get_prop'}
[2021-06-28 12:04:11]DEBUG : Bulb<192.168.31.215:55443, type=BulbType.Unknown> < {u'id': 0, u'result': [u'off', u'21', u'6375', u'16712196', u'360', u'99', u'1', u'0', u'0', u'0', u'', u'', u'', u'', u'', u'', u'', u'', u'', u'']}
[2021-06-28 12:04:11]DEBUG : Send to jeedom : {u'devices': {u'yeelight_192.168.31.215': {'ip': u'192.168.31.215', 'capabilities': {'delayoff': u'0', 'bright': u'21', 'id': u'192.168.31.215', 'sat': u'99', 'bg_hue': None, 'color_mode': u'1', 'rgb': u'16712196', 'flowing': u'0', 'bg_bright': None, 'ct': u'6375', 'bg_flowing': None, 'hue': u'360', 'power': u'off', 'music_on': u'0', 'bg_sat': None, 'active_mode': None, 'bg_ct': None, 'nl_br': None, 'bg_rgb': None, 'name': None, 'bg_power': None, 'current_brightness': u'21'}}}}
Pour, au final, ça
