Yeelight NOK chez moi mais pas le reste du plugin
J’ai un soucis depuis hier avec la partie yeelight du plugin (que j’adore, merci au(x) dev(s)), je relance le demon je peux piloter les ampoule moins d’une dizaine de secondes puis plus rien. Le demon n’a pas l’air de tomber car il reste au vert.
Je mets ci-dessous un bout des log en debug au moment où j’envoie des actions mais qu’il n’y pas de réponse des ampoules.
[2021-01-07 19:13:04][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-01-07 20:13:04][DEBUG] : Rafraîchissement de Yeelight : Bandeau Led
[2021-01-07 19:13:04][DEBUG] : Client connected to [127.0.0.1:44920]
[2021-01-07 19:13:04][DEBUG] : Message read from socket: {"apikey":"6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx","type":"yeelight","cmd":"refresh","model":"stripe","dest":"192.168.4.22","token":"","devtype":"73","serial":"0x0000000012c28f35","id":"192.168.4.22"}
[2021-01-07 19:13:04][DEBUG] : Client disconnected from [127.0.0.1:44920]
[2021-01-07 19:13:04][DEBUG] : http://127.0.0.1:80 "POST /plugins/xiaomihome/core/php/jeeXiaomiHome.php?apikey=6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx HTTP/1.1" 200 0
[2021-01-07 20:13:04][DEBUG] : Rafraîchissement de Yeelight : Grand œuf
[2021-01-07 19:13:04][DEBUG] : Client connected to [127.0.0.1:44922]
[2021-01-07 19:13:04][DEBUG] : Message read from socket: {"apikey":"6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx","type":"yeelight","cmd":"refresh","model":"color","dest":"192.168.4.23","token":"","devtype":"65","serial":"0x0000000007c49795","id":"192.168.4.23"}
[2021-01-07 19:13:04][DEBUG] : Client disconnected from [127.0.0.1:44922]
[2021-01-07 19:13:04][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2021-01-07 19:13:04][DEBUG] : Received command from jeedom : refresh
[2021-01-07 19:13:04][DEBUG] : Refreshing : color4
[2021-01-07 19:13:04][DEBUG] : Bulb<192.168.4.60:55443, type=BulbType.Unknown> > {'params': ['power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode', 'flowing', 'delayoff', 'music_on', 'name', 'bg_power', 'bg_flowing', 'bg_ct', 'bg_bright', 'bg_hue', 'bg_sat', 'bg_rgb', 'nl_br', 'active_mode'], 'id': 0, 'method': 'get_prop'}
[2021-01-07 20:13:08][DEBUG] : execute : action yeelight on
[2021-01-07 19:13:08][DEBUG] : Client connected to [127.0.0.1:44946]
[2021-01-07 19:13:08][DEBUG] : Message read from socket: {"apikey":"6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx","type":"yeelight","cmd":"send","dest":"192.168.4.23","model":"color","sid":"0x0000000007c49795","short_id":"65","command":"turn on","option":"","id":"192.168.4.23","sup":""}
[2021-01-07 19:13:08][DEBUG] : Client disconnected from [127.0.0.1:44946]
[2021-01-07 19:13:08][DEBUG] : {u'short_id': u'0', u'cmd': u'heartbeat', u'token': u'cf5ZbFw4roKHnWOk', u'sid': u'7811dc6c9420', u'model': u'gateway', u'data': u'{"ip":"192.168.4.24"}'}
[2021-01-07 19:13:08][DEBUG] : Send to jeedom : {u'devices': {u'aquara_7811dc6c9420': {'short_id': u'0', 'cmd': u'heartbeat', 'source': '192.168.4.24', 'token': u'cf5ZbFw4rxxxxxxxx', 'sid': u'7811dc6xxxxx', 'model': u'gateway', 'data': {u'ip': u'192.168.4.24'}}}}
[2021-01-07 19:13:08][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-01-07 19:13:08][DEBUG] : http://127.0.0.1:80 "POST /plugins/xiaomihome/core/php/jeeXiaomiHome.php?apikey=6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx HTTP/1.1" 200 0
[2021-01-07 20:13:10][DEBUG] : execute : action yeelight on
[2021-01-07 19:13:10][DEBUG] : Client connected to [127.0.0.1:44964]
[2021-01-07 19:13:10][DEBUG] : Message read from socket: {"apikey":"6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx","type":"yeelight","cmd":"send","dest":"192.168.4.23","model":"color","sid":"0x0000000007c49795","short_id":"65","command":"turn on","option":"","id":"192.168.4.23","sup":""}
[2021-01-07 19:13:10][DEBUG] : Client disconnected from [127.0.0.1:44964]
[2021-01-07 19:13:10][DEBUG] : Client connected to [127.0.0.1:44972]
[2021-01-07 19:13:10][DEBUG] : Client disconnected from [127.0.0.1:44972]
[2021-01-07 19:13:18][DEBUG] : {u'short_id': u'0', u'cmd': u'heartbeat', u'token': u'G7aqUgHLIJaVkcee', u'sid': u'7811dc6xxxxx', u'model': u'gateway', u'data': u'{"ip":"192.168.4.24"}'}
[2021-01-07 19:13:18][DEBUG] : Send to jeedom : {u'devices': {u'aquara_7811dc6xxxxx': {'short_id': u'0', 'cmd': u'heartbeat', 'source': '192.168.4.24', 'token': u'G7aqUgHLIJaxxxxx', 'sid': u'7811dc6xxxxx', 'model': u'gateway', 'data': {u'ip': u'192.168.4.24'}}}}
[2021-01-07 19:13:18][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-01-07 19:13:18][DEBUG] : http://127.0.0.1:80 "POST /plugins/xiaomihome/core/php/jeeXiaomiHome.php?apikey=6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx HTTP/1.1" 200 0
[2021-01-07 19:13:28][DEBUG] : {u'short_id': u'0', u'cmd': u'heartbeat', u'token': u'vwNzEN4394qxxxxx', u'sid': u'7811dc6xxxxx', u'model': u'gateway', u'data': u'{"ip":"192.168.4.24"}'}
[2021-01-07 19:13:28][DEBUG] : Send to jeedom : {u'devices': {u'aquara_7811dc6c9420': {'short_id': u'0', 'cmd': u'heartbeat', 'source': '192.168.4.24', 'token': u'vwNzEN4394qxxxxx', 'sid': u'7811dc6xxxxx', 'model': u'gateway', 'data': {u'ip': u'192.168.4.24'}}}}
[2021-01-07 19:13:28][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2021-01-07 19:13:28][DEBUG] : http://127.0.0.1:80 "POST /plugins/xiaomihome/core/php/jeeXiaomiHome.php?apikey=6jHDBM0aR7REURlkaL7fXWRaHgxxxxxx HTTP/1.1" 200 0
Quelqu’un pourrait m’aider à trouver un debut de piste pour retrouver le fonctionnement normal ?
Bonne soirée.
