Ce matin j’ai pu effectuer la MaJ vers la version 4.4.5 de Jeedom et depuis mes YeeLight ne sont plus pilotables.
J’ai pu collecter les logs ci-dessous :
[2024-04-29 14:28:28][DEBUG] : execute : action yeelight toggle
[2024-04-29 14:28:29][DEBUG] : Envoi : {"apikey":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","type":"yeelight","cmd":"send","dest":"192.168.1.28","model":"color","sid":"0x0000000002e05a9e","short_id":"76","command":"toggle","option":"","id":"192.168.1.28","sup":""}
[2024-04-29 14:28:29.348][DEBUG] : Client connected to [127.0.0.1:41214]
[2024-04-29 14:28:29.349][DEBUG] : Message read from socket: b'{"apikey":"XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX","type":"yeelight","cmd":"send","dest":"192.168.1.28","model":"color","sid":"0x0000000002e05a9e","short_id":"76","command":"toggle","option":"","id":"192.168.1.28","sup":""}'
[2024-04-29 14:28:29.349][DEBUG] : Client disconnected from [127.0.0.1:41214]
[2024-04-29 14:28:29.479][DEBUG] : SOCKET-READ------Message received in socket JEEDOM_SOCKET_MESSAGE
[2024-04-29 14:28:29.479][DEBUG] : SOCKET-READ------Received command from jeedom : send
[2024-04-29 14:28:29.480][DEBUG] : SOCKET-READ------Executing action on : color
[2024-04-29 14:28:29.480][DEBUG] : {'apikey': 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX', 'type': 'yeelight', 'cmd': 'send', 'dest': '192.168.1.28', 'model': 'color', 'sid': '0x0000000002e05a9e', 'short_id': '76', 'command': 'toggle', 'option': '', 'id': '192.168.1.28', 'sup': ''}
[2024-04-29 14:28:29.480][DEBUG] : Bulb<192.168.1.28:55443, type=BulbType.Unknown> > {'id': 0, 'method': 'toggle', 'params': ['smooth', 500]}
[2024-04-29 14:28:29.491][ERROR] : SOCKET-READ------Exception on socket : A socket error occurred when sending the command.
La problématique ne touche que les ampoules YeeLight. La gateway, les sensors et mes prises connectés Xiaomi répondent correctement.
Par acquis de conscience j’ai tenté le petit trick de changer la version de Python utilisé directement dans le fichier xiaomihome.class.php mais sans succès.
Je n’ai pas encore testé de charger un backup d’avant la MaJ je me dis que ce soucis pourrait peut être impacter d’autres personnes du coup autant en profiter pour tester des choses.
A votre dispo si besoin de plus de logs ou de faire des tests.
Bonne journée.
