Moi non plus je n’arrive pas à connecter aucun des 2 wifi de ma luna, ça ne détecte pas aucun réseau wifi.
Au début ça a marché, mais ensuite j’ai voulu installer le plugin docker… Pour des pb de manque d’espace disque j’ai supprimé le plugin docker, mais je pense que ça a fichu le bazar sur la configuration réseau du système, car désormais je n’ai plus aucun wifi…
santé OK, jeedom 4.4 à jour, je joins aussi quelques logs du plugin luna:
1099|[2024-11-04 21:30:24] DEBUG : save wifi >>sudo nmcli device wifi hotspot ssid "NicoLuna1" password "xxx" ifname wlan1 con-name Hotspot-wlan1
1100|[2024-11-04 21:30:26] DEBUG : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
1101|[2024-11-04 21:30:27] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"}]
1102|[2024-11-04 21:30:27] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"824e2d1e-a730-43c6-9011-0c2e24285dfa","name":"Hotspot-wlan1","type":"802-11-wireless","active":"no","device":"wlan1"}]
1103|[2024-11-04 21:30:27] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"824e2d1e-a730-43c6-9011-0c2e24285dfa","name":"Hotspot-wlan1","type":"802-11-wireless","active":"no","device":"wlan1"},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
1104|[2024-11-04 21:31:38] DEBUG : save wifi >>[{"id":"334","configuration":{"wifi2Enabled":"1","wifi2Mode":"hotspot","wifi2TypeAdressage":"","wifi2ip":"","wifi2mask":"","wifi2router":"","wifi2dns":"","wifi2dnsOpt":"","wifi2hotspotname":"","wifi2hotspotpwd":"","wifi2hotspotdhcp":"0","wifi2hotspotip":"","wifi2hotspotmask":"","wifi2Ssid":"","wifi2Password":""}}]
1105|[2024-11-04 21:31:38] DEBUG : save wifi >>hotspot
1106|[2024-11-04 21:31:38] DEBUG : clean wifi >>1
1107|[2024-11-04 21:31:39] DEBUG : save wifi >>sudo nmcli device wifi hotspot ssid "" password "" ifname wlan1 con-name Hotspot-wlan1
1108|[2024-11-04 21:31:39] DEBUG : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
1109|[2024-11-04 21:31:39] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"}]
1110|[2024-11-04 21:31:40] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
1111|[2024-11-04 21:31:43] DEBUG : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
1112|[2024-11-04 21:31:43] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"}]
1113|[2024-11-04 21:31:44] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
1114|[2024-11-04 21:31:47] DEBUG : save wifi >>[{"id":"334","configuration":{"wifi2Enabled":"1","wifi2Mode":"","wifi2TypeAdressage":"","wifi2ip":"","wifi2mask":"","wifi2router":"","wifi2dns":"","wifi2dnsOpt":"","wifi2hotspotname":"","wifi2hotspotpwd":"","wifi2hotspotdhcp":"0","wifi2hotspotip":"","wifi2hotspotmask":"","wifi2Ssid":"","wifi2Password":""}}]
1115|[2024-11-04 21:31:47] DEBUG : Wifi enabled : sudo nmcli -f SSID,SIGNAL,SECURITY,CHAN -t -m tabular dev wifi list ifname wlan-1
1116|[2024-11-04 21:31:47] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"}]
1117|[2024-11-04 21:31:47] DEBUG : [{"UUID":"b36b3dcc-e0e1-394a-b4f7-e4638932178f","name":"Wired connection 1","type":"802-3-ethernet","active":"yes","device":"eth0"},{"UUID":"","name":null,"type":null,"active":null,"device":""}]
1118|[2024-11-04 21:34:07] DEBUG : save priority >>["b36b3dcc-e0e1-394a-b4f7-e4638932178f"]
Je me connecte bien en ssh (via l’IP reseau RJ45) et je peux voir que les 2 wlan sont disconnected…
Est-ce que la version beta est corrigée, si oui je veux bien faire le test aussi
