Je viens d’équiper notre maison de vacances d’un alarme Somfy Home Alarm Plus Integral. Elle est installée et tout fonctionne à distance avec l’application Somfy protect.
Afin d’en contrôler l’état à distance, je voulais la connecter sur le Jeedom de ma résidence principale.
[2022-07-25 09:04:50.741]DEBUG : https://sso.myfox.io:443 "POST /oauth/oauth/v2/token HTTP/1.1" 400 None
[2022-07-25 09:04:50.745]DEBUG : Request to fetch token completed with status 400.
[2022-07-25 09:04:50.746]DEBUG : Request url was https://sso.myfox.io/oauth/oauth/v2/token
[2022-07-25 09:04:50.747]DEBUG : Request headers were {'User-Agent': 'Somfy Protect', 'Accept-Encoding': 'gzip, deflate', 'Accept': 'application/json', 'Connection': 'keep-alive', 'Content-Type': 'application/x-www-form-urlencoded;charset=UTF-8', 'Content-Length': '242'}
[2022-07-25 09:04:50.748]DEBUG : Request body was grant_type=password&client_id=#MONID#&client_secret=#MONSECRET#&username=#MONEMAIL#&password=#MONPASSWORD#
[2022-07-25 09:04:50.748]DEBUG : Response headers were {'Date': 'Mon, 25 Jul 2022 07:04:50 GMT', 'Content-Type': 'application/json', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'Server': 'openresty', 'Cache-Control': 'max-age=0, must-revalidate, private', 'Expires': 'Mon, 25 Jul 2022 07:04:50 GMT'} and content {"message":"error.too_many_failed_attempts","data":[],"uid":"62de4092adb6c"}.
[2022-07-25 09:04:50.749]DEBUG : Invoking 0 token response hooks.
[2022-07-25 09:04:50.749]ERROR : WebSocket connection Error(missing_token) Missing access token parameter.
[2022-07-25 09:04:50.749]INFO : Trying to reconnect in 25 seconds
[2022-07-25 09:05:15.772]INFO : Starting websocket
[2022-07-25 09:05:15.775]DEBUG : Obtention d'un nouveau token à partir du démon
[2022-07-25 09:05:15.777]DEBUG : Requesting url https://sso.myfox.io/oauth/oauth/v2/token using method POST.
[2022-07-25 09:05:15.778]DEBUG : Supplying headers {'Accept': 'application/json', 'Content-Type': 'application/x-www-form-urlencoded;charset=UTF-8'} and data {'grant_type': 'password', 'client_id': '#MONID#', 'client_secret': '#MONSECRET#', 'username': '#MONEMAIL#', 'password': '#MONPASSWORD#'}
[2022-07-25 09:05:15.779]DEBUG : Passing through key word arguments {'timeout': None, 'auth': None, 'verify': False, 'proxies': None, 'cert': None}.
[2022-07-25 09:05:15.785]DEBUG : Starting new HTTPS connection (1): sso.myfox.io:443
/usr/local/lib/python3.7/dist-packages/urllib3/connectionpool.py:1052: InsecureRequestWarning: Unverified HTTPS request is being made to host 'sso.myfox.io'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings
InsecureRequestWarning,
[2022-07-25 09:05:16.013]DEBUG : https://sso.myfox.io:443 "POST /oauth/oauth/v2/token HTTP/1.1" 400 None
[2022-07-25 09:05:16.014]DEBUG : Request to fetch token completed with status 400.
[2022-07-25 09:05:16.014]DEBUG : Request url was https://sso.myfox.io/oauth/oauth/v2/token
[2022-07-25 09:05:16.015]DEBUG : Request headers were {'User-Agent': 'Somfy Protect', 'Accept-Encoding': 'gzip, deflate', 'Accept': 'application/json', 'Connection': 'keep-alive', 'Content-Type': 'application/x-www-form-urlencoded;charset=UTF-8', 'Content-Length': '242'}
[2022-07-25 09:05:16.015]DEBUG : Request body was grant_type=password&client_id=#MONID#&client_secret=#MONSECRET#&username=#MONEMAIL#&password=#MONPASSWORD#
[2022-07-25 09:05:16.015]DEBUG : Response headers were {'Date': 'Mon, 25 Jul 2022 07:05:15 GMT', 'Content-Type': 'application/json', 'Transfer-Encoding': 'chunked', 'Connection': 'keep-alive', 'Server': 'openresty', 'Cache-Control': 'max-age=0, must-revalidate, private', 'Expires': 'Mon, 25 Jul 2022 07:05:15 GMT'} and content {"message":"error.too_many_failed_attempts","data":[],"uid":"62de40abf0b8b"}.
[2022-07-25 09:05:16.015]DEBUG : Invoking 0 token response hooks.
[2022-07-25 09:05:16.016]ERROR : WebSocket connection Error(missing_token) Missing access token parameter.
[2022-07-25 09:05:16.016]INFO : Trying to reconnect in 30 seconds
J’ai testé le plugin en version stable et beta. J’ai essayé de desinstaller le plugin puis réinstaller. Le dépendances ont été refaite à chaque changement.
Pour le log, le plugin est en Version 2022-07-02 13:28:18
Dans le log des dépendance,s il n’y pas d’erreur.
Merci d’avance pour votre aide !
