J’ai un souci avec des erreurs dans les logs depuis la mise a jour du plugin :
[2023-07-12 15:00:05][WARNING] : getTide Unable to get data.
[2023-07-12 16:00:05][WARNING] : getTide Unable to get data.
[2023-07-12 17:00:06][WARNING] : getTide Unable to get data.
[2023-07-12 18:00:03][WARNING] : getTide Unable to get data.
[2023-07-12 19:00:07][WARNING] : getTide Unable to get data.
[2023-07-12 20:00:04][WARNING] : getTide Unable to get data.
[2023-07-12 21:00:08][WARNING] : getTide Unable to get data.
[2023-07-12 22:00:07][WARNING] : getTide Unable to get data.
[2023-07-12 23:00:03][WARNING] : getMarine Unable to get data.
[2023-07-12 23:00:03][WARNING] : getTide Unable to get data.
[2023-07-12 23:00:04][WARNING] : getAlerts Unable to get data.
[2023-07-12 23:00:04][WARNING] : getBulletinFrance Unable to get data.
[2023-07-12 23:00:04][WARNING] : getBulletinSemaine Unable to get data.
[2023-07-12 23:00:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:00:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:00:05][WARNING] : getAlerts Unable to get data.
[2023-07-12 23:00:05][WARNING] : getBulletinFrance Unable to get data.
[2023-07-12 23:00:06][WARNING] : getBulletinSemaine Unable to get data.
[2023-07-12 23:05:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:05:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:10:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:10:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:15:05][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:15:05][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:20:03][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:20:03][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:25:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:25:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:30:05][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:30:05][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:35:03][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:35:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:40:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:40:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:45:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:45:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:50:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:50:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-12 23:55:04][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-12 23:55:04][WARNING] : getInstantsValues Unable to get data.
[2023-07-13 00:00:04][WARNING] : getMarine Unable to get data.
[2023-07-13 00:00:04][WARNING] : getTide Unable to get data.
[2023-07-13 00:00:05][WARNING] : getAlerts Unable to get data.
[2023-07-13 00:00:05][WARNING] : getEphemeris Unable to get data. Initializing sunrise and sunset commands
[2023-07-13 00:00:05][WARNING] : getBulletinFrance Unable to get data.
[2023-07-13 00:00:05][WARNING] : getBulletinSemaine Unable to get data.
[2023-07-13 00:00:05][WARNING] : getInstantsValues Unable to get data.
[2023-07-13 00:00:05][WARNING] : getHourlyDailyForecasts Unable to get data.
[2023-07-13 00:00:06][WARNING] : getAlerts Unable to get data.
[2023-07-13 00:00:06][WARNING] : getBulletinFrance Unable to get data.
[2023-07-13 00:00:06][WARNING] : getBulletinSemaine Unable to get data.
[2023-07-13 01:00:06][WARNING] : getTide Unable to get data.
[2023-07-13 02:00:04][WARNING] : getTide Unable to get data.
[2023-07-13 03:00:03][WARNING] : getTide Unable to get data.
[2023-07-13 04:00:03][WARNING] : getTide Unable to get data.
[2023-07-13 05:00:06][WARNING] : getTide Unable to get data.
[2023-07-13 06:00:04][WARNING] : getTide Unable to get data.
[2023-07-13 07:00:06][WARNING] : getTide Unable to get data.
[2023-07-13 08:00:04][WARNING] : getTide Unable to get data.
[2023-07-13 09:00:04][WARNING] : getTide Unable to get data.
[2023-07-13 09:01:20][WARNING] : getTide Unable to get data.
Pouvez-vous SVP me communiquer la localisation utilisée ?
J’ai essayé avec Toulon et il y a bien des données de marée qui sont récupérées. Même s’il n’y a pas un marnage important.
Il faudrait aussi passer le plugin en debug et fournir le contenu du fichier getTide-insee-ville.json dans le répertoire data du plugin lorsqu’il y a l’erreur.
Le fichier getTide-83137-Toulon.json que j’ai obtenu:
Merci,
J’ai dans Jeedom : configuration / général : indiqué mes coordonnées GPS et mon adresse dans la ville 83500 LA SEYNE SUR MER
J’ai passé le plugin en mode debug et voici les logs :
J’ai 2 équipents Meteo France : un ‹ ‹ LS › › basé sur les infos de « Config Jeedom » et un autre Vacances basé sur le plugin Geoloc pour la météo d’ou je suis quand je suis en vacances
Et voici les fichiers que j’ai dans les datadu plugin :
La valeur de geoloc d’équipement vacances est celle-ci
tout devrait etre ok pourtant ?
Je vais me répondre : j’ai ce message d’erreur dans le plugin geococ : cela ne fonctionne pas :
Votre dernière capture d’écran ressemble plus à un équipement du plugin geotrav « Localisation et trajet »
J’avais commencé à chercher sur la piste geoloc sans succés. Le plugin n’a jamais pu utiliser une localisation du plugin geoloc.
Vous êtes certain que c’est du geoloc ?
Avec cette localisation geotrav:
Le code postal et la ville sont nécessaires.
Ça fonctionne pour la météo:
Il n’y a pas de données pour les marées. Le contenu du fichier getTide-83126-La Seyne-sur-Mer.json :
{"error":400,"message":"Unknown ID"}
Je ne vois pas « La-seyne-sur-mer » sur le site METEO MARINE par Météo-France
Donc le message getTide Unable to get data est normal. Je regarderai comment le masquer dans une future version.
Si la météo ne s’affiche pas, vérifiez la configuration de votre geotrav.
Votre message "Google Maps Platform rejected " dans la localisation est normal. Il faut laisser un numéro de CB chez Google.
Je n’affiche pas les geotrav. Ils sont tous en Mode de configuration Manuel ( sans rien demander à Google )
Pas compris ce qui était trop beau ?
Pour moi, ça fonctionne. Le plugin ne peut pas inventer des données si MF ne les fournit pas ou ne répond pas aux requêtes.
Il y a juste un warning sans conséquence dans le log …
en je voudrais que lorsque je suis hors de chez moi je puisse avoir la météo de la ou je suis
Et comme avec Jeedom connect j’ai l’info de mes coordonnées GPS je pensais que ca pouvait marcher
mais tant pis
merci
Vous avez changé de sujet en cours de discussion sans me prévenir.
Désolé, mon neurone n’avait pas détecté ce changement. (cerf volant ou servo lent …)
Pour revenir au sujet de base, la météo de La-seyne-sur-mer fonctionne ou pas ?
Ce ne sont pas des erreurs mais des warnings.
Ils vont se produire dés que MF ne fournira pas une réponse attendue par le plugin.
Et cela quelque soit la fonction appelée. getTide, getMarine, getAlerts …
