Je ne crois pas avoir déjà vu ces warning, pas gênant en soi puisque warning mais du coup est-ce plus prudent de corriger dans les noms les caractères qui génèrent ces logs ? : ( ) +
3410|[12/10/2026 01:53:19] [HOMEBRIDGE] ┌──── Chambres > HOMEGIV (METEOINT) (317)
3411|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3412|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3413|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3414|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3415|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3416|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3417|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3418|HAP-NodeJS WARNING: The accessory 'HOMEGIV (METEOINT)' has an invalid 'Name' characteristic ('HOMEGIV (METEOINT)'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3419|[12/10/2026 01:53:19] [@nebz/homebridge-jeedom] This plugin generated a warning from the characteristic 'Carbon Dioxide Detected': Characteristic not in required or optional characteristic section for service AirQualitySensor. Adding anyway.. See https://homebridge.io/w/JtMGR for more info.
3420|[12/10/2026 01:53:19] [HOMEBRIDGE] │ OK : Mise à jour de l'accessoire (HOMEGIV (METEOINT))
3535|[12/10/2026 01:53:19] [HOMEBRIDGE] ┌──── Entrée > Présence J+1 (114)
3536|HAP-NodeJS WARNING: The accessory 'Présence J+1' has an invalid 'Name' characteristic ('Présence J+1'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3537|[12/10/2026 01:53:19] [HOMEBRIDGE] │ OK : Mise à jour de l'accessoire (Présence J+1)
3538|[12/10/2026 01:53:19] [HOMEBRIDGE] └─────────
3539|[12/10/2026 01:53:19] [HOMEBRIDGE] ┌──── Entrée > Présence Maison (456)
3540|HAP-NodeJS WARNING: The accessory 'Occupée à :' has an invalid 'Name' characteristic ('Occupée à :'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3541|HAP-NodeJS WARNING: The accessory 'Vide à :' has an invalid 'Name' characteristic ('Vide à :'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3542|[12/10/2026 01:53:19] [HOMEBRIDGE] │ OK : Mise à jour de l'accessoire (Présence Maison)
3543|[12/10/2026 01:53:19] [HOMEBRIDGE] └─────────
3544|[12/10/2026 01:53:19] [HOMEBRIDGE] ┌──── Entrée > Statut Florence (447)
3545|HAP-NodeJS WARNING: The accessory 'Départ :' has an invalid 'Name' characteristic ('Départ :'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3546|HAP-NodeJS WARNING: The accessory 'Arrivée :' has an invalid 'Name' characteristic ('Arrivée :'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3547|[12/10/2026 01:53:19] [HOMEBRIDGE] │ OK : Mise à jour de l'accessoire (Statut Florence)
3548|[12/10/2026 01:53:19] [HOMEBRIDGE] └─────────
3549|[12/10/2026 01:53:19] [HOMEBRIDGE] ┌──── Entrée > Statut François (446)
3550|HAP-NodeJS WARNING: The accessory 'Départ :' has an invalid 'Name' characteristic ('Départ :'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3551|HAP-NodeJS WARNING: The accessory 'Arrivée :' has an invalid 'Name' characteristic ('Arrivée :'). Please ensure the name starts and ends with a letter or number. Only letters, numbers, spaces, apostrophes, and common punctuation are supported. Avoid emojis or unsupported symbols. This may prevent the accessory from being added in the Home App or cause unresponsiveness.
3552|[12/10/2026 01:53:19] [HOMEBRIDGE] │ OK : Mise à jour de l'accessoire (Statut François)
