Warning avec Core en Alpha V4.5
J’ai des Warning qui apparaissent dans le log
0848|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1083
0849|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1083
0850|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1083
0851|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1084
0852|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1084
0853|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1085
0854|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1085
0855|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1092
0856|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1092
0857|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1092
0858|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1093
0859|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1093
0860|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1093
0861|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1097
0862|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1097
0863|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1097
0864|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1098
0865|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1098
0866|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1098
0867|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1099
0868|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1099
0869|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1099
0870|PHP Warning:  Undefined array key "hour +3" in /var/www/html/plugins/weather/core/class/weather.class.php on line 1100
0871|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1100
0872|PHP Warning:  Trying to access array offset on value of type null in /var/www/html/plugins/weather/core/class/weather.class.php on line 1100
J’ai vérifié mes coordonnées GPS dans l’équipement sont bien renseignés
Informations Jeedom
Core : 4.5 (alpha)
DNS Jeedom : oui
Plugin : Weather
Version : 2024-08-29 01:23:18 (beta)
A disposition pour toutes questions
Merci pour le retour ca sera corrigé dans la beta de demain du plugin
