Je viens de migrer sur le nouveau plugin Philips Hue et je remarque que mes modules Wall Switch, présentent parfois 2 boutons (normal) et certains 1 seul bouton (anormal).
Je précise que les modules concernés sont bien connectés à des boutons poussoirs doubles, configurés et fonctionnels sur le bridge.
Exemple:
2 boutons
1 bouton
J’ai essayé de:
- Synchroniser → KO
- Supprimer l’équipement puis synchroniser → KO
Voici l’état de santé :
Et la version:
[2024-01-15 10:08:10][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"199c2025-8769-4e23-965c-61935445ba5a","id_v1":"\/sensors\/23","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Corridor Office","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_single_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"2181bb1f-2ef6-4f25-9bbb-343e1d8f03ac","rtype":"zigbee_connectivity"},{"rid":"e32fb0d4-80f2-47b4-9db4-b8001a1f8be1","rtype":"button"},{"rid":"b43d0cec-dcb7-4ade-b49f-9e2ae0deefc4","rtype":"device_power"},{"rid":"0feb07de-48e6-4be5-8d20-a1d6f1bb48b6","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:11][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"5aa2b47a-45c7-493a-8db0-64aa3648a944","id_v1":"\/sensors\/26","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Toilet","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_single_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"90fb928b-4a9f-4892-b0d4-2b8d2e541600","rtype":"zigbee_connectivity"},{"rid":"d86ba503-a64a-4bd3-928b-b4d9ac758670","rtype":"button"},{"rid":"8eaadb3e-dedb-4f93-a9ef-e0233009fd0d","rtype":"device_power"},{"rid":"acb05e21-1722-432a-ab78-e412df2c5123","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:11][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"5c9895a3-649d-41e1-8d85-31391be4d396","id_v1":"\/sensors\/59","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Bedroom","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_dual_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"2afaacb8-56cf-41f3-b114-17b22055d2c1","rtype":"zigbee_connectivity"},{"rid":"aae36c41-8b41-4198-b273-76a863286676","rtype":"button"},{"rid":"805a51f1-990d-48ec-8da7-c43c05446c56","rtype":"button"},{"rid":"fecdb7e1-b189-4a2c-b2dd-0545099baa16","rtype":"device_power"},{"rid":"4ca30b1e-63f6-47a5-98a9-651d3eed9b46","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:12][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"8ab690fe-c2bb-4385-bfe4-3f2efa957949","id_v1":"\/sensors\/27","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Office","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_dual_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"65d1702e-bb1a-4a84-89cc-1bd15434ac9f","rtype":"zigbee_connectivity"},{"rid":"ac239f74-8590-41cc-a5e0-e1740af6d5f5","rtype":"button"},{"rid":"839321e6-f86e-4455-9b8e-4312ff9fe626","rtype":"device_power"},{"rid":"57d34fe9-6b32-4129-a0d4-6b43ca2d9f54","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:13][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"beacc814-8684-464c-af34-936474db5126","id_v1":"\/sensors\/25","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Hall","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_dual_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"0cea22bd-8e53-4fea-87a9-4b36b271b4f3","rtype":"zigbee_connectivity"},{"rid":"c700b181-bfe7-4e93-9a46-a1ae90f5c53e","rtype":"button"},{"rid":"1cfe9bba-715d-4b2b-b90d-98656ffca9bd","rtype":"button"},{"rid":"4876587d-ad8e-42b6-9375-e64dd5a8fb86","rtype":"device_power"},{"rid":"4600552f-faed-4f78-83cb-9fb6e77ca155","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:14][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"d7131e91-db47-41d2-8375-39169ead5c87","id_v1":"\/sensors\/22","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Corridor Hall","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_dual_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"e6c9baa1-b364-4634-9bad-75619f3e2042","rtype":"zigbee_connectivity"},{"rid":"e8708037-ef35-4257-8f90-6973df2e8818","rtype":"button"},{"rid":"1ded0bd3-7f85-4d6d-9a31-7a1e87c821f1","rtype":"device_power"},{"rid":"3e362b48-11de-4602-a126-848fb508f31e","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:14][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"dd6aced0-3b6b-4e4e-914f-80a4c432e294","id_v1":"\/sensors\/16","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Corridor Bathroom","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_single_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"e930dbb7-f3dd-4943-8658-21e18212c9c2","rtype":"zigbee_connectivity"},{"rid":"44b3eb6b-78e0-4e9b-9d3a-836787764d08","rtype":"button"},{"rid":"69c05c66-5795-421c-91a5-eae1a21ae908","rtype":"device_power"},{"rid":"4cdbf405-7c5b-478c-a11e-d8cca7853f5e","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:14][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"f1665e60-d515-4937-b080-4a51a534cae8","id_v1":"\/sensors\/35","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Bathroom","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_dual_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"67c522ba-c29c-4fc1-918c-954080de9a19","rtype":"zigbee_connectivity"},{"rid":"1e0d3da5-7147-4509-92f6-073389b38112","rtype":"button"},{"rid":"18ceaa5c-b9ea-453d-a71a-a0323ebb902c","rtype":"device_power"},{"rid":"ed13527a-f000-4ff8-8ba9-7b12dfb30e14","rtype":"device_software_update"}],"type":"device"}
[2024-01-15 10:08:14][DEBUG] : Found device type zigbee_connectivity model : RDM001 => {"id":"fc62821e-9b5c-4779-b1c4-a81f2fc121ce","id_v1":"\/sensors\/7","product_data":{"model_id":"RDM001","manufacturer_name":"Signify Netherlands B.V.","product_name":"Hue wall switch module","product_archetype":"unknown_archetype","certified":true,"software_version":"1.0.5","hardware_platform_type":"100b-11c"},"metadata":{"name":"Wall Switch Kitchen","archetype":"unknown_archetype"},"device_mode":{"status":"set","mode":"switch_dual_pushbutton","mode_values":["switch_single_rocker","switch_single_pushbutton","switch_dual_rocker","switch_dual_pushbutton"]},"services":[{"rid":"183ec550-bd53-4a98-8a3e-a81cdc9447f1","rtype":"zigbee_connectivity"},{"rid":"8b6d9473-bb4d-4ca0-91ef-5afa79cd536a","rtype":"button"},{"rid":"9f872276-2b03-49b0-b759-6c286c4d5a14","rtype":"button"},{"rid":"8d0d9d82-4872-49db-9199-da507fd3fcd7","rtype":"device_power"},{"rid":"699f1b28-d9aa-4206-8745-f73c1e2f0f9a","rtype":"device_software_update"}],"type":"device"}
Auriez-vous une idée sur la raison pour laquelle les commandes ne sont pas correctement créées ?
Merci pour votre aide !
