Il y a un soucis d’autorisation avec le plugin xiaomitalk et la version 4.2 du core Jeedom.
Je joint les log pour information.
0000|ffmpeg version 4.1.8-0+deb10u1 Copyright (c) 2000-2021 the FFmpeg developers
0001|built with gcc 8 (Debian 8.3.0-6)
0002|configuration: --prefix=/usr --extra-version=0+deb10u1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared
0003|WARNING: library configuration mismatch
0004|avcodec configuration: --prefix=/usr --extra-version=0+deb10u1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared --enable-version3 --disable-doc --disable-programs --enable-liblensfun --enable-libopencore_amrnb --enable-libopencore_amrwb --enable-libtesseract --enable-libvo_amrwbenc
0005|libavutil 56. 22.100 / 56. 22.100
0006|libavcodec 58. 35.100 / 58. 35.100
0007|libavformat 58. 20.100 / 58. 20.100
0008|libavdevice 58. 5.100 / 58. 5.100
0009|libavfilter 7. 40.101 / 7. 40.101
0010|libavresample 4. 0. 0 / 4. 0. 0
0011|libswscale 5. 3.100 / 5. 3.100
0012|libswresample 3. 3.100 / 3. 3.100
0013|libpostproc 55. 3.100 / 55. 3.100
0014|Vous n'êtes pas autorisé à effectuer cette action: No such file or directory
0000|[2021-11-16 08:29:37]DEBUG : Lancement commande : sudo nodejs /var/www/html/plugins/xiaomiTalk/core/class/../../resources/check.js 192.168.1.191 19585ea7f339ff2bddef32ed2bbb5fb8
0001|[2021-11-16 08:29:37]DEBUG : Lancement commande : sudo nodejs /var/www/html/plugins/xiaomiTalk/core/class/../../resources/check.js 192.168.1.191 19585ea7f339ff2bddef32ed2bbb5fb8
0002|[2021-11-16 08:29:38]INFO : Check passerelle : ok (Password=492E0D7E311A4145)
0003|[2021-11-16 08:29:40]INFO : Parle : Options:[Jeedom] Message de test - Message :Ceci est un test de message pour la commande Parle
0004|[2021-11-16 08:29:40]DEBUG : Valeurs par défaut : 10 fr-FR jeedom no
0005|[2021-11-16 08:29:40]DEBUG : Valeurs modifiées : 10 fr-FR jeedom no
0006|[2021-11-16 08:29:40]DEBUG : FFMPEG existe et c'est un exécutable, on l'utilise
0007|[2021-11-16 08:29:40]DEBUG : Jeedom audio location : Vous n'êtes pas autorisé à effectuer cette action
0008|[2021-11-16 08:29:40]DEBUG : Lancement Commande : sudo ffmpeg -y -i "Vous n'êtes pas autorisé à effectuer cette action" -c:a aac -b:a 64k /var/www/html/plugins/xiaomiTalk/core/class/../../resources/tts/tts_3399b73bc473fccc24c10201a812102a.aac >> /var/www/html/core/class/../../log/xiaomiTalk_convertAudio 2>&1
0009|[2021-11-16 08:29:40]WARNING : La phrase n'a pas pu être générée via jeedom, vérifiez le log xiaomiTalk_convertAudio en debug
0010|[2021-11-16 08:29:40]INFO : Check passerelle : ok (Password=492E0D7E311A4145)
0011|[2021-11-16 12:17:09]DEBUG : Lancement commande : sudo nodejs /var/www/html/plugins/xiaomiTalk/core/class/../../resources/check.js 192.168.1.191 19585ea7f339ff2bddef32ed2bbb5fb8
0012|[2021-11-16 12:17:09]DEBUG : Lancement commande : sudo nodejs /var/www/html/plugins/xiaomiTalk/core/class/../../resources/check.js 192.168.1.191 19585ea7f339ff2bddef32ed2bbb5fb8
0013|[2021-11-16 12:17:11]INFO : Parle : Options:[Jeedom] Message de test - Message :Ceci est un test de message pour la commande Parle
0014|[2021-11-16 12:17:11]DEBUG : Valeurs par défaut : 10 fr-FR jeedom no
0015|[2021-11-16 12:17:11]DEBUG : Valeurs modifiées : 10 fr-FR jeedom no
0016|[2021-11-16 12:17:11]DEBUG : FFMPEG existe et c'est un exécutable, on l'utilise
0017|[2021-11-16 12:17:11]DEBUG : Jeedom audio location : Vous n'êtes pas autorisé à effectuer cette action
0018|[2021-11-16 12:17:11]DEBUG : Lancement Commande : sudo ffmpeg -y -i "Vous n'êtes pas autorisé à effectuer cette action" -c:a aac -b:a 64k /var/www/html/plugins/xiaomiTalk/core/class/../../resources/tts/tts_3399b73bc473fccc24c10201a812102a.aac >> /var/www/html/core/class/../../log/xiaomiTalk_convertAudio 2>&1
0019|[2021-11-16 12:17:11]INFO : Check passerelle : ok (Password=492E0D7E311A4145)
0020|[2021-11-16 12:17:11]WARNING : La phrase n'a pas pu être générée via jeedom, vérifiez le log xiaomiTalk_convertAudio en debug
0021|[2021-11-16 12:17:12]INFO : Check passerelle : Erreur : timeout
Système à jour OK Cron actif OK
Scénario actif OK Démarré OK 2021-09-25 12:18:02
Date système (dernière heure enregistrée) OK 2021-11-16 12:18:16 (2021-11-16 11:48:02) Droits sudo OK
Version Jeedom 4.2.5 Version OS debian 10.11
Version PHP 7.3.31-1~deb10u1 Apache 11
Version OS Linux odroidn2 5.10.21-meson64 #21.02.3 SMP PREEMPT Mon Mar 8 07:22:00 UTC 2021 aarch64 GNU/Linux [10.11] Version database 10.3.31-MariaDB-0+deb10u1
Espace disque libre 66 % Espace disque libre tmp 100 %
Mémoire disponible 80 % (Total 3633 Mo) Mémoire suffisante 0
Erreur I/O 0 Swap disponible 100 % (Total 1816 Mo)
Swapiness 100 % Charge 0.19 - 0.12 - 0.05
Configuration réseau interne OK Configuration réseau externe OK
Persistance du cache OK (2021-11-16 12:00:02) Apache private tmp OK
Plugins OK
