Lorsque j’essaye d’accéder à Jeedom en https depuis mon mobile depuis quelque jours j’ai :
NET::ERR_CERT_DATE_INVALID
Je me suis alors connecté via putty sur mon Raspberry pi3 et j’ai effectué la commande :
sudo certbot renew
Je ne sais pas si cela est important mais j’ai ceci :
pi@jeedom:~ $ sudo certbot renew
File "/snap/certbot/4194/bin/certbot", line 5, in <module>
from certbot.main import main
File "/snap/certbot/4194/lib/python3.12/site-packages/certbot/main.py", line 6, in <module>
from certbot._internal import main as internal_main
File "/snap/certbot/4194/lib/python3.12/site-packages/certbot/_internal/main.py", line 20, in <module>
import josepy as jose
File "/snap/certbot/4194/lib/python3.12/site-packages/josepy/__init__.py", line 40, in <module>
from josepy.json_util import (
File "/snap/certbot/4194/lib/python3.12/site-packages/josepy/json_util.py", line 24, in <module>
from OpenSSL import crypto
File "/snap/certbot/4194/lib/python3.12/site-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import SSL, crypto
File "/snap/certbot/4194/lib/python3.12/site-packages/OpenSSL/SSL.py", line 11, in <module>
from OpenSSL._util import (
File "/snap/certbot/4194/lib/python3.12/site-packages/OpenSSL/_util.py", line 6, in <module>
from cryptography.hazmat.bindings.openssl.binding import Binding
File "/snap/certbot/4194/lib/python3.12/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 15, in <module>
from cryptography.exceptions import InternalError
File "/snap/certbot/4194/lib/python3.12/site-packages/cryptography/exceptions.py", line 9, in <module>
from cryptography.hazmat.bindings._rust import exceptions as rust_exceptions
RuntimeError: OpenSSL 3.0's legacy provider failed to load. This is a fatal error by default, but cryptography supports running without legacy algorithms by setting the environment variable CRYPTOGRAPHY_OPENSSL_NO_LEGACY. If you did not expect this error, you have likely made a mistake with your OpenSSL configuration.
Et j’ai toujours l’avertissement comme quoi la connexion n’est pas privé quand je veux acceder en https.
De plus je suis étonné de ce renouvellement car de ce que j’ai pu lire qu’il doit être fait tout les 90 jours alors que cela fait plusieurs années que je n’ai pas eu besoin de faire un renouvellement de certificat.
Merci par avance si quelqu’un peut apporter des éclaircissements ![]()
