Avec la version bêta de Mqtt Manager du 2023-07-26 01:19:46 le démon ne veut pas se lancer.
0020|[2023-07-26 10:34:47]INFO : Démarrage du démon MQTT Manager : sudo /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.1.94:1883 --username blablabla --password blablablabla --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey blablablabla --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
0021|[2023-07-26 10:35:17]ERROR : Impossible de démarrer le démon MQTT Manager, vérifiez les logs
0262|node:internal/modules/cjs/loader:1031
0263|throw err;
0264|^
0265|Error: Cannot find module 'axios'
0266|Require stack:
0267|- /var/www/html/plugins/mqtt2/resources/mqtt2d/jeedom/jeedom.js
0268|- /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js
0269|at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1028:15)
0270|at Function.Module._load (node:internal/modules/cjs/loader:873:27)
0271|at Module.require (node:internal/modules/cjs/loader:1100:19)
0272|at require (node:internal/modules/cjs/helpers:108:18)
0273|at Object. (/var/www/html/plugins/mqtt2/resources/mqtt2d/jeedom/jeedom.js:17:15)
0274|at Module._compile (node:internal/modules/cjs/loader:1198:14)
0275|at Object.Module._extensions..js (node:internal/modules/cjs/loader:1252:10)
0276|at Module.load (node:internal/modules/cjs/loader:1076:32)
0277|at Function.Module._load (node:internal/modules/cjs/loader:911:12)
0278|at Module.require (node:internal/modules/cjs/loader:1100:19) {
0279|code: 'MODULE_NOT_FOUND',
0280|requireStack: [
0281|'/var/www/html/plugins/mqtt2/resources/mqtt2d/jeedom/jeedom.js',
0282|'/var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js'
0283|]
0284|}
