[2024-03-01 20:18:00][INFO] : ---------------------------------------------
[2024-03-01 20:18:00][INFO] : [découverte MQTT] Exécution du service : nice -n 19 /var/www/html/plugins/teleinfo/ressources/venv/bin/python3 /var/www/html/plugins/teleinfo/ressources/teleinfo_mqtt.py --socketport 55064 --mqtt True --mqtt_broker 127.0.0.1 --mqtt_port 1883 --apikey Gsi7f2bqFxGEHlKMc0QZ2BK2tI5Anb2p --mqtt_keepalive 45 --mqtt_username admin --mqtt_password &Rjc1981! --modem aucun --callback http://127.0.0.1:80/plugins/teleinfo/core/php/jeeTeleinfo.php --loglevel debug --mqtt_topic "#"
[2024-03-01 20:18:02][DEBUG] : calculatepapp
[2024-03-01 20:18:02][DEBUG] : Pas de calcul
[2024-03-01 20:18:02][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:02][DEBUG] : HCHP=016457607|device=031961382662|
[2024-03-01 20:18:02][INFO] : [découverte Mqtt] Vérification de l'état du service de découverte MQTT : NOK
[2024-03-01 20:18:04][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:04][DEBUG] : PAPP=00590|device=031961382662|
[2024-03-01 20:18:07][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:07][DEBUG] : HCHP=016457608|device=031961382662|
[2024-03-01 20:18:10][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:10][DEBUG] : PAPP=00580|device=031961382662|
[2024-03-01 20:18:12][INFO] : [découverte Mqtt] Vérification de l'état du service de découverte MQTT : NOK
[2024-03-01 20:18:12][ERROR] : [TELEINFO_mqtt] Impossible de lancer le démon téléinfo, vérifiez la configuration.
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:12][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:12][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 20:18:13][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:13][DEBUG] : HCHP=016457609|IINST=004|PAPP=00910|device=031961382662|
[2024-03-01 20:18:16][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:16][DEBUG] : IINST=007|PAPP=01450|device=031961382662|
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:17][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:17][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 20:18:19][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:19][DEBUG] : HCHP=016457611|device=031961382662|
[2024-03-01 20:18:22][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:22][DEBUG] : HCHP=016457612|IINST=003|PAPP=00590|device=031961382662|
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:22][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:22][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:23][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:23][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:27][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:27][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:28][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:28][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 20:18:28][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:28][DEBUG] : HCHP=016457613|PAPP=00580|device=031961382662|
[2024-03-01 20:18:31][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:31][DEBUG] : PAPP=00590|device=031961382662|
[2024-03-01 20:18:33][DEBUG] : This is a message from teleinfo program 031961382662
[2024-03-01 20:18:33][DEBUG] : HCHP=016457614|device=031961382662|
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 20:18:34][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 20:18:34][DEBUG] : [TELEINFO_deamon] état global => retour: nok
Je trouve ceci: [2024-03-01 20:19:19][INFO] : [découverte Mqtt] Vérification de l'état du service de découverte MQTT : NOK
Coté MQTT tout est ok mais je n’ai pas teleinfo en plugin abonné
+ touch /tmp/jeedom_install_in_progress_teleinfo
+ echo 1
+ echo 2
+ sudo chmod +x /var/www/html/core/class/../../plugins/teleinfo/ressources/post-install.sh
+ sudo /var/www/html/core/class/../../plugins/teleinfo/ressources/post-install.sh
Fri Mar 1 21:06:04 CET 2024
* Installation des dépendances *
Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
Hit:2 http://deb.debian.org/debian bullseye InRelease
Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
Hit:4 http://phoscon.de/apt/deconz bullseye InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
Calculating upgrade...
The following packages have been kept back:
linux-image-amd64
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Fri Mar 1 21:06:06 CET 2024
libxml2-dev is already the newest version (2.9.10+dfsg-6.7+deb11u4).
libxslt1-dev is already the newest version (1.1.34-4+deb11u1).
python3 is already the newest version (3.9.2-3).
python3-pip is already the newest version (20.3.4-4+deb11u1).
python3-dev is already the newest version (3.9.2-3).
python3-venv is already the newest version (3.9.2-3).
Fri Mar 1 21:06:07 CET 2024
Fri Mar 1 21:06:08 CET 2024
WARNING: The directory '/var/www/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
Requirement already satisfied: pip in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (24.0)
Requirement already satisfied: wheel in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (0.42.0)
Requirement already satisfied: pylibftdi in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (0.21.0)
Requirement already satisfied: six in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (1.16.0)
Requirement already satisfied: pyserial in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (3.5)
Requirement already satisfied: setuptools in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (44.1.1)
Requirement already satisfied: requests in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (2.31.0)
Requirement already satisfied: charset-normalizer<4,>=2 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (from requests) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (from requests) (3.6)
Requirement already satisfied: urllib3<3,>=1.21.1 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (from requests) (2.2.1)
Requirement already satisfied: certifi>=2017.4.17 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (from requests) (2024.2.2)
Requirement already satisfied: pyudev in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (0.24.1)
Requirement already satisfied: paho-mqtt==1.6.1 in /var/www/html/plugins/teleinfo/ressources/venv/lib/python3.9/site-packages (1.6.1)
Fri Mar 1 21:06:14 CET 2024
* Installation des dépendances OK *
+ echo 3
+ php /var/www/html/core/class/../php/jeecli.php plugin dependancy_end teleinfo
+ rm /tmp/jeedom_install_in_progress_teleinfo
log deamon mqtt
sh: 1: xxxxxx not found
log teleinfo:
[2024-03-01 21:08:32][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 21:08:32][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 21:08:38][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:08:38][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 21:08:44][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:08:44][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 21:08:49][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:08:49][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 21:08:54][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:08:54][DEBUG] : [TELEINFO_deamon] état global => retour: nok
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon_infoserial] démon port modem 1 ou 2cpt => ok
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon_infoMqtt] test pid
[2024-03-01 21:08:55][ERROR] : [TELEINFO_deamon_infoMqtt] le deamon MQTT n'est pas démarré
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon_modem] état : ok
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon_MQTT] état : nok
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:08:55][DEBUG] : [TELEINFO_deamon] état global => retour: nok
2024-03-01 21:20:13]DEBUG : [TELEINFO_deamon] état global => retour: ok
[2024-03-01 21:20:13]INFO : [deamon_stop_serial] Tentative d'arrêt du service
[2024-03-01 21:20:13]INFO : [deamon_stop_serial] Arrêt du service Conso OK
[2024-03-01 21:20:14]DEBUG : [TELEINFO_deamon_infoserial] test pid
[2024-03-01 21:20:14]ERROR : [TELEINFO_deamon_infoserial] le deamon port modem 1 n'est pas démarré
[2024-03-01 21:20:14]DEBUG : [TELEINFO_deamon_modem] état : nok
[2024-03-01 21:20:14]DEBUG : [TELEINFO_deamon_MQTT] état : sans
[2024-03-01 21:20:14]DEBUG : [TELEINFO_deamon_prod] état : sans
[2024-03-01 21:20:14]DEBUG : [TELEINFO_deamon] état global => retour: nok
