Merci pour votre message
Je viens de réessayer, pas d’amélioration
Réinstallation de la beta : pas mieux
Ci-dessous le log du myaudi_deamon :
[2025-01-17 12:27:02][ERROR] : Error while updating - WAUZZZFZ1RP086346 - (1 validation error for Model
climatisation.climatisationSettings.value.targetTemperature_C
Input should be a valid integer, got a number with a fractional part [type=int_from_float, input_value=15.5, input_type=float]
For further information visit https://errors.pydantic.dev/2.10/v/int_from_float)
[2025-01-17 12:27:02][ERROR] : Impossible to get data for vehicle Vehicle(vin='WAUZZZFZ1RP086346', uris={'client_id': '09b6cbec-cd19-4589-82fd-363dfa8c24da@apps_vw-dilab_com', 'audi_url': 'https://emea.bff.cariad.digital/login/v1/audi', 'base_url': 'https://app-api.my.audi.com', 'profil_url': 'https://customer-profile.vwgroup.io/v3', 'mbb_url': 'https://mbboauth-1d.prd.ece.vwg-connect.com/mbbcoauth', 'here_url': 'https://csm.cc.api.here.com/api/v1', 'mdk_url': 'https://emea.bff.cariad.digital/', 'cv_url': 'https://emea.bff.cariad.digital', 'user_url': 'https://userinformationservice.apps.emea.vwapps.io', 'authorization_endpoint': 'https://identity.vwgroup.io/oidc/v1/authorize', 'token_endpoint': 'https://emea.bff.cariad.digital/login/v1/idk/token', 'revocation_endpoint': 'https://emea.bff.cariad.digital/login/v1/idk/revoke', 'language': 'fr', 'country': 'FR'}, auth=<audiconnectpy.auth.Auth object at 0x7f1292577690>, fill_region=FillRegion(url='https://fal-3a.prd.eu.dp.vwg-connect.com/fs-car', url_setter='https://mal-3a.prd.eu.dp.vwg-connect.com/api'), spin='', last_access=None, last_update=None, is_moving=False, capabilities={'plugAndCharge': {'id': 'plugAndCharge', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'postPlugandchargeUninstall': {'id': 'postPlugandchargeUninstall', 'scopes': ['plugAndCharge']}, 'postPlugandchargeUpdate': {'id': 'postPlugandchargeUpdate', 'scopes': ['plugAndCharge']}, 'postPlugandchargeActivate': {'id': 'postPlugandchargeActivate', 'scopes': ['plugAndCharge']}, 'postPlugandchargeDeactivate': {'id': 'postPlugandchargeDeactivate', 'scopes': ['plugAndCharge']}, 'postPlugandchargeInstall': {'id': 'postPlugandchargeInstall', 'scopes': ['plugAndCharge']}, 'getPlugandchargeRequestsByID': {'id': 'getPlugandchargeRequestsByID', 'scopes': ['plugAndCharge']}, 'getPlugandchargeStatus': {'id': 'getPlugandchargeStatus', 'scopes': ['plugAndCharge']}, 'getPlugandchargeStatusContract': {'id': 'getPlugandchargeStatusContract', 'scopes': ['plugAndCharge']}}, 'parameters': []}, 'privateEmergencyCall': {'id': 'privateEmergencyCall', 'expirationDate': '2034-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'hybridRadio': {'id': 'hybridRadio', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'ignition': {'id': 'ignition', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getStates': {'id': 'getStates', 'scopes': ['parkingBrakeStatus', 'ignitionStatus', 'oilLevels']}}, 'parameters': []}, 'onlineTraffic': {'id': 'onlineTraffic', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'cubicNetwork': {'id': 'cubicNetwork', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'onlineSpeech': {'id': 'onlineSpeech', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'automation': {'id': 'automation', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'functionOnDemand': {'id': 'functionOnDemand', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'mapUpdate': {'id': 'mapUpdate', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'onStreetParking': {'id': 'onStreetParking', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'parkingPosition': {'id': 'parkingPosition', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getParkingposition': {'id': 'getParkingposition', 'scopes': ['parking_position']}}, 'parameters': []}, 'wifiHotspot': {'id': 'wifiHotspot', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['DisabledByUser', 'FrontendSwitchedOff'], 'operations': {}, 'parameters': []}, 'charging': {'id': 'charging', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getChargingCareStatus': {'id': 'getChargingCareStatus', 'scopes': ['manageCharging']}, 'getChargingMode': {'id': 'getChargingMode', 'scopes': ['charging']}, 'getChargingSettingsBidirectional': {'id': 'getChargingSettingsBidirectional', 'scopes': ['charging']}, 'getChargingStatus': {'id': 'getChargingStatus', 'scopes': ['charging']}, 'postChargingStop': {'id': 'postChargingStop', 'scopes': ['manageCharging']}, 'putChargingMode': {'id': 'putChargingMode', 'scopes': ['manageCharging']}, 'getChargingRequestsByID': {'id': 'getChargingRequestsByID', 'scopes': ['manageCharging']}, 'getChargingSettings': {'id': 'getChargingSettings', 'scopes': ['charging']}, 'putChargingSettings': {'id': 'putChargingSettings', 'scopes': ['manageCharging']}, 'postChargingStart': {'id': 'postChargingStart', 'scopes': ['manageCharging']}}, 'parameters': [{'key': 'allowPlugUnlockACPermanent', 'value': 'false'}, {'key': 'allowPlugUnlockACOnce', 'value': 'false'}, {'key': 'allowPlugUnlockDCPermanent', 'value': 'false'}, {'key': 'allowPlugUnlockDCOnce', 'value': 'false'}, {'key': 'supportsTargetStateOfCharge', 'value': 'true'}, {'key': 'targetStateOfChargeMinimumAllowedValue', 'value': '50'}, {'key': 'targetStateOfChargeStepSize', 'value': '10'}]}, 'climatisationTimers': {'id': 'climatisationTimers', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getClimatisationTimers': {'id': 'getClimatisationTimers', 'scopes': ['climatisation']}, 'putClimatisationTimers': {'id': 'putClimatisationTimers', 'scopes': ['manageClimatisation']}}, 'parameters': [{'key': 'timerStepSizeInMinutes', 'value': '5'}, {'key': 'supportsSingleTimer', 'value': 'true'}, {'key': 'supportsRepeatingTimer', 'value': 'false'}, {'key': 'allowedSchedulingIntervalInDays', 'value': '7'}, {'key': 'multipleActiveTimersAllowed', 'value': 'true'}, {'key': 'timeZoneReference', 'value': 'UTC'}]}, 'mapUpdateSd': {'id': 'mapUpdateSd', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'vehicleLights': {'id': 'vehicleLights', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getLightsStatus': {'id': 'getLightsStatus', 'scopes': ['vehicleLights']}}, 'parameters': []}, 'climatisation': {'id': 'climatisation', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'postWindowheatingStop': {'id': 'postWindowheatingStop', 'scopes': ['manageClimatisation']}, 'getClimatisationSettings': {'id': 'getClimatisationSettings', 'scopes': ['climatisation']}, 'putClimatisationSettings': {'id': 'putClimatisationSettings', 'scopes': ['manageClimatisation']}, 'postClimatisationStart': {'id': 'postClimatisationStart', 'scopes': ['manageClimatisation']}, 'getClimatisationTemperature': {'id': 'getClimatisationTemperature', 'scopes': ['intExtTemperature']}, 'getWindowheatingRequestsByID': {'id': 'getWindowheatingRequestsByID', 'scopes': ['manageClimatisation']}, 'getClimatisationRequestsByID': {'id': 'getClimatisationRequestsByID', 'scopes': ['manageClimatisation']}, 'getClimatisationStatus': {'id': 'getClimatisationStatus', 'scopes': ['climatisation']}, 'postClimatisationStop': {'id': 'postClimatisationStop', 'scopes': ['manageClimatisation']}, 'postWindowheatingStart': {'id': 'postWindowheatingStart', 'scopes': ['manageClimatisation']}}, 'parameters': [{'key': 'supportsTargetTemperatureInStartClimatisation', 'value': 'false'}, {'key': 'supportsTargetTemperatureInSettings', 'value': 'false'}, {'key': 'supportsClimatisationAtUnlock', 'value': 'false'}, {'key': 'supportsWindowHeatingEnabled', 'value': 'false'}, {'key': 'supportsZoneFrontLeftEnabled', 'value': 'false'}, {'key': 'supportsZoneFrontRightEnabled', 'value': 'false'}, {'key': 'supportsZoneRearLeftEnabled', 'value': 'false'}, {'key': 'supportsZoneRearRightEnabled', 'value': 'false'}, {'key': 'supportsClimatisationMode', 'value': 'false'}, {'key': 'supportsOffGridClimatisation', 'value': 'false'}, {'key': 'supportsStartParallelClimatisationWindowHeating', 'value': ''}]}, 'eRoutePlanner': {'id': 'eRoutePlanner', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'trafficSigns': {'id': 'trafficSigns', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'localHazards': {'id': 'localHazards', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'news': {'id': 'news', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'postNewsfeeds': {'id': 'postNewsfeeds', 'scopes': ['rssFeeds']}, 'deleteNewsfeedsByID': {'id': 'deleteNewsfeedsByID', 'scopes': ['rssFeeds']}, 'getNewsfeeds': {'id': 'getNewsfeeds', 'scopes': ['rssFeeds']}}, 'parameters': []}, 'predictiveRouting': {'id': 'predictiveRouting', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'weatherInformation': {'id': 'weatherInformation', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'destinationSync': {'id': 'destinationSync', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': [{'key': 'supportsTours', 'value': 'true'}]}, 'audishop': {'id': 'audishop', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'batteryColdWarning': {'id': 'batteryColdWarning', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'satelliteMap': {'id': 'satelliteMap', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'vehicleHealth': {'id': 'vehicleHealth', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'chargingStations': {'id': 'chargingStations', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'poiSearch': {'id': 'poiSearch', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'theming': {'id': 'theming', 'expirationDate': '2034-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': [{'key': 'themeFeatureSet', 'value': ''}]}, 'vehicleWakeUpTrigger': {'id': 'vehicleWakeUpTrigger', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'postVehiclewakeupUpdate': {'id': 'postVehiclewakeupUpdate', 'scopes': []}}, 'parameters': []}, 'parkingBrake': {'id': 'parkingBrake', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'state': {'id': 'state', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getAccessStatus': {'id': 'getAccessStatus', 'scopes': ['doors_windows']}}, 'parameters': []}, 'fuelStatus': {'id': 'fuelStatus', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getFuelStatus': {'id': 'getFuelStatus', 'scopes': ['fuelLevels']}}, 'parameters': []}, 'measurements': {'id': 'measurements', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getMeasurements': {'id': 'getMeasurements', 'scopes': ['range', 'mileage']}}, 'parameters': []}, 'onlineBoardBook': {'id': 'onlineBoardBook', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'readiness': {'id': 'readiness', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getReadinessStatus': {'id': 'getReadinessStatus', 'scopes': ['vehicleOnlineCapabilities']}}, 'parameters': []}, 'trafficLights': {'id': 'trafficLights', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'vehicleHealthWarnings': {'id': 'vehicleHealthWarnings', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getWarninglightsLast': {'id': 'getWarninglightsLast', 'scopes': ['warning_lights']}}, 'parameters': []}, 'alexa': {'id': 'alexa', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'chargingProfiles': {'id': 'chargingProfiles', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getChargingProfiles': {'id': 'getChargingProfiles', 'scopes': ['charging']}, 'putChargingProfiles': {'id': 'putChargingProfiles', 'scopes': ['manageCharging']}}, 'parameters': [{'key': 'supportsMaxChargingCurrent', 'value': 'false'}, {'key': 'allowPlugUnlockACPermanent', 'value': 'false'}, {'key': 'allowPlugUnlockACOnce', 'value': 'false'}, {'key': 'allowPlugUnlockDCPermanent', 'value': 'false'}, {'key': 'allowPlugUnlockDCOnce', 'value': 'false'}, {'key': 'minimumStateOfChargeFixedValue', 'value': '25'}, {'key': 'minimumStateOfChargeMinimumAllowedValue', 'value': ''}, {'key': 'minimumStateOfChargeMaximumAllowedValue', 'value': ''}, {'key': 'minimumStateOfChargeStepSize', 'value': ''}, {'key': 'numberOfPreferredChargingTimes', 'value': '1'}, {'key': 'numberOfTimers', 'value': '0'}, {'key': 'supportsRepeatingTimer', 'value': 'false'}, {'key': 'supportsSingleTimer', 'value': 'false'}, {'key': 'numberOfProfiles', 'value': '7'}, {'key': 'supportsTimerClimatisation', 'value': 'false'}, {'key': 'supportsUsePrivateCurrent', 'value': 'false'}, {'key': 'minimumStateOfChargeSupportsDisabling', 'value': 'true'}, {'key': 'targetStateOfChargeStepSize', 'value': '10'}, {'key': 'targetStateOfChargeMinimumAllowedValue', 'value': '50'}, {'key': 'supportsTargetStateOfCharge', 'value': 'true'}, {'key': 'timeZoneReference', 'value': 'UTC'}, {'key': 'supportsVehiclePositionedInProfileID', 'value': 'true'}, {'key': 'allowLocationModification', 'value': 'false'}, {'key': 'radiusInMeters', 'value': '100'}]}, 'cityModels': {'id': 'cityModels', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'onlineTrafficPlus': {'id': 'onlineTrafficPlus', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'emergencyCalling': {'id': 'emergencyCalling', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {}, 'parameters': []}, 'songRecognition': {'id': 'songRecognition', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'webRadio': {'id': 'webRadio', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': False, 'status': ['MissingLicense'], 'operations': {}, 'parameters': []}, 'batteryChargingCare': {'id': 'batteryChargingCare', 'userDisablingAllowed': True, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getChargingCareSettings': {'id': 'getChargingCareSettings', 'scopes': ['charging']}, 'putChargingCareSettings': {'id': 'putChargingCareSettings', 'scopes': ['manageCharging']}, 'getChargingCareStatus': {'id': 'getChargingCareStatus', 'scopes': ['manageCharging']}}, 'parameters': []}, 'chargingTimers': {'id': 'chargingTimers', 'expirationDate': '2027-07-12T23:59:59Z', 'userDisablingAllowed': False, 'endpoint': 'vs', 'isEnabled': True, 'status': [], 'operations': {'getChargingTimers': {'id': 'getChargingTimers', 'scopes': ['charging']}, 'postChargingTimers': {'id': 'postChargingTimers', 'scopes': ['manageCharging']}, 'putChargingTimers': {'id': 'putChargingTimers', 'scopes': ['manageCharging']}, 'deleteChargingTimersByID': {'id': 'deleteChargingTimersByID', 'scopes': ['manageCharging']}}, 'parameters': [{'key': 'timerStepSizeInMinutes', 'value': '5'}, {'key': 'supportsSingleTimer', 'value': 'false'}, {'key': 'supportsRepeatingTimer', 'value': 'true'}, {'key': 'allowedSchedulingIntervalInDays', 'value': '7'}, {'key': 'multipleActiveTimersAllowed', 'value': 'true'}, {'key': 'timeZoneReference', 'value': 'UTC'}, {'key': 'supportsEditingClimatisationOption', 'value': 'true'}]}}, capabilities_supported=True, position_supported=True, locations_supported=True, trips_supported=False, position=None, climatisation_timers=[]): 'Vehicle' object has no attribute 'infos'
