### Link
https://www.leroymerlin.fr/produits/chauffage-et-ventilation/radiateur…/radiateur-a-eau-chaude/accessoires-de-radiateur-eau-chaude/thermostat-et-tete-thermostatique-connecte/tete-thermostatique-connectee-et-intelligente-sedea-92041646.html
### Database entry
{"id":30,"type":"EndDevice","ieeeAddr":"0x28dba7fffe6dd0a4","nwkAddr":20963,"manufId":4742,"manufName":"SEDEA","powerSource":"Battery","modelId":"eTH700","epList":[1],"endpoints":{"1":{"profId":260,"epId":1,"devId":769,"inClusterList":[0,1,3,6,32,513,64599,64529],"outClusterList":[10,25],"clusters":{"64529":{"attributes":{"0":0,"16":513,"24576":0,"24577":1500,"24578":700,"24579":343,"24580":423,"24581":1371,"24582":2730,"24583":1369,"24584":127,"24585":2500,"24586":1900,"24587":100,"24588":100}},"genBasic":{"attributes":{"modelId":"eTH700","manufacturerName":"SEDEA","powerSource":3,"zclVersion":8,"appVersion":0,"dateCode":"20240321","swBuildId":"1.1.5"}},"genPollCtrl":{"attributes":{"checkinInterval":14400}},"genPowerCfg":{"attributes":{"batteryPercentageRemaining":188}},"genOnOff":{"attributes":{"onOff":1}},"hvacThermostat":{"attributes":{"systemMode":4,"localTemp":2390,"occupiedHeatingSetpoint":2500,"runningState":1,"localTemperatureCalibration":0}}},"binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0xe0798dfffe77c921","endpointID":1},{"cluster":1,"type":"endpoint","deviceIeeeAddress":"0xe0798dfffe77c921","endpointID":1},{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0xe0798dfffe77c921","endpointID":1}],"configuredReportings":[{"cluster":1,"attrId":33,"minRepIntval":3600,"maxRepIntval":65000,"repChange":10},{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":65000,"repChange":1}],"meta":{}}},"appVersion":0,"dateCode":"20240321","swBuildId":"1.1.5","zclVersion":8,"interviewCompleted":true,"meta":{"configured":332242049},"lastSeen":1728843567729,"checkinInterval":3600}
### Zigbee2MQTT version
1.40.2
### Comments
I think this is the same product than Sonoff TRVZB, is there a way to say to z2m to use the same definitions?
### External definition
```shell
const {battery, onOff} = require('zigbee-herdsman-converters/lib/modernExtend');
const definition = {
zigbeeModel: ['eTH700'],
model: 'eTH700',
vendor: 'SEDEA',
description: 'Automatically generated definition',
extend: [battery(), onOff({"powerOnBehavior":false})],
meta: {},
module.exports = definition;
### What does/doesn't work with the external definition?
power on/ power off
batterie level
