Bonjour @nebz
Je viens de recevoir mon UXG-Lite pour remplacer mon USG3, mais il ne remonte pas via le plugin, d’après les logs il est bien vu mais dans les équipements je ne le vois pas.
Log débug d’un scan :
[2023-11-25 15:54:11][INFO] : Mise à jour Device UXG(d8:b3:70:8d:e3:b0)(uxg):{"site_id":"5a4b83a2e4b0208567393030","mac":"d8:b3:70:8d:e3:b0","adopted":true,"model_in_lts":false,"model_in_eol":false,"credential_caps":0,"uptime":19980,"serial":"D8B3708DE3B0","ip":"xxx","model":"UXG","version":"3.1.15.12687","hostname":"UXG-Lite","hash_id":"077bd78f2f7b9768","anon_id":"0872b600-8053-4ca0-877b-d78f2f7b9768","default":false,"locating":false,"type":"uxg","unsupported":false,"unsupported_reason":0,"discovered_via":"l2","adopt_ip":"192.168.10.1","adopt_url":"http:\/\/192.168.10.210:8080\/inform","state":1,"adopt_status":0,"start_disconnected_millis":1700904130160,"last_seen":1700924050,"startup_timestamp":1700904070,"upgradable":false,"adoptable_when_upgraded":false,"x_authkey":"dddd","cfgversion":"abc53c5d2a22aab4","syslog_key":"ddd","config_network":{"ip":"192.168.1.1","type":"dhcp"},"setup_id":"e365ffcf-d2de-4232-93b7-bef6dcc13ce1","license_state":"registered","adopted_at":1700904168,"_id":"6561bce8258fb80d9cf828b2","device_id":"6561bce8258fb80d9cf828b2","adopt_state":0,"adopt_tries":0,"adopt_manual":true,"adopted_by_client":"web","x_aes_gcm":true,"x_adopt_username":"","x_adopt_password":"","x_ssh_hostkey_fingerprint":"xxxxx:xxxx","adoption_completed":true,"config_network_lan":{"dhcp_enabled":false,"dhcp_range_stop":"","vlan":1,"dhcp_range_start":"","cidr":"192.168.10.1\/24"},"inform_url":"http:\/\/192.168.10.210:8080\/inform","inform_ip":"192.168.10.210","reboot_duration":90,"upgrade_duration":120,"required_version":"3.1.0","kernel_version":"4.4.60-ui-qcom","architecture":"aarch64","board_rev":4,"manufacturer_id":61,"model_incompatible":false,"min_inform_interval_seconds":1,"rollupgrade":false,"last_config_applied_successfully":true,"ethernet_table":[{"port_idx":1,"num_port":1,"name":"eth0","mac":"d8:b3:70:8d:e3:b0"},{"port_idx":2,"num_port":1,"name":"eth1","mac":"d8:b3:70:8d:e3:b1"}],"port_table":[{"port_idx":1,"media":"GE","port_poe":false,"speed_caps":1048623,"op_mode":"switch","forward":"all","autoneg":true,"enable":true,"flowctrl_rx":false,"flowctrl_tx":false,"full_duplex":true,"is_uplink":false,"mac":"d8:b3:70:8d:e3:b0","name":"Port 1","num_port":1,"poe_enable":false,"poe_power":"0.00","rx_broadcast":0,"rx_bytes":2823914209,"rx_dropped":118,"rx_errors":0,"rx_multicast":0,"rx_packets":3890364,"rx_rate":98781,"rx_rate-max":320223,"speed":1000,"tx_broadcast":0,"tx_bytes":5753575832,"tx_dropped":0,"tx_errors":0,"tx_multicast":0,"tx_packets":4596846,"tx_rate":307276,"tx_rate-max":493836,"type":"ethernet","up":true,"ifname":"eth0","tx_bytes-r":16454.01446599885,"rx_bytes-r":9189.17773809884,"bytes-r":25643.192204097693,"ip":"192.168.10.1","netmask":"255.255.255.0","network_name":"lan","masked":false,"aggregated_by":false},{"port_idx":2,"media":"GE","port_poe":false,"speed_caps":1048623,"op_mode":"switch","forward":"all","autoneg":true,"enable":true,"flowctrl_rx":false,"flowctrl_tx":false,"full_duplex":true,"is_uplink":true,"mac":"d8:b3:70:8d:e3:b1","mac_table":[{"age":19928,"authorized":true,"hostname":"xxxx","ip":"xxx","lastReachable":14,"mac":"3a:07:16:0e:23:7a"}],"name":"Port 2","num_port":1,"poe_enable":false,"poe_power":"0.00","rx_broadcast":0,"rx_bytes":5747831150,"rx_dropped":34,"rx_errors":0,"rx_multicast":0,"rx_packets":4660124,"rx_rate":308651,"rx_rate-max":495281,"speed":1000,"tx_broadcast":0,"tx_bytes":2708559338,"tx_dropped":0,"tx_errors":0,"tx_multicast":0,"tx_packets":3494483,"tx_rate":60947,"tx_rate-max":133652,"type":"ethernet","up":true,"ifname":"eth1","tx_bytes-r":7618,"rx_bytes-r":38581,"bytes-r":46199,"ip":"","netmask":"255.255.255.0","network_name":"wan","masked":false,"aggregated_by":false}],"ethernet_overrides":[{"ifname":"eth0","networkgroup":"LAN"},{"ifname":"eth1","networkgroup":"WAN"}],"usg_caps":-34738180,"usg2_caps":19,"has_speaker":false,"has_eth1":false,"fw_caps":1676582447,"fw2_caps":7,"hw_caps":0,"wifi_caps":22986449,"udapi_caps":1027055,"udapi_version":{"path":"\/system\/ubios\/udm\/configuration","versionDetail":{"services\/webServer":1,"services\/redirector":1,"services\/upnp":1,"services\/mdns":1,"services\/snmpAgent":1,"services\/utm":2,"vpn\/wireguard\/site-to-sites":3,"vpn\/wireguard\/servers":2,"services\/sshServer":1,"firewall\/nat":3,"qos":2,"services\/bleHTTPTransport":1,"vpn\/openvpn\/raws":3,"vpn\/teleport":1,"bridge-firewall":1,"services\/discoveryResponder":1,"services\/igmpSnooping":2,"services\/dohProxy":1,"services\/vrrp":1,"peripherals":1,"routes\/ospf":3,"vpn\/ipsec\/site-to-site":3,"services\/telnetServer":1,"firewall\/settings":1,"routes\/ospf\/interfaces":2,"services\/arpInspection":1,"vpn\/wireguard\/clients":2,"services\/suspend":1,"system":4,"routes\/static":1,"system\/users":1,"firewall\/pbr":4,"services\/lldp":1,"services\/unms":1,"firewall\/sets":1,"services\/dnsForwarder":3,"services\/igmpProxy":1,"services\/radius-profiles":1,"vlans":1,"services\/radiusServer":2,"qos\/ip":2,"firewall\/filter":3,"services\/wanFailover":5,"services\/systemLog":1,"services\/stunnel":1,"services\/clientIsolation":1,"routes\/ospf\/areas":3,"services\/l2tpServer":2,"services\/geoipFiltering":1,"routes\/access-lists":1,"firewall\/mangle":4,"services\/dhcpServers":1,"services\/dpi":1,"services\/ntpClient":1,"services\/unifiNetwork":1,"services\/latencyMonitor":1,"interfaces":9,"vpn\/openvpn\/peers":4,"services\/idsIps":2,"services\/wifiman":2,"services\/uid":1,"services\/ipAccounting":1,"services\/ddns":2},"versionFormat":"v2","version":48},"switch_caps":{"max_aggregate_sessions":0,"feature_caps":0,"max_mirror_sessions":0},"has_fan":false,"has_temperature":false,"ruleset_interfaces":{"br0":"lan","eth1":"eth1"},"teleport_version":"1","known_cfgversion":"abc53c5d2a22aab4","start_connected_millis":1700905327339,"connected_at":1700905327,"next_interval":33,"prev_non_busy_state":1,"_uptime":19980,"provisioned_at":1700913992,"sys_stats":{"loadavg_1":"1.66","loadavg_15":"1.57","loadavg_5":"1.63","mem_buffer":54693888,"mem_total":1021415424,"mem_used":812232704},"system-stats":{"cpu":"18.9","mem":"79.6","uptime":"19981"},"ssh_session_table":[],"lldp_table":[{"chassis_id":"00:8e:73:c9:aa:b2","chassis_id_subtype":"mac","is_wired":true,"local_port_idx":1,"local_port_name":"eth0","port_id":"00:8e:73:c9:aa:b2"}],"displayable_version":"3.1.15","connection_network_id":"5a4b83a5e4b0208567393039","connection_network_name":"Home","last_connection_network_id":"5a4b83a5e4b0208567393039","last_connection_network_name":"Home","is_access_point":false,"safe_for_autoupgrade":true,"guest_kicks":0,"guest_token":"95D0C0AF6C5034A99C47EAE3FE728EC9","temperatures":[],"storage":[{"mount_point":"\/persistent","name":"Backup","size":2040373248,"type":"eMMC","used":36864},{"mount_point":"\/tmp","name":"Temporary","size":255356928,"type":"other","used":118784}],"uptime_stats":{"WAN":{"alerting_monitors":[{"availability":100,"latency_average":4,"target":"ping.ui.com","type":"icmp"},{"availability":100,"latency_average":100,"target":"1.1.1.1","type":"dns"},{"availability":100,"latency_average":100,"target":"8.8.8.8","type":"dns"}],"availability":100,"latency_average":4,"monitors":[{"availability":100,"latency_average":4,"target":"www.microsoft.com","type":"icmp"},{"availability":100,"latency_average":4,"target":"google.com","type":"icmp"},{"availability":100,"latency_average":5,"target":"1.1.1.1","type":"icmp"}],"time_period":18706,"uptime":18699}},"overheating":false,"geo_info":{"WAN":{"accuracy":500,"address":"xxx","asn":12322,"city":"Pl\u00e9d\u00e9liac","continent_code":"EU","country_code":"FR","country_name":"France","isp_name":"Free SAS","isp_organization":"Free SAS","latitude":48.4473,"longitude":-2.3816,"timezone":"Europe\/Paris"}},"led_state":{"pattern":"1","tempo":120},"outlet_table":[],"speedtest-status":{"latency":0,"rundate":0,"runtime":0,"server":{"cc":"","city":"","country":"","lat":0,"lon":0,"provider":"","provider_url":""},"source_interface":"","status_download":0,"status_ping":0,"status_summary":0,"status_upload":0,"xput_download":0,"xput_upload":0},"speedtest-status-saved":true,"wan1":{"latency":4,"availability":100,"uplink_ifname":"eth1","max_speed":1000,"type":"ethernet","autoneg":true,"enable":true,"flowctrl_rx":false,"flowctrl_tx":false,"full_duplex":true,"is_uplink":true,"mac":"d8:b3:70:8d:e3:b1","mac_table":[{"age":19928,"authorized":true,"hostname":"xxx","ip":"xxx","lastReachable":14,"mac":"3a:07:16:0e:23:7a"}],"media":"GE","name":"eth1","num_port":1,"poe_enable":false,"poe_power":"0.00","port_idx":2,"port_poe":false,"rx_broadcast":0,"rx_bytes":5747831150,"rx_dropped":34,"rx_errors":0,"rx_multicast":0,"rx_packets":4660124,"rx_rate":308651,"rx_rate-max":495281,"speed":1000,"speed_caps":1048623,"tx_broadcast":0,"tx_bytes":2708559338,"tx_dropped":0,"tx_errors":0,"tx_multicast":0,"tx_packets":3494483,"tx_rate":60947,"tx_rate-max":133652,"up":true,"ifname":"eth1","tx_bytes-r":7618,"rx_bytes-r":38581,"bytes-r":46199,"ip":"xxx","netmask":"255.255.255.0"},"uplink":{"drops":2,"ip":"xxx","latency":5,"name":"eth1","netmask":"255.255.255.0","num_port":1,"rx_bytes":5747831150,"rx_dropped":34,"rx_errors":0,"rx_multicast":0,"rx_packets":4660124,"speedtest_lastrun":0,"speedtest_ping":0,"speedtest_status":"Idle","tx_bytes":2708559338,"tx_dropped":0,"tx_errors":0,"tx_packets":3494483,"up":true,"uptime":19427,"xput_down":0,"xput_up":0,"port_idx":2,"media":"GE","speed":1000,"full_duplex":true,"rx_rate":308651,"tx_rate":60947,"max_speed":1000,"type":"wire","tx_bytes-r":7618,"rx_bytes-r":38581,"uplink_source":"legacy"},"uplink_depth":1,"downlink_lldp_macs":["00:8e:73:c9:aa:b2"],"last_wan_ip":"xxx","downlink_table":[{"mac":"74:ac:b9:af:48:8c","port_idx":1,"speed":1000,"full_duplex":true}],"network_table":[{"setting_preference":"manual","dhcpdv6_dns_auto":true,"ipv6_pd_stop":"::7d1","dhcpd_gateway_enabled":false,"dhcpd_dns_1":"192.168.10.250","ipv6_client_address_assignment":"slaac","dhcpd_start":"192.168.10.10","dhcpd_unifi_controller":"","ipv6_ra_enabled":true,"domain_name":"home","ip_subnet":"192.168.10.1\/24","dhcpd_dns_2":"","ipv6_interface_type":"none","dhcpdv6_stop":"::7d1","is_nat":true,"dhcpd_dns_enabled":true,"nat_outbound_ip_addresses":[{"wan_network_group":"WAN","ip_address":"192.168.90.10"}],"dhcp_relay_enabled":false,"igmp_proxy_downstream":false,"ipv6_pd_auto_prefixid_enabled":false,"name":"Home","site_id":"5a4b83a2e4b0208567393030","dhcpdv6_leasetime":86400,"ipv6_enabled":false,"_id":"5a4b83a5e4b0208567393039","lte_lan_enabled":false,"dhcpd_leasetime":86400,"purpose":"corporate","igmp_snooping":true,"dhcpd_time_offset_enabled":false,"dhcpguard_enabled":false,"dhcpdv6_allow_slaac":true,"ipv6_ra_preferred_lifetime":14400,"dhcpd_stop":"192.168.10.70","enabled":true,"dhcpd_enabled":true,"dhcpd_wpad_url":"","networkgroup":"LAN","ipv6_ra_valid_lifetime":"14400","dhcpdv6_start":"::2","vlan_enabled":false,"ipv6_setting_preference":"auto","gateway_type":"default","ipv6_ra_priority":"high","dhcpd_boot_enabled":false,"ipv6_pd_start":"::2","upnp_lan_enabled":false,"dhcpd_ntp_enabled":false,"mdns_enabled":true,"attr_no_delete":true,"dhcpdv6_dns_1":"","attr_hidden_id":"LAN","dhcpd_tftp_server":"","auto_scale_enabled":false,"is_guest":false,"ip":"192.168.10.1","mac":"d8:b3:70:8d:e3:b0","up":true,"active_dhcp_lease_count":11,"gateway_interface_name":"br0","dpistats_table":{"last_updated":1700924050,"by_cat":[{"cat":0,"apps":[27,41],"rx_bytes":8316243,"tx_bytes":3008243,"rx_packets":12552,"tx_packets":13536},{"cat":1,"apps":[2],"rx_bytes":235359,"tx_bytes":245567,"rx_packets":1581,"tx_packets":2313},{"cat":3,"apps":[5,150],"rx_bytes":33404434,"tx_bytes":6396141,"rx_packets":31704,"tx_packets":27064},{"cat":4,"apps":[132,10,42,112],"rx_bytes":209780940,"tx_bytes":4343170,"rx_packets":116013,"tx_packets":54585},{"cat":5,"apps":[95],"rx_bytes":1863409,"tx_bytes":432534,"rx_packets":5314,"tx_packets":4797},{"cat":6,"apps":[1,4],"rx_bytes":723243,"tx_bytes":323085,"rx_packets":1068,"tx_packets":1110},{"cat":8,"apps":[142],"rx_bytes":67074,"tx_bytes":104100,"rx_packets":745,"tx_packets":1469},{"cat":9,"apps":[61],"rx_bytes":88,"tx_bytes":220,"rx_packets":2,"tx_packets":5},{"cat":11,"apps":[68],"rx_bytes":16639,"tx_bytes":4750,"rx_packets":40,"tx_packets":35},{"cat":13,"apps":[66,69,134,7,15,272,84,21,24,30,222,234,247,190],"rx_bytes":2260731146,"tx_bytes":31287858,"rx_packets":1487950,"tx_packets":410516},{"cat":17,"apps":[32,56],"rx_bytes":13641,"tx_bytes":5762,"rx_packets":24,"tx_packets":26},{"cat":18,"apps":[40,63],"rx_bytes":579262,"tx_bytes":255370,"rx_packets":2475,"tx_packets":4394},{"cat":19,"apps":[94],"rx_bytes":111540430,"tx_bytes":7573046,"rx_packets":66591,"tx_packets":25631},{"cat":20,"apps":[194,195,160,185,186,189],"rx_bytes":325296851,"tx_bytes":1258877366,"rx_packets":444852,"tx_packets":954658},{"cat":24,"apps":[3,17,158],"rx_bytes":60664193,"tx_bytes":3608033,"rx_packets":47424,"tx_packets":10146},{"cat":255,"apps":[65535],"rx_bytes":17502448,"tx_bytes":2961088,"rx_packets":31335,"tx_packets":29103}],"by_app":[{"app":1,"cat":6,"clients":…..
[2023-11-25 15:54:11][DEBUG] : postSave
[2023-11-25 15:54:11][DEBUG] : type:uxg
[2023-11-25 15:54:11][DEBUG] : common:[{"name":"Vu Derni\u00e8re Fois","type":"info","subtype":"string","display":{"generic_type":"GENERIC_INFO"},"isVisible":1,"isHistorized":0,"logicalId":"last_seen"},{"name":"Charge Processeur","type":"info","subtype":"numeric","display":{"generic_type":"GENERIC_INFO"},"unit":"%","isVisible":1,"isHistorized":0,"logicalId":"system-stats::cpu"},{"name":"Charge M\u00e9moire","type":"info","subtype":"numeric","display":{"generic_type":"GENERIC_INFO"},"unit":"%","isVisible":1,"isHistorized":0,"logicalId":"system-stats::mem"},{"name":"Uptime","type":"info","subtype":"string","display":{"generic_type":"GENERIC_INFO"},"isVisible":1,"isHistorized":0,"logicalId":"system-stats::uptime"},{"name":"Etat Binaire","type":"info","subtype":"binary","display":{"generic_type":"ONLINE"},"isVisible":1,"isHistorized":0,"logicalId":"stateBin"},{"name":"Etat Num\u00e9rique","type":"info","subtype":"numeric","display":{"generic_type":"GENERIC_INFO"},"template":{"dashboard":"line","mobile":"line"},"isVisible":0,"isHistorized":0,"logicalId":"stateNum"},{"name":"Etat Texte","type":"info","subtype":"string","display":{"generic_type":"GENERIC_INFO"},"isVisible":1,"isHistorized":1,"logicalId":"stateTxt"},{"name":"Upgradable","type":"info","subtype":"binary","display":{"generic_type":"GENERIC_INFO","forceReturnLineBefore":true},"isVisible":1,"isHistorized":0,"logicalId":"upgradable"},{"name":"Mettre \u00e0 jour","type":"action","subtype":"other","display":{"generic_type":"GENERIC_ACTION"},"value":"upgradable","isVisible":1,"logicalId":"upgrade"},{"name":"Nombre de clients","type":"info","subtype":"numeric","display":{"generic_type":"GENERIC_INFO"},"template":{"dashboard":"line","mobile":"line"},"isVisible":1,"isHistorized":0,"logicalId":"num_sta"},{"name":"Rafraichir","type":"action","subtype":"other","display":{"generic_type":"DONT"},"isVisible":1,"logicalId":"refresh"}]
[2023-11-25 15:54:11][DEBUG] : specific:false
Si tu as besoin d’autre chose tu me dis ![]()
