Je viens d installer ce plugin. Reconnu dans l’application harmony comme Roku 4. Quand j’appuie sur le bouton « home » de la telecommande Harmony pour le dispositif « Roku 4 », il se déclenche quelque chose puisque je vois ces messages dans les logs. Les dispositifs sont sur le même réseau. Je vois pas pourquoi ils ne communiquent pas.
Si dessus le log en mode « debug ».
ERROR:aiohttp.server:Error handling request
File "/usr/lib/python3.5/urllib/request.py", line 1254, in do_open
h.request(req.get_method(), req.selector, req.data, headers)
File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
File "/usr/lib/python3.5/http/client.py", line 849, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/lib/python3.5/socket.py", line 712, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 703, in create_connection
sock.connect(sa)
OSError: [Errno 113] No route to host
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/var/www/html/plugins/fakeroku/resources/emulated_roku/__init__.py", line 366, in _check_remote_and_host_ip
File "/var/www/html/plugins/fakeroku/resources/emulated_roku/__init__.py", line 324, in _roku_keypress_handler
self.handler.on_keypress(self.roku_usn, key)
File "/var/www/html/plugins/fakeroku/resources/fakerokud.py", line 37, in on_keypress
urllib.request.urlopen(JEEDOM_URL + key)
File "/usr/lib/python3.5/urllib/request.py", line 163, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.5/urllib/request.py", line 466, in open
response = self._open(req, data)
File "/usr/lib/python3.5/urllib/request.py", line 484, in _open
'_open', req)
File "/usr/lib/python3.5/urllib/request.py", line 444, in _call_chain
result = func(*args)
File "/usr/lib/python3.5/urllib/request.py", line 1282, in http_open
return self.do_open(http.client.HTTPConnection, req)
File "/usr/lib/python3.5/urllib/request.py", line 1256, in do_open
raise URLError(err)
urllib.error.URLError: <urlopen error [Errno 113] No route to host>
INFO:aiohttp.access:192.168.1.15 [01/Mar/2020:09:39:59 +0000] "POST /keypress/Home HTTP/1.1" 500 244 "-" "LuaSocket 2.0.2"
self.send(msg)
self.connect()
raise err
sock.connect(sa)
resp = await task
future.result()
'_open', req)
raise URLError(err)
INFO:aiohttp.access:192.168.1.15 [01/Mar/2020:09:40:03 +0000] "POST /keypress/Home HTTP/1.1" 500 244 "-" "LuaSocket 2.0.2"
