J’ai une jeedom atlas en version 4.2.18.
Je rencontre un problème avec le plugin google cast.
Les dépendances se sont installées correctement mais le démon refuse de démarrer.
Ci-dessous, le contenu des fichiers de log du plugin.
Dominique
Le contenu du fichier googlecast_local comporte un message d’ erreur (|TypeError: Descriptors cannot not be created directly.) et une solution de contournement que je ne comprends pas du tout …
0455|Traceback (most recent call last):
0456|File "/var/www/html/plugins/googlecast/resources/googlecast.py", line 45, in
0457|import pychromecast.pychromecast as pychromecast
0458|File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/__init__.py", line 12, in
0459|from . import socket_client
0460|File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/socket_client.py", line 23, in
0461|from . import cast_channel_pb2
0462|File "/var/www/html/plugins/googlecast/resources/pychromecast/pychromecast/cast_channel_pb2.py", line 36, in
0463|type=None),
0464|File "/usr/local/lib/python3.7/dist-packages/google/protobuf/descriptor.py", line 755, in __new__
0465|_message.Message._CheckCalledFromGeneratedFile()
0466|TypeError: Descriptors cannot not be created directly.
0467|If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.19.0.
0468|If you cannot immediately regenerate your protos, some other possible workarounds are:
0469|1. Downgrade the protobuf package to 3.20.x or lower.
0470|2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slower).
0471|More information: https://developers.google.com/protocol-buffers/docs/news/2022-05-06#python-updates
Le fichier de log googlecast_update comporte quelques warning …
0000|Launch install of googlecast dependancies
0001|-- Current OS version :
0002|Description: Debian GNU/Linux 10 (buster)
0003|-- Updating repo...
0004|Hit:1 http://deb.debian.org/debian buster InRelease
0005|Get:2 http://security.debian.org buster/updates InRelease [65.4 kB]
0006|Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
0007|Get:5 http://deb.debian.org/debian buster-backports InRelease [46.7 kB]
0008|Hit:4 http://mirrors.xtom.de/armbian buster InRelease
0009|Get:6 http://deb.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
0010|Get:7 http://deb.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
0011|Get:8 http://deb.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [28.0 kB]
0012|Get:9 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
0013|Get:10 http://deb.debian.org/debian buster-backports/main arm64 Packages 2022-06-07-1410.28.pdiff [408 B]
0014|Get:11 http://deb.debian.org/debian buster-backports/main arm64 Packages 2022-06-07-2014.25.pdiff [1079 B]
0015|Get:11 http://deb.debian.org/debian buster-backports/main arm64 Packages 2022-06-07-2014.25.pdiff [1079 B]
0016|Get:12 http://deb.debian.org/debian buster-backports/main armhf Packages 2022-06-07-1410.28.pdiff [408 B]
0017|Get:13 http://deb.debian.org/debian buster-backports/main armhf Packages 2022-06-07-2014.25.pdiff [1064 B]
0018|Get:13 http://deb.debian.org/debian buster-backports/main armhf Packages 2022-06-07-2014.25.pdiff [1064 B]
0019|Get:14 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2022-06-07-1410.28.pdiff [1553 B]
0020|Get:15 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2022-06-07-2014.25.pdiff [93 B]
0021|Get:16 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2022-06-07-1410.28.pdiff [1548 B]
0022|Get:15 http://deb.debian.org/debian buster-backports/main armhf Contents (deb) 2022-06-07-2014.25.pdiff [93 B]
0023|Get:17 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2022-06-07-2014.25.pdiff [93 B]
0024|Get:17 http://deb.debian.org/debian buster-backports/main arm64 Contents (deb) 2022-06-07-2014.25.pdiff [93 B]
0025|Hit:18 https://deb.nodesource.com/node_14.x buster InRelease
0026|Fetched 282 kB in 11s (25.2 kB/s)
0027|Reading package lists...
0028|-- Installation of python3 and dependancies
0029|Reading package lists...
0030|Building dependency tree...
0031|Reading state information...
0032|build-essential is already the newest version (12.6).
0033|python-dev is already the newest version (2.7.16-1).
0034|python3 is already the newest version (3.7.3-1).
0035|0 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
0036|-- Installed version of Python :
0037|Python 3.7.3
0038|Your version of python is compatible with this plugin.
0039|-- Installation of pip for python3 and necessary libraries
0040|Reading package lists...
0041|Building dependency tree...
0042|Reading state information...
0043|python3-pip is already the newest version (18.1-5).
0044|python3-dev is already the newest version (3.7.3-1).
0045|python-requests is already the newest version (2.21.0-1).
0046|0 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
0047|-- Installation of audio sox library
0048|Reading package lists...
0049|Building dependency tree...
0050|Reading state information...
0051|sox is already the newest version (14.4.2+git20190427-1).
0052|0 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
0053|-- Installation of TTS libraries
0054|Reading package lists...
0055|Building dependency tree...
0056|Reading state information...
0057|libttspico-utils is already the newest version (1.0+git20130326-9).
0058|0 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
0059|-- Installation of libav/ffmpeg libraries
0060|Reading package lists...
0061|Building dependency tree...
0062|Reading state information...
0063|ffmpeg is already the newest version (7:4.1.9-0+deb10u1).
0064|0 upgraded, 0 newly installed, 0 to remove and 111 not upgraded.
0065|-- Upgrade setuptools with command pip3.7 if not up to date
0066|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0067|Requirement already satisfied: setuptools>=42.0.0 in /usr/local/lib/python3.7/dist-packages (62.3.3)
0068|-- Installed version of pip :
0069|pip 22.1.2 from /usr/local/lib/python3.7/dist-packages/pip (python 3.7)
0070|-- Installation of python library 'requests' with command pip3.7
0071|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0072|Requirement already satisfied: requests>=2.21.0 in /usr/local/lib/python3.7/dist-packages (2.27.1)
0073|Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (1.26.9)
0074|Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (2.0.12)
0075|Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (2022.5.18.1)
0076|Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests>=2.21.0) (3.3)
0077|-- Installation of python library 'protobuf' with command pip3.7
0078|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0079|Requirement already satisfied: protobuf>=3.11.0 in /usr/local/lib/python3.7/dist-packages (4.21.1)
0080|-- Installation of python library 'zeroconf' with command pip3.7
0081|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0082|Requirement already satisfied: zeroconf>=0.25.1 in /usr/local/lib/python3.7/dist-packages (0.38.6)
0083|Requirement already satisfied: ifaddr>=0.1.7 in /usr/local/lib/python3.7/dist-packages (from zeroconf>=0.25.1) (0.1.7)
0084|-- Installation of python library 'click, bs4 and six' for TTS with command pip3.7
0085|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0086|Requirement already satisfied: click in /usr/local/lib/python3.7/dist-packages (8.1.3)
0087|Requirement already satisfied: bs4 in /usr/local/lib/python3.7/dist-packages (0.0.1)
0088|Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.16.0)
0089|Requirement already satisfied: importlib-metadata in /usr/local/lib/python3.7/dist-packages (from click) (4.11.4)
0090|Requirement already satisfied: beautifulsoup4 in /usr/local/lib/python3.7/dist-packages (from bs4) (4.11.1)
0091|Requirement already satisfied: soupsieve>1.2 in /usr/local/lib/python3.7/dist-packages (from beautifulsoup4->bs4) (2.3.2.post1)
0092|Requirement already satisfied: zipp>=0.5 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata->click) (3.8.0)
0093|Requirement already satisfied: typing-extensions>=3.6.4 in /usr/local/lib/python3.7/dist-packages (from importlib-metadata->click) (4.2.0)
0094|-- Installation of python library 'tqdm, websocket-client, casttube' for plex/youtube with command pip3.7
0095|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0096|Requirement already satisfied: tqdm in /usr/local/lib/python3.7/dist-packages (4.64.0)
0097|Requirement already satisfied: websocket-client in /usr/local/lib/python3.7/dist-packages (1.3.2)
0098|Requirement already satisfied: casttube in /usr/local/lib/python3.7/dist-packages (0.2.1)
0099|Requirement already satisfied: requests in /usr/local/lib/python3.7/dist-packages (from casttube) (2.27.1)
0100|Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (3.3)
0101|Requirement already satisfied: charset-normalizer~=2.0.0 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (2.0.12)
0102|Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (2022.5.18.1)
0103|Requirement already satisfied: urllib3<1.27,>=1.21.1 in /usr/local/lib/python3.7/dist-packages (from requests->casttube) (1.26.9)
0104|-- Installation of dependencies is done !
