J’utilise Tydom2mqtt pour récupérer l’état de mon alarme mais je n’arrive pas à récupérer les infos des détecteurs de fenêtres et ma porte de garage est visible mais en mode set_level et pas on/off comme c’est le cas avec mon module.
Voici les infos de la découverte de la porte de garage
{"sensor":{"cover_class_tydom_1730728016_1730728016":{"name":"cover_class","unique_id":"cover_class_tydom_1730728016_1730728016","device":{"manufacturer":"Delta Dore","identifiers":"1730728016_1730728016","model":"Sensor","name":"Porte sectionnelle"},"state_topic":"sensor/tydom/cover_class_tydom_1730728016_1730728016/state"}},"binary_sensor":{"thermicdefect_tydom_1730728016_1730728016":{"name":"thermicDefect","unique_id":"thermicDefect_tydom_1730728016_1730728016","device":{"manufacturer":"Delta Dore","identifiers":"1730728016_1730728016","model":"Sensor","name":"Porte sectionnelle"},"state_topic":"binary_sensor/tydom/thermicDefect_tydom_1730728016_1730728016/state"}},"cover":{"1730728016_1730728016":{"name":null,"unique_id":"1730728016_1730728016","command_topic":"cover/tydom/1730728016_1730728016/set_garageLevelCmd","position_topic":"cover/tydom/1730728016_1730728016/current_position","level_topic":"cover/tydom/1730728016_1730728016/current_level","set_position_topic":"cover/tydom/1730728016_1730728016/set_garageLevel","payload_open":"ON","payload_close":"OFF","payload_stop":"STOP","retain":"false","device":{"manufacturer":"Delta Dore","model":"Garage Door Horizontal","name":"Porte sectionnelle","identifiers":"1730728016_1730728016"},"device_class":"garage","json_attributes_topic":"cover/tydom/1730728016_1730728016/attributes"}}}
Quelqu’un aurait une idée?
