j’ai le même problème avec l’ampoule, impossible de contrôler
les blanc chaud
[2021-02-03 14:33:52][DEBUG] : http://127.0.0.1:8484/application/include type : PUT
[2021-02-03 14:33:52][DEBUG] : {"duration":180}
[2021-02-03 14:33:53][DEBUG] : ""
[2021-02-03 14:33:58][DEBUG] : {"device_joined":"58:8e:81:ff:fe:c8:0d:f5"}
[2021-02-03 14:34:06][DEBUG] : {"device_initialized":"58:8e:81:ff:fe:c8:0d:f5"}
[2021-02-03 14:34:08][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[[{"value":"3","cluster_name":"Basic"},{"value":"80","cluster_name":"Basic"},{"value":"0","cluster_name":"Basic"},{"value":"1","cluster_name":"Basic"}]]}}}
[2021-02-03 14:34:09][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[{"7":{"value":"PowerSource.Mains_single_phase","cluster_name":"Basic"}}]}}}
[2021-02-03 14:34:10][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[{"6":{"value":"","cluster_name":"Basic"}}]}}}
[2021-02-03 14:34:36][DEBUG] : http://127.0.0.1:8484/device/all?with_attributes=2 type : GET
[2021-02-03 14:34:36][DEBUG] : {"with_attributes":2}
[2021-02-03 14:34:36][DEBUG] : http://127.0.0.1:8484/group/all type : GET
[2021-02-03 14:34:36][DEBUG] : null
[2021-02-03 14:36:07][DEBUG] : http://127.0.0.1:8484/device/attributes type : POST
[2021-02-03 14:36:07][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","endpoint":3,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-02-03 14:36:07][INFO] : [rpi4][TZ3000_el5kt5im.TS0502A 58:8e:81:ff:fe:c8:0d:f5] Erreur lors de la requete : http://127.0.0.1:8484/device/attributes(POST), data : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","endpoint":3,"cluster":6,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Endpoint not found : 3","code":0}
[2021-02-03 14:36:07][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","endpoint":3,"cluster":8,"cluster_type":"in","attributes":[0],"allowCache":0}
[2021-02-03 14:36:07][INFO] : [rpi4][TZ3000_el5kt5im.TS0502A 58:8e:81:ff:fe:c8:0d:f5] Erreur lors de la requete : http://127.0.0.1:8484/device/attributes(POST), data : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","endpoint":3,"cluster":8,"cluster_type":"in","attributes":[0],"allowCache":0} erreur : {"state":"error","result":"Endpoint not found : 3","code":0}
[2021-02-03 14:36:11][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[{"1":{"value":"80","cluster_name":"Basic"}}]}}}
[2021-02-03 14:36:11][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::0::1 => 80
[2021-02-03 14:36:55][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:36:55][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-02-03 14:37:03][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:03][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-02-03 14:37:08][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:08][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["156","0"]}],"allowQueue":false}
[2021-02-03 14:37:08][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"8":[{"value":"156","cluster_name":"Level control"}]}}}}
[2021-02-03 14:37:08][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::8::0 => 156
[2021-02-03 14:37:14][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:14][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["27","0"]}],"allowQueue":false}
[2021-02-03 14:37:15][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"8":[{"value":"27","cluster_name":"Level control"}]}}}}
[2021-02-03 14:37:15][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::8::0 => 27
[2021-02-03 14:37:30][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:30][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-02-03 14:37:33][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:33][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-02-03 14:37:45][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-02-03 14:37:45][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::6::0 => Bool.true
[2021-02-03 14:37:45][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"8":[{"value":"255","cluster_name":"Level control"}],"0":{"1":{"value":"80","cluster_name":"Basic"}}}}}}
[2021-02-03 14:37:45][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::8::0 => 255
[2021-02-03 14:37:45][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::0::1 => 80
[2021-02-03 14:37:48][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:48][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"on_off","command":"off","await":1}],"allowQueue":false}
[2021-02-03 14:37:48][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-02-03 14:37:48][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::6::0 => Bool.false
[2021-02-03 14:37:56][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:56][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"on_off","command":"on","await":1}],"allowQueue":false}
[2021-02-03 14:37:56][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-02-03 14:37:56][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::6::0 => Bool.true
[2021-02-03 14:37:58][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:37:58][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["0","0"]}],"allowQueue":false}
[2021-02-03 14:37:58][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"8":[{"value":"1","cluster_name":"Level control"}]}}}}
[2021-02-03 14:37:58][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::8::0 => 1
[2021-02-03 14:38:07][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:38:07][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["254","0"]}],"allowQueue":false}
[2021-02-03 14:38:07][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"8":[{"value":"254","cluster_name":"Level control"}]}}}}
[2021-02-03 14:38:07][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::8::0 => 254
[2021-02-03 14:38:12][DEBUG] : http://127.0.0.1:8484/device/command type : PUT
[2021-02-03 14:38:12][DEBUG] : {"ieee":"58:8e:81:ff:fe:c8:0d:f5","cmd":[{"endpoint":1,"cluster":"level","command":"move_to_level","await":1,"args":["0","0"]}],"allowQueue":false}
[2021-02-03 14:38:12][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"8":[{"value":"1","cluster_name":"Level control"}]}}}}
[2021-02-03 14:38:12][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::8::0 => 1
[2021-02-03 14:38:14][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":{"768":{"color":{"value":"#ff0900","cluster_name":"Color Control"},"7":{"value":"153","cluster_name":"Color Control"}}}}}}
[2021-02-03 14:38:14][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::768::color => #ff0900
[2021-02-03 14:38:14][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::768::7 => 153
[2021-02-03 14:40:15][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[{"1":{"value":"80","cluster_name":"Basic"}}]}}}
[2021-02-03 14:40:15][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::0::1 => 80
[2021-02-03 14:42:45][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[{"1":{"value":"80","cluster_name":"Basic"}}]}}}
[2021-02-03 14:42:45][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::0::1 => 80
[2021-02-03 14:45:15][DEBUG] : {"devices":{"58:8e:81:ff:fe:c8:0d:f5":{"1":[{"1":{"value":"80","cluster_name":"Basic"}}]}}}
[2021-02-03 14:45:15][DEBUG] : Search attribut for 58:8e:81:ff:fe:c8:0d:f5 logicalId : 1::0::1 => 80
