Bonjour à tous et désolé de déterrer le sujet
Je ne retrouve pas la partie " // Array of Equipment logo descriptors " dans mon fichier jMQTT.global.js : je suppose que depuis les Maj. on modifié ceci. Existe-t-il un autre moyen de d’avoir des icones persos ?
Bonne soirée !
/* This file is part of Jeedom.
* Jeedom is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Jeedom is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with Jeedom. If not, see <http://www.gnu.org/licenses/>.
// TODO: Remove core4.2 backward compatibility `jeeFrontEnd` js function
// Remove when Jeedom 4.2 is no longer supported
// labels: workarround, core4.2, javascript
// Handle retrocompatibility of jeeFrontEnd namespace in Jeedom 4.2
if (typeof jeeFrontEnd === 'undefined') {
jeeFrontEnd = window;
// TODO: Remove core4.2 backward compatibility `addUpdateFunction` js function
// Handle retrocompatibility of addUpdateFunction function in Jeedom 4.2
if (typeof jeedom.cmd.addUpdateFunction !== 'function') {
jeedom.cmd.addUpdateFunction = function(id, func) {
jeedom.cmd.update[id] = func;
// Namespace
jmqtt_globals = {};
// Array of Status Icons descriptors and selectors
jmqtt_globals.icons = {
broker: {
status: {
selector: function(_eq) { var info = jmqtt.getMqttClientInfo(_eq); return (!jmqtt_globals.daemonState) ? false : info.state; },
ok: { icon: 'fas fa-check-circle', color: 'success', msg: '{{Connexion au Broker active}}' },
pok: { icon: 'fas fa-minus-circle', color: 'warning', msg: '{{Connexion au Broker en échec}}' },
nok: { icon: 'fas fa-times-circle', color: 'danger', msg: '{{Connexion au Broker désactivée}}' },
false: { icon: 'fas fa-times-circle', color: 'danger', msg: "{{Démon non démarré}}" }
visible: {
selector: function(_eq) { return _eq.isVisible == '1'; },
true: { icon: 'fas fa-eye', color: 'success', msg: '{{Broker visible}}' },
false: { icon: 'fas fa-eye-slash', color: 'warning', msg: '{{Broker masqué}}' }
learning: {
selector: function(_eq) { return _eq.cache.realtime_mode == '1'; },
true: { icon: 'fas fa-sign-in-alt fa-rotate-90', color: 'danger', msg: '{{Temps Réel activé}}' },
false: { icon: 'far fa-square', color: 'success', msg: '{{Temps Réel désactivé}}' }
battery: {
selector: function(_eq) { return 'none'; },
none: { icon: '', color: '', msg: "" }
availability: {
eqpt: {
status: {
selector: function(_eq) { return _eq.isEnable == '1'; },
true: { icon: 'fas fa-check', color: 'success', msg: '{{Activé}}' },
false: { icon: 'fas fa-times', color: 'danger', msg: '{{Désactivé}}' }
visible: {
true: { icon: 'fas fa-eye', color: 'success', msg: '{{Visible}}' },
false: { icon: 'fas fa-eye-slash', color: 'warning', msg: '{{Masqué}}' }
learning: {
selector: function(_eq) { return _eq.configuration.auto_add_cmd == '1'; },
true: { icon: 'fas fa-sign-in-alt fa-rotate-90', color: 'danger', msg: '{{Ajout auto. de commandes activé}}' },
false: { icon: 'far fa-square', color: 'success', msg: '{{Ajout auto. de commandes désactivé}}' }
battery: {
selector: function(_eq) { return (_eq.configuration.battery_cmd == '') ? 'none' : (_eq.status.batterydanger ? 'nok' : (_eq.status.batterywarning ? 'pok' : 'ok')); },
none: { icon: 'fas fa-plug', color: '', msg: '' },
ok: { icon: 'fas fa-battery-full', color: 'success', msg: '{{Batterie OK}}' },
pok: { icon: 'fas fa-battery-quarter', color: 'warning', msg: '{{Batterie en alarme}}' },
nok: { icon: 'fas fa-battery-empty', color: 'danger', msg: '{{Batterie en fin de vie}}' }
availability: {
selector: function(_eq) { return (_eq.configuration.availability_cmd == '') ? 'none' : (_eq.status.warning ? 'nok' : 'ok'); },
none: { icon: 'far fa-bell', color: '', msg: '' },
ok: { icon: 'fas fa-bell', color: 'success', msg: '{{Equipement disponible}}' },
nok: { icon: 'fas fa-bell', color: 'danger', msg: '{{Equipement indisponible}}' }
// To memorise page refresh timeout when set
jmqtt_globals.refreshTimeout = null;
// To reload Real Time view
jmqtt_globals.refreshRealTime = null;
jmqtt_globals.lockRealTime = false;
// To memorise current eqLogic main subscription topic
jmqtt_globals.mainTopic = '';
// Drop zone counter
jmqtt_globals.dropzoneCpt = 0;
// Update daemon state global variable on reception of a new event (jmqtt_globals.daemonState is initialized by sendVarToJS() in jMQTT.php)
$('body').off('jMQTT::EventDaemonState').on('jMQTT::EventDaemonState', function (_event, _options) {
jmqtt_globals.daemonState = _options;
