Ca semble bien venir du plugin :
Logs mysql :
2020-09-21 13:57:08 107 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 13:57:49 107 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 13:58:48 865 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 13:59:31 865 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
Puis :
2020-09-21 16:12:35 1238 [Warning] mysqld: Retry in 60 secs. Message reprinted in 600 secs
2020-09-21 16:14:07 3077 [ERROR] mysqld: Disk full (/tmp/#sql_443_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
Et le total :
2020-09-21 14:12:18 975 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 14:12:59 975 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 16:02:50 2490 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 16:03:32 2490 [ERROR] mysqld: Table 'conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 16:11:42 3037 [ERROR] Got an error from thread_id=3037, /build/mariadb-10.3-V9JMsi/mariadb-10.3-10.3.23/storage/myisam/ha_myisam.cc:1049
2020-09-21 16:11:42 3037 [ERROR] MySQL thread id 1982, OS thread handle 140194989340416, query id 1159297 localhost jeedom Waiting for table level lock
select timestamp,rec_date,hchp*1,hchc*1,ptec,papp*1 as papp,inst1,rec_time,imax1,temp,id_equipement,
DATE_FORMAT(FROM_UNIXTIME(`timestamp`), "%d-%m-%Y %H:%i") as date From conso_current WHERE rec_date = current_date() AND id_equipement = 345 order by timestamp desc limit 1
2020-09-21 16:11:42 3037 [ERROR] MySQL thread id 1238, OS thread handle 140194980783872, query id 1158332 localhost jeedom Waiting for table level lock
REPLACE INTO conso_teleinfo (timestamp , rec_date, rec_time ,hchp,hchc,ptec,inst1,papp,imax1,id_equipement,temp) VALUES (1600697475,"2020-09-21","16:11:15",33388,865997,"HP",0,0,0,468,0)
2020-09-21 16:11:42 3037 [ERROR] MySQL thread id 3037, OS thread handle 140194781755136, query id 1153400 localhost jeedom Checking table
CHECK TABLE `conso_teleinfo`
2020-09-21 16:11:46 1238 [ERROR] mysqld: Table './jeedom/conso_teleinfo' is marked as crashed and should be repaired
2020-09-21 16:11:46 1238 [Warning] Checking table: './jeedom/conso_teleinfo'
2020-09-21 16:11:46 1238 [Warning] Recovering table: './jeedom/conso_teleinfo'
2020-09-21 16:12:35 1238 [Warning] mysqld: Disk is full writing '/tmp/STRRVj8Y' (Errcode: 28 "No space left on device"). Waiting for someone to free space... (Expect up to 60 secs delay for server to continue after freeing disk space)
En gros la table teleinfo crash, il essaie de la réparer et rempli le /tmp
