depuis quelques jours mes équipements ne remontent plus malgré que TGW soit en ligne. Je redémarre l’antenne et tout reviens pour quelques heures…
Mes log:
ERROR:BLEGateway:[org.bluez.Error.InProgress] Operation already in progress
--- Logging error ---
File "/usr/lib/python3.7/logging/__init__.py", line 1034, in emit
msg = self.format(record)
File "/usr/lib/python3.7/logging/__init__.py", line 880, in format
return fmt.format(record)
File "/usr/lib/python3.7/logging/__init__.py", line 619, in format
record.message = record.getMessage()
File "/usr/lib/python3.7/logging/__init__.py", line 380, in getMessage
msg = msg % self.args
TypeError: %d format: a number is required, not ReasonCode
Call stack:
File "/root/.local/bin/TheengsGateway", line 4, in <module>
main()
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/TheengsGateway/__init__.py", line 55, in main
run(configuration, config_path)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/TheengsGateway/ble_gateway.py", line 683, in run
gw.client.loop_forever()
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/paho/mqtt/client.py", line 2291, in loop_forever
rc = self._loop(timeout)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/paho/mqtt/client.py", line 1680, in _loop
rc = self.loop_read()
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/paho/mqtt/client.py", line 2096, in loop_read
return self._loop_rc_handle(rc)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/paho/mqtt/client.py", line 3042, in _loop_rc_handle
self._do_on_disconnect(packet_from_broker=False, v1_rc=rc)
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/paho/mqtt/client.py", line 4383, in _do_on_disconnect
properties,
File "/root/.local/pipx/venvs/theengsgateway/lib/python3.7/site-packages/TheengsGateway/ble_gateway.py", line 164, in on_disconnect
"Disconnected from MQTT broker with reason code = %d", reason_code
Message: 'Disconnected from MQTT broker with reason code = %d'
Arguments: (ReasonCode(Disconnect, 'Unspecified error'),)
