Suite à la mise à jour
impossible de relancer le daemon
le log donne ce message
Error: importing module from jeedom folder
No module named ‹ requests ›
sudo apt update
Get:1 Index of /debian-security buster/updates InRelease [34.8 kB]
Get:2 http://www.deb-multimedia.org buster InRelease [18.1 kB]
Get:3 Index of /debian/ buster InRelease [122 kB]
Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
Get:5 Index of /debian/ buster-updates InRelease [56.6 kB]
Hit:6 Index of /meveric all InRelease
Hit:7 Index of /meveric buster InRelease
Reading package lists…
E: Repository ‹ Index of /debian-security buster/updates InRelease › changed its ‹ Suite › value from ‹ oldstable › to ‹ oldoldstable ›
E: Repository ‹ http://www.deb-multimedia.org buster InRelease › changed its ‹ Suite › value from ‹ oldstable › to ‹ oldoldstable ›
E: Repository ‹ Index of /debian/ buster InRelease › changed its ‹ Suite › value from ‹ oldstable › to ‹ oldoldstable ›
E: Repository ‹ Index of /debian/ buster-updates InRelease › changed its ‹ Suite › value from ‹ oldstable-updates › to ‹ oldoldstable-updates ›
echo 3
sudo apt install -o Dpkg::Options::=–force-confdef -y python3-ftdi1
Building dependency tree…
Reading state information…
python3-ftdi1 is already the newest version (1.4-1+b2).
0 upgraded, 0 newly installed, 0 to remove and 281 not upgraded.
sudo /var/www/html/core/class/…/…/plugins/teleinfo/ressources/post-install.sh
Fri Mar 1 16:49:35 UTC 2024
Installation des dépendances *
Get:2 Index of /debian/ buster InRelease [122 kB]
Get:3 http://www.deb-multimedia.org buster InRelease [18.1 kB]
Get:4 Index of /debian/ buster-updates InRelease [56.6 kB]
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Calculating upgrade…
The following packages have been kept back:
setup-odroid
The following packages will be upgraded:
apache2 apache2-bin apache2-data apache2-utils apt-transport-https
avahi-daemon avahi-discover avahi-utils base-files bind9-host bzip2
ca-certificates chromium chromium-common cpio curl dbus dbus-user-session
debconf debconf-i18n debian-archive-keyring device-tree-compiler dirmngr
distro-info-data dpkg dpkg-dev espeak espeak-data ffmpeg file git-man
glib-networking glib-networking-common glib-networking-services gnupg
gnupg-agent gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client
gpg-wks-server gpgconf gpgsm gpgv gzip iproute2 iputils-ping isc-dhcp-client
isc-dhcp-common klibc-utils libapache2-mod-php7.3 libaprutil1
libaprutil1-dbd-sqlite3 libaprutil1-ldap libapt-inst2.0 libapt-pkg5.0
libarchive13 libavahi-client-dev libavahi-client3 libavahi-common-data
libavahi-common-dev libavahi-common3 libavahi-compat-libdnssd-dev
libavahi-compat-libdnssd1 libavahi-core7 libavcodec-extra libavcodec-extra58
libavdevice58 libavfilter7 libavformat58 libavresample4 libavutil56
libbind9-161 libbluray2 libbrotli1 libbsd0 libbz2-1.0 libbz2-dev libc-bin
libc-dev-bin libc-l10n libc6 libc6-dev libcairo-gobject2 libcairo2 libcups2
libcurl3-gnutls libcurl4 libdbi-perl libdbus-1-3 libdbus-1-dev
libdns-export1104 libdns1104 libdpkg-perl libespeak1 libexpat1 libexpat1-dev
libflac8 libfreetype6 libfribidi0 libgcrypt20 libgif7 libglib2.0-0 libgmp10
libgnutls30 libgssapi-krb5-2 libgstreamer-plugins-base1.0-0 libhogweed4
libinput-bin libinput10 libisc-export1100 libisc1100 libisccc161
libisccfg163 libjpeg-dev libjpeg62-turbo libjpeg62-turbo-dev libjson-c3
libk5crypto3 libklibc libkrb5-3 libkrb5support0 libksba8 libldap-2.4-2
libldap-common libldb1 libllvm7 liblwres161 liblz4-1 liblzma5 libmagic-mgc
libmagic1 libncurses-dev libncurses5 libncurses5-dev libncurses6
libncursesw5 libncursesw6 libnettle6 libnss3 libopenjp2-7 libopenmpt0
libp11-kit0 libpam-systemd libpcap0.8 libpcre2-16-0 libpcre2-32-0
libpcre2-8-0 libpcre2-dev libpcre2-posix0 libperl5.28 libpixman-1-0
libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0
libportaudio2 libpostproc55 libproxy1v5 libpython2.7 libpython2.7-dev
libpython2.7-minimal libpython2.7-stdlib libpython3.7 libpython3.7-dev
libpython3.7-minimal libpython3.7-stdlib libqt5core5a libqt5dbus5 libqt5gui5
libqt5network5 libqt5printsupport5 libqt5widgets5 librsvg2-2 librsvg2-common
libsasl2-2 libsasl2-modules-db libsmbclient libsndfile1 libsox-fmt-alsa
libsox-fmt-base libsox-fmt-mp3 libsox3 libsqlite3-0 libssh-gcrypt-4
libssl-dev libssl1.1 libswresample3 libswscale5 libsystemd0 libtasn1-6
libtiff5 libtinfo5 libtinfo6 libudev-dev libudev1 libunwind8 libwavpack1
libwbclient0 libwebp6 libwebpdemux2 libwebpmux3 libx11-6 libx11-data
libx11-xcb1 libxapian30 libzmq5 libzstd1 linux-libc-dev locales
mariadb-client mariadb-client-10.3 mariadb-client-core-10.3 mariadb-common
mariadb-server mariadb-server-10.3 mariadb-server-core-10.3 mplayer
multiarch-support ncurses-base ncurses-bin nodejs openssl perl perl-base
perl-modules-5.28 php7.3 php7.3-cli php7.3-common php7.3-curl php7.3-dev
php7.3-gd php7.3-gmp php7.3-imap php7.3-json php7.3-ldap php7.3-mbstring
php7.3-mysql php7.3-opcache php7.3-readline php7.3-soap php7.3-xml
php7.3-xmlrpc php7.3-zip policykit-1 psmisc python-apt-common python-avahi
python-lxml python2.7 python2.7-dev python2.7-minimal python3-apt python3.7
python3.7-dev python3.7-minimal rsyslog rtl8821cu-dkms samba-common
samba-libs smbclient sox sudo systemd systemd-sysv tzdata udev unzip vim
vim-common vim-runtime vim-tiny wpasupplicant xserver-common xvfb xxd
xz-utils zlib1g zlib1g-dev
279 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 293 MB of archives.
After this operation, 28.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] Abort.
Fri Mar 1 16:49:46 UTC 2024
libxml2-dev is already the newest version (2.9.4+dfsg1-7+deb10u6).
libxslt1-dev is already the newest version (1.1.32-2.2~deb10u2).
python3 is already the newest version (3.7.3-1).
Fri Mar 1 16:49:51 UTC 2024
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
The following additional packages will be installed:
libpython3.7 libpython3.7-dev libpython3.7-minimal libpython3.7-stdlib
python3.7 python3.7-dev python3.7-minimal python3.7-venv
Suggested packages:
python3.7-doc binfmt-support
python3-venv python3.7-venv
7 upgraded, 2 newly installed, 0 to remove and 274 not upgraded.
Need to get 8232 kB/8233 kB of archives.
After this operation, 56.3 kB of additional disk space will be used.
Err:1 Index of /debian-security buster/updates/main arm64 python3.7-dev arm64 3.7.3-2+deb10u4
404 Not Found [IP: 2a04:4e42:6a::644 80]
Err:2 Index of /debian-security buster/updates/main arm64 python3.7 arm64 3.7.3-2+deb10u4
Err:3 Index of /debian-security buster/updates/main arm64 libpython3.7-dev arm64 3.7.3-2+deb10u4
Err:4 Index of /debian-security buster/updates/main arm64 libpython3.7 arm64 3.7.3-2+deb10u4
Err:5 Index of /debian-security buster/updates/main arm64 libpython3.7-stdlib arm64 3.7.3-2+deb10u4
Err:6 Index of /debian-security buster/updates/main arm64 python3.7-minimal arm64 3.7.3-2+deb10u4
Err:7 Index of /debian-security buster/updates/main arm64 libpython3.7-minimal arm64 3.7.3-2+deb10u4
Err:8 Index of /debian-security buster/updates/main arm64 python3.7-venv arm64 3.7.3-2+deb10u4
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-dev_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-dev_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-stdlib_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-minimal_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/libpython3.7-minimal_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-venv_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Fri Mar 1 16:49:54 UTC 2024
The virtual environment was not created successfully because ensurepip is not
available. On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
apt-get install python3-venv
You may need to use sudo with that command. After installing the python3-venv
package, recreate your virtual environment.
Failing command: [‹ /var/www/html/plugins/teleinfo/ressources/venv/bin/python3 ›, ‹ -Im ›, ‹ ensurepip ›, ‹ –upgrade ›, ‹ –default-pip ›]
Fri Mar 1 16:49:57 UTC 2024
/var/www/html/plugins/teleinfo/ressources/venv/bin/python3: No module named pip
sudo: /var/www/html/plugins/teleinfo/ressources/venv/bin/pip3: command not found
Désolé pour la réponse tardive
J’ai été obligé de réinstaller mon jeedom
Aprés mise à jour de tele info le repertoire /html/plugins/teleinfo/ressources/venv
n’existe pas
