ça veut pas up le log donc…
pour le log Telegram à cette heure là:
[2021-01-19 15:20:50][DEBUG] : {"update_id":365356648, "message":{"message_id":195,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066050,"text":"Hello"}}
[2021-01-19 15:20:50][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:20:51][DEBUG] : Interaction Array ( [reply] => Désolé xx je n'ai pas compris )
[2021-01-19 15:20:51][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 1 [parse_mode] => HTML [text] => Désolé xx je n'ai pas compris [chat_id] => id )
[2021-01-19 15:20:51][DEBUG] : Result : {"ok":true,"result":{"message_id":196,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066051,"text":"D\u00e9sol\u00e9 xx je n'ai pas compris"}}
[2021-01-19 15:20:55][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 0 [parse_mode] => HTML [reply_markup] => {"keyboard":[["status","reboot","stop","terralampe","terratapis","rien"]],"one_time_keyboard":true,"resize_keyboard":true} [text] => Quelle action doit être executée? [chat_id] => id )
[2021-01-19 15:20:55][DEBUG] : Result : {"ok":true,"result":{"message_id":197,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066055,"text":"Quelle action doit \u00eatre execut\u00e9e?"}}
[2021-01-19 15:20:57][DEBUG] : {"update_id":365356649, "message":{"message_id":198,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066057,"text":"status"}}
[2021-01-19 15:20:57][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:20:58][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 1 [parse_mode] => HTML [text] => Température Extérieure: Entrée 8.3°C et 79% Terrasse 9.4°C et 81% Terrariums: Mehen 29.38°C 29%; Lampe 1; Tapis 0 Neheb 26.91°C 33.14%; Lampe 1; Tapis 0 [chat_id] => id )
[2021-01-19 15:20:58][DEBUG] : Result : {"ok":true,"result":{"message_id":199,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066058,"text":"Temp\u00e9rature Ext\u00e9rieure:
Entr\u00e9e 8.3\u00b0C et 79%
Terrasse 9.4\u00b0C et 81%
Terrariums:
Mehen 29.38\u00b0C 29%; Lampe 1; Tapis 0
Neheb 26.91\u00b0C 33.14%; Lampe 1; Tapis 0"}}
[2021-01-19 15:21:21][DEBUG] : {"update_id":365356650, "message":{"message_id":200,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066081,"text":"Hello"}}
[2021-01-19 15:21:21][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:21:22][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 0 [parse_mode] => HTML [reply_markup] => {"keyboard":[["status","reboot","stop","terralampe","terratapis","rien"]],"one_time_keyboard":true,"resize_keyboard":true} [text] => Quelle action doit être executée? [chat_id] => id )
[2021-01-19 15:21:22][DEBUG] : Result : {"ok":true,"result":{"message_id":201,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066082,"text":"Quelle action doit \u00eatre execut\u00e9e?"}}
[2021-01-19 15:21:33][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 1 [parse_mode] => HTML [text] => Pas de réponse - Merci a plus au revoir :) [chat_id] => id )
[2021-01-19 15:21:33][DEBUG] : Result : {"ok":true,"result":{"message_id":203,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066093,"text":"Pas de r\u00e9ponse - Merci a plus au revoir :)"}}
[2021-01-19 15:21:33][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:21:33][DEBUG] : {"update_id":365356651, "message":{"message_id":202,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066083,"text":"status"}}
[2021-01-19 15:21:33][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:21:33][DEBUG] : Interaction Array ( [reply] => Désolé je n'ai pas compris la demande )
[2021-01-19 15:21:33][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 1 [parse_mode] => HTML [text] => Désolé je n'ai pas compris la demande [chat_id] => id )
[2021-01-19 15:21:33][DEBUG] : Result : {"ok":true,"result":{"message_id":204,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066093,"text":"D\u00e9sol\u00e9 je n'ai pas compris la demande"}}
[2021-01-19 15:26:30][DEBUG] : {"update_id":365356652, "message":{"message_id":205,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066390,"text":"Hello"}}
[2021-01-19 15:26:30][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:26:30][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:26:47][DEBUG] : {"update_id":365356653, "message":{"message_id":206,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066407,"text":"Hello"}}
[2021-01-19 15:26:47][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:26:47][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 0 [parse_mode] => HTML [reply_markup] => {"keyboard":[["status","reboot","stop","terralampe","terratapis","rien"]],"one_time_keyboard":true,"resize_keyboard":true} [text] => Quelle action doit être executée? [chat_id] => id )
[2021-01-19 15:26:47][DEBUG] : Result : {"ok":true,"result":{"message_id":207,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066407,"text":"Quelle action doit \u00eatre execut\u00e9e?"}}
[2021-01-19 15:26:58][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 1 [parse_mode] => HTML [text] => Pas de réponse - Merci a plus au revoir :) [chat_id] => id )
[2021-01-19 15:26:58][DEBUG] : Result : {"ok":true,"result":{"message_id":209,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066418,"text":"Pas de r\u00e9ponse - Merci a plus au revoir :)"}}
[2021-01-19 15:26:58][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:26:59][DEBUG] : {"update_id":365356654, "message":{"message_id":208,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066408,"text":"status"}}
[2021-01-19 15:26:59][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:26:59][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:28:26][DEBUG] : ://jeedom.zzzJDM_bot.fr/plugins/telegram/core/api/jeeTelegram.php?apikey=EpY8AJ05Q12WUB1tlGYeybb3Z3XJTjHJ&id=68
[2021-01-19 15:28:26][DEBUG] : {"ok":true,"result":true,"description":"Webhook is already set"}
[2021-01-19 15:28:31][DEBUG] : ://jeedom.zzzJDM_bot.fr/plugins/telegram/core/api/jeeTelegram.php?apikey=EpY8AJ05Q12WUB1tlGYeybb3Z3XJTjHJ&id=68
[2021-01-19 15:28:31][DEBUG] : {"ok":true,"result":true,"description":"Webhook is already set"}
[2021-01-19 15:28:35][DEBUG] : {"update_id":365356655, "message":{"message_id":210,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066515,"text":"Hey"}}
[2021-01-19 15:28:35][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:28:36][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:28:51][DEBUG] : ://jeedom.zzzJDM_bot.fr/plugins/telegram/core/api/jeeTelegram.php?apikey=EpY8AJ05Q12WUB1tlGYeybb3Z3XJTjHJ&id=68
[2021-01-19 15:28:51][DEBUG] : {"ok":true,"result":true,"description":"Webhook is already set"}
[2021-01-19 15:28:55][DEBUG] : {"update_id":365356656, "message":{"message_id":211,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066535,"text":"Hello"}}
[2021-01-19 15:28:55][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:28:55][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:30:03][DEBUG] : {"update_id":365356657, "message":{"message_id":212,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066603,"text":"Hello"}}
[2021-01-19 15:30:03][DEBUG] : Recu message de yyyyyy
[2021-01-19 15:30:04][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 0 [parse_mode] => HTML [reply_markup] => {"keyboard":[["status","reboot","stop","terralampe","terratapis","rien"]],"one_time_keyboard":true,"resize_keyboard":true} [text] => Quelle action doit être executée? [chat_id] => id )
[2021-01-19 15:30:04][DEBUG] : Result : {"ok":true,"result":{"message_id":213,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066604,"text":"Quelle action doit \u00eatre execut\u00e9e?"}}
[2021-01-19 15:30:15][DEBUG] : Call url ://api.telegram.org/botid:bot_id/sendMessage with option Array ( [disable_notification] => 1 [parse_mode] => HTML [text] => Pas de réponse... Bye Bye :) [chat_id] => id )
[2021-01-19 15:30:15][DEBUG] : Result : {"ok":true,"result":{"message_id":215,"from":{"id":id,"is_bot":true,"first_name":"zzzJDM_bot27_JDM","username":"zzzJDM_botJDM_bot"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066615,"text":"Pas de r\u00e9ponse... Bye Bye :)"}}
[2021-01-19 15:30:15][DEBUG] : Interaction Array ( [reply] => )
[2021-01-19 15:30:15][DEBUG] : {"update_id":365356658, "message":{"message_id":214,"from":{"id":id,"is_bot":false,"first_name":"xx","last_name":"xx","username":"yyyyyy","language_code":"fr"},"chat":{"id":id,"first_name":"xx","last_name":"xx","username":"yyyyyy","type":"private"},"date":1611066605,"text":"status"}}
[2021-01-19 15:30:15][DEBUG] : Recu message de yyyyyy
